App Access Topic is solved
Luxtux
Domoticz version: 2021.1 β
App Access
Post by Luxtux »
Good evening,
In the last few days i'm unable to connect to my domoticz instance via the paid android app. Apparently im no longer allowed to used basic auth and need to use the logon page. this is an issue for my current set up
        <Location /domoticz/json.htm>
                AuthType Basic
                AuthName "Basic auth"
                AuthBasicProvider file
                AuthUserFile "/var/www/shared/psswd/passwords"
                Require valid-user
        </Location>
        ProxyPass /domoticz/json.htm https://domoticz/json.htm
        proxyPassReverse /domoticz/json.htm https://domoticz/json.htm
even by removing the password it doesnt work anymore. could you please tell me why this doesnt work anymore?
FireWizard
Re: App Access
Post by FireWizard »
Luxtux
Re: App Access
Post by Luxtux »
thank you for that but i would like to authorise the minimum amount of files to be shared with the outside world. is there some login page i need to make available?
Luxtux
Re: App Access
Post by Luxtux »
ok after reading some more posts. i found that i was not forwarding login check. My apache configuration now looks like this
	ProxyPass /domoticz/logincheck https://domoticz/logincheck
        proxyPassReverse /domoticz/logincheck https://domoticz/logincheck
