Page 1 of 2
Atag Zone One thermostat
Posted: Thursday 07 May 2020 22:31
by mvveelen
Hi there,
I'm aware of the Atag One plugin for Domoticz, but since today I have replaced my Nefit Easy for the new Atag Zone One thermostat.
Is there any chance of getting the readings in Domoticz too?
What could I do to get this added to Domoticz?
Re: Atag Zone One thermostat
Posted: Thursday 07 May 2020 23:52
by FireWizard
On github you can find an API. (Probably also used by the Domoticz plugin).
See:
https://juur.link/2015/11/atag-one-thermostaat/
and
https://github.com/kozmoz/atag-one-api
If you "google", you will also find the description :
https://atag.one/
It is a typical Node Red job:
https://flows.nodered.org/node/node-red ... b-atag-one
So possibilities enough.
Posted: Friday 08 May 2020 8:47
by mvveelen
Well, this is all about the Atag One and not about the Atag Zone One.
I think that's why I can't get it added to my Domoticz, the Hardware is "Atag One" where I need the "Atag Zone One", or are both using the same plugin?
Posted: Friday 08 May 2020 11:22
by FireWizard
@mvveelen
My apologies that I overlooked, that the results are for the Atag One instead of the Atag
Zone One.
Did you also replace your boiler?
Or does the Atag Zone One thermostat uses the Nefit EMS protocol?
Perhaps the API and/or the Node Red node supports also the Atag One thermostat.
That is easy to test with the NR node.
Posted: Friday 08 May 2020 13:03
by mvveelen
yes the whole unit has been replaced by an Atag i36ECZ-CW5 boiler.
The Atag Zone One connects to the internet, so that is independent of the boiler as far as I know.
I was able to connect the Atag Zone One to Homekit, but I really would like to have the readings in Domoticz......
Posted: Friday 08 May 2020 22:11
by FireWizard
@mvveelen
Perhaps the solution is to use HomeBridge Edomoticz.
A wiki exists and there are a number of users on this forum.
Posted: Saturday 09 May 2020 20:37
by mvveelen
FireWizard wrote: Friday 08 May 2020 22:11
@mvveelen
I don't understand. What will this do to add the Atag Zone One to Domoticz? Maybe you can explain a bit more?
Posted: Saturday 09 May 2020 21:13
by FireWizard
@mvveelen
It was just an idea, as I found:
https://www.atagverwarming.nl/ondersteu ... asystemen/
Homebridge Edomoticz is an interface between Domoticz and Homekit.
Recently I noted this thread on this forum:
https://www.domoticz.com/forum/viewtopi ... 69&t=32242
Here they use Homebridge to communicate with Google Home.
It had nothing to do with Homekit.
As it is stated (in Dutch):
De ATAG One Zone is compatibel met Apple Homekit en Amazon Alexa. Snel worden Google Home toegevoegd. Andere systemen worden voorlopig niet (direct) ondersteund. Wel kan je altijd kijken of jouw specifieke systeem één van de eerdergenoemde systemen ondersteund, waarmee indirect veel te verbinden is.
The last line made me make that suggestion.
I read also that this Atag Zone One can be controlled by the Atag One app.
This app is the same as the app used for the Atag One thermostat.
Did you already test something?
Posted: Saturday 09 May 2020 21:37
by mvveelen
FireWizard wrote: Saturday 09 May 2020 21:13
Where did you read that? I installed the Atag One app on my iPhone too, but I had to make an extra account on the Atag One website and with that account I couldn't control the Atag. But then again, the app isn't the issue, the thermostat (hardware) is the issue, this needs to be read somehow.
I have tests the plugin for the Atag One, I've tested some scripts for the Atag One, nothing.
Posted: Saturday 09 May 2020 21:54
by mvveelen
There is a website on which I can logon:
http://my.atag.zone and when I do so, I can see all readings from my thermostat:
- Schermafbeelding 2020-05-09 om 21.52.26.png (140.92 KiB) Viewed 6728 times
(yes, it was a hot day.....)
So maybe there is a way to get the readings from this website (directly from the thermostat seems a better way, but I'm only guessing...)
Posted: Saturday 09 May 2020 22:08
by FireWizard
@mvveelen
I made that conclusion, because of two facts:
1. In the Google Play Store, I see one app (Atag One) made by Atag.
The Atag zone is made by Ariston Thermo SpA. Third party?
2.
https://www.atagverwarming.nl/ondersteu ... -one-zone/
In this question:
https://www.atagverwarming.nl/ondersteu ... -zone-app/
they talk about the Atag One.
So sorry, a wrong conclusion.
As you said you tested a number of things, but with the app you should be able to communicate.
Not the Atag One app, but Atag Zone One app.
In this case you communicate directly with the thermostat?
B.t.w. the Zone thermostat is already supported by Google Home, so you can already control it by Google Assistant.
Posted: Saturday 09 May 2020 22:18
by mvveelen
No harm done
Unfortunately the Atag One app keeps searching for the Atag One, not the Atag Zone One. So with the Atag One app I can't control the Atag boiler.
Maybe the website is something that could contribute to a solution?
Posted: Friday 05 November 2021 18:40
by flouflou
Hi mvveelen,
I also got a new atag zone boiler and I was wondering if you found out something new
Posted: Friday 05 November 2021 19:34
by mvveelen
No,
Still not supported. Although I haven’t searched since my post.
Posted: Monday 08 November 2021 17:25
by flouflou
I found a possible solution for my side. So I'm working with homeassisten and it is working for me to connect locally via homekit to the atag zone one boiler. Now I'm able to configure custom automations for example: leave the home -> switch heating temperature to 15 degrees
Steps to configure the connection between homeassisten / atag one zone
1) Take an IOS device (it's not possible with an android phone because the IOS Home App is a must have) and download & install the atag zone app
2) Configure the device like in the user manual:
https://f.hubspotusercontent00.net/hubf ... uide-2.pdf
3) Start Home App on the Iphone
4) Click on "add device"
5) Click on "code is missing"
6) Click on the "Remote Atag" Device
7) Click: "open Camera" after that the HomeKit QR Code opens on the ATAG Zone Controller.
Do not scan it with the IOS phone!
8) Open homeassitant: Configuration -> Integrations -> HomeKit Controller (should already detect the device)
9) Type in the 7 digits which are showing up above the QR Code into homeassistant.
Kind Regards
Posted: Sunday 21 November 2021 12:49
by mvveelen
Good for you, but this is a Domoticz forum/topic. How can Domoticz users benefit from this?
Posted: Wednesday 24 November 2021 3:32
by flouflou
1) I wanted to show a approach that there exists a possible solution to connect the atag zone to third party software.
2) Maybe you can find a working apple homekit integration for Domoticz and read data for your needs. Homekit Siri could be a possible solution after a quick google research.
Posted: Sunday 14 August 2022 15:25
by mvveelen
The website for the Atag
Zone One has been changed significantly, maybe there could be way to get this as native hardware in Domoticz? Willing to try/test of course.
Or, if someone managed to get the readings in Domoticz, share your findings
Posted: Monday 15 August 2022 10:53
by waltervl
It seems that ATAG still has not opened their API for the ATAG Zone. So an integration is not possible other than with Google Home or Amazon Alexa.
Posted: Monday 15 August 2022 20:18
by mvveelen
That's too bad. Unfortunately I'm not able to do this myself, so hopefully someone will try in the near future and describe what he/she has done in the Wiki. Thanks!
