free unused dashticz ports?
skom
- Domoticz version: 2022.2
First I installed dashticz stable version - it was installed on port 8082, then beta version - port 8083, after upgrading to the next beta version dashticz stopped working, so I installed again - port 8084 ... Now I only use the last version. How can I free port 8083 on which nothing is running anymore?
Lokonli
Re: free unused dashticz ports?
Probably there is still a Dashticz docker instance running on that port.
To see all docker containers:
This will give output similar as:
In this example you see there are two Dashticz containers running, on port 8082 and port 8083.
To stop the container with name dtv3-8083, which is running on port 8083:
The -t 5 parameter will give the container 5 seconds to gracefully shut down.
After this you have an unused, stopped image dtv3-8083.
To get an overview of all images:
This will show something like:
To remove all unused containers and images:
You will see a prompt, to which you can answer Y:
You can check the results with 'sudo docker ps' and 'sudo docker images'
sudo docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
500c42ae47eb dtv3-8083 "docker-php-entrypoi…" 3 weeks ago Up 2 weeks 0.0.0.0:8083->80/tcp dtv3-8083
af0cd4278a60 dtv3-8082 "docker-php-entrypoi…" 3 weeks ago Up 2 weeks 0.0.0.0:8082->80/tcp dtv3-8082
sudo docker stop -t 5 dtv3-8083
sudo docker images
REPOSITORY TAG IMAGE ID CREATED SIZE
<none> <none> a5d13a69533b 3 weeks ago 414MB
dtv3-8082 latest 5c0cc9bf78e7 3 weeks ago 414MB
dtv3-8083 latest 5c0cc9bf78e7 3 weeks ago 414MB
dtv3-8084 latest 5c0cc9bf78e7 3 weeks ago 414MB
php apache 5e1d7ed3b92a 5 weeks ago 414MB
hello-world latest fce289e99eb9 16 months ago 1.84kB
sudo docker system prune
WARNING! This will remove:
- all stopped containers
- all networks not used by at least one container
- all dangling images
- all dangling build cache
Are you sure you want to continue? [y/N] Y
Deleted Containers:
8140945ab5e770297a9b89751d3d8c303ca1ad2702dbaf1b6b68e6b1c6266aca
394f7f28dc9a26336a17534f539061a49caf624b090f0174620412472146e932
c4f8f460f86ee27a82090c15c070a66bf8a2763f430c8d534301c54ba585e62c
4401d69b78159b14e0f618758d2a547da34e2d9709ab661be51cedfc66774537
Deleted Images:
deleted: sha256:a5d13a69533bc8695fbd6feb0d094462d2b5a6d3d89256cd77c6f4b71c82271d
deleted: sha256:4db803ea9cd4b5e91e9ea3fa0746707aa3bbe6138f02083aa49aec2e6e59b6bb
deleted: sha256:36335a64948142f427dd6b94808682d7e49e4e252fdcd73dfa4f347f78513412
skom
Thank you
I release 8083 port, but "sudo docker system prune" did not removed anything
I still have don't used:
dtv3-8082 latest 270f15e46bc2 2 months ago 300MB
dtv3-8083 latest 270f15e46bc2 2 months ago 300MB
dtv3-8084 latest 270f15e46bc2 2 months ago 300MB
dtv3-8085 latest 270f15e46bc2 2 months ago 300MB
php apache 6c2719be579b 2 months ago 300MB
hello-world latest 851163c78e4a 4 months ago 4.85kB
Lokonli
You cannot remove the php apache image: It's used by Dashticz.
Other images, like hello-world, you remove with:
The number consists of the 5 first characters from the Image ID.
sudo docker image rm 85116
skom
Thank you again
