Zigate and aqara trough ikea signal repeater
Ivanhoe1
Post by Ivanhoe1 »
Trying to get aqara motion sensor to connect to a ikea signal repeater but dont get it. Ikea is connected to zigate but dont get how to connect the aqara to ikea..?
Tried to activate pairing in zigate and paired the aqara within 5cm from ikea = aqara gets directly connected to zigate.
Tried to pair aqara without zigate inclusion provisioning activated = aqara cant pair. Cant find any way to set ikea in pair mode for nodes, The little button on it seems only be used to the pairing against zigate.
Tried to move aqara away from zigate to see if it change route but it keeps connected to zigate with a 3 in signal strength.
How did you guys do to get this done?
pipiche
Re: Zigate and aqara trough ikea signal repeater
Post by pipiche »
If you are on beta branch, you might want to try this
https://github.com/pipiche38/Domoticz-Z ... mRouter.md
pipiche
Post by pipiche »
Screenshot 2020-05-10 at 16.53.25.png (226.43 KiB) Viewed 1943 times
I
f you update to the latest version on beta branch ( 4.8.026), User Interface in in place to provision on a specific router
Ivanhoe1
Post by Ivanhoe1 »
Great! But trying to change to branch beta and update but get ”Your branch is up to date” and plugin version is still 4.7.010.
pipiche
Post by pipiche »
Git checkout beta to reach the beta branch
Ivanhoe1
Post by Ivanhoe1 »
Sorry forgot to say that I get that (..is up to date) after changed branch to beta.
pipiche
Post by pipiche »
4.7 is stable branche, bêta branch is 4.8.
Ivanhoe1
Post by Ivanhoe1 »
Had to reinstall zigate to change branch to beta, it only said I hade latest version for beta but gui said 4.7.
But now i’m on 4.8.029. Tried as suggested but the aqara wont pair against the ikea repeater when its selected under ”Accept new Hardware on router”
pipiche
Post by pipiche »
@Ivanhoe1 , indeed I did few tests, and the repeater is not able to Accept New Hardware, while a Ikea Bulb or Ikea Plug do!
Ivanhoe1
Post by Ivanhoe1 »
@pipiche ,You know if theres any other repeater that works with zigate and aqara or if it might will work in feature with ikea repeater?
pipiche
Post by pipiche »
Thorgal789
Post by Thorgal789 »
pipiche wrote: Thursday 14 May 2020 14:20 @Ivanhoe1 , indeed I did few tests, and the repeater is not able to Accept New Hardware, while a Ikea Bulb or Ikea Plug do!
So you have some issues with ikea repeter too ?
pipiche
Post by pipiche »
Thorgal789 wrote: Sunday 16 August 2020 19:36
I'm not able to switch the Ikea Repeater to Permit Mode (without puting all others routers+gateway) in permit mode.
