Ditec Gate RC signal compatible with RFLink ? HELP
Posted: Saturday 09 May 2020 9:47
I have a Raspberry Pi with 2 antennas modules for my tests purposes : RFXtrx433XL & RFLink with Arduino Mega 2560 (bought this pack : https://www.nodo-shop.nl/en/rflink-gate ... cable.html)
By using RFLink loader, i can copy a SOMFY RTS signal with no problem and then create a switch in Domoticz (by using this french method : https://matdomotique.wordpress.com/2016 ... k-et-somfy)
Now i would like to copy the signal of Ditec outdoor gate remote controler (remote controler model : Ditec GoL4)
When switching on the Serial port LOG monitor in RFLink Loader, i can see a line appearing when i press one of the Ditec RC button :
20;03;Ditec;ID=92b6;SWITCH=01;CMD=ON;
In Domoticz, i went in "settings > devices. I could see a new device detected coming from the RFLink with the code "92b6" and type=Ditec. I added this line as a new device, and it now appears in my switch list. When i press the Ditec RC button, i dont see the state changing for the Ditec switch. The Ditec RC frequency is 433,92Mhz so i thought it would work like the SOMFY RTS blinds..
Question : is it possible to copy a Ditec signal with RFLink and remote control the Ditec gate from Domoticz ?
Thank you for any help
