Aqara Air Conditioning (HUB) lumi.acpartner.v3 doesn't work.
Vopis
Post by Vopis »
I have an Aqara Air Conditioning controller. It works as a HUB, just doesn't support all sensors but it supports sensor I have at the moment (water leak sensor, wall switch with null, remote switch, themperature sensor).
https://xiaomi-mi.com/sockets-and-senso ... ty-sensor/
The problem is that I can't connect it to domoticz. I played around with older verision of Mi Home on Android device and found the token for my device as it is not possible to get it from newer versions of Mi Home for this specific HUB.
When I try to send a request to my Aqara Air Conditioning controller via php-miio it works and device is responding back, which means that token is correct.
root@server:~/php-miio# php miio-cli.php --ip 192.168.1.200 --token {my_token} --sendcmd '{"id":1,"method":"get_music_free_space","params":[]}'
Устройство 192.168.1.200 доступно и ответило:
{"result":[11437778],"id":1}
I tried to add this device in domoticz -> Hardware as "Xiaomi Gateway", port 9898 and password the token I have but it doesn't discover any devices, even the Aqara Conditioning Controller itself doesn't appear in devices. I think it must appear as a switch or IR controller as it has a power socket and infrared on it.
model: lumi.acpartner.v3
Vopis
Re: Aqara Air Conditioning (HUB) lumi.acpartner.v3 doesn't work.
Post by Vopis »
Anyone can help me with this problem?
molnaratti
Post by molnaratti »
i know i don't support it unfortunately.
