Login mix-up Thermosmart
Posted: Tuesday 05 May 2020 16:30
We have two homes next to each other that I am connecting via Domoticz. In each home we have a Thermosmart to control the heating. Aside from sometimes having a login error (also mentioned elsewhere ion this forum) I get that the two devices get mixed up after them logging in.
Instead of having both devices displaying the settings and readings from each separate device, I will have both hardware devices in Domoticz showing the values from just one device.
In reality Thermosmart 9 will be set to 20 degrees and reading a room temperature of 20.4 degrees. Thermosmart 11 will be set to 21 degrees and reading 21.6 degrees. Domoticz will, for instance, show both 9 and 11 as being set to 21 degrees and reading 21.6. It can also be vice-versa.
If I go to hardware and select each Thermosmart and press "Update", the login is repeated and the values correspond to what they should be. How can this be happening? And how can I prevent this? It's rather annoying, as because of another issue I'm still having with a plugin causing Domoticz to crash a few times a day, this happens too often.
For now, I have removed one of the hardware devices, but would like to add it again in the near future.
