is it possible tio see which dzvents script activated device
Posted: Tuesday 05 May 2020 14:17
by Gravityz
yesterday i had one of the weirdest things.
I had a zwave device(pump) which aparently activated on it's own
looking at the log it seems it was activated by a dzvents script.
the thing is this script does not have the pump device in it
is there a way to tell what activated this device
so it looks like pir sensor triggered dzvents script which turned on switch 19(veranda) and then also triggered Tuinsproeier
2020-05-04 22:05:57.801  Status: OpenZWave: Alarm received (Home Security: Motion Detected at Unknown Location), NodeID: 16 (0x10)
2020-05-04 22:05:57.802  (Aeonlabs Z-wave stick Gen5) Light/Switch (Sensor)
2020-05-04 22:05:57.804  (Aeonlabs Z-wave stick Gen5) General/Alarm (Alarm Type: Burglar 7 (0x07))
2020-05-04 22:05:57.807  (Aeonlabs Z-wave stick Gen5) Light/Switch (PIR sensor)
2020-05-04 22:05:57.858  Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2020-05-04 22:05:57.895  OpenZWave: Domoticz has send a Switch command! NodeID: 19 (0x13)
2020-05-04 22:05:57.897  (Aeonlabs Z-wave stick Gen5) Light/Switch (Veranda)
2020-05-04 22:05:58.326  MQTT: Topic: domoticz/in, Message: {"idx":339,"RSSI":10,"nvalue":0,"svalue":"22.1"}
2020-05-04 22:05:59.475  (Aeonlabs Z-wave stick Gen5) Usage (Watt Tuinlampen)
2020-05-04 22:05:59.479  (Aeonlabs Z-wave stick Gen5) General/kWh (kWh Tuinlampen)
2020-05-04 22:05:59.662  (Aeonlabs Z-wave stick Gen5) Light/Switch (Tuinsproeier)
2020-05-04 22:05:59.713  Status: EventSystem: Script event triggered: /usr/local/domoticz/dzVents/runtime/dzVents.lua
2020-05-04 22:05:59.741  Status: Notification: Domoticz
2020-05-04 22:05:59.742  Notification sent (email) => Success
2020-05-04 22:05:59.742  Notification sent (browser) => Success
2020-05-04 22:05:59.874  Notification sent (telegram) => Success
this is the script which turned on 2 seconds before the pump but it has no pump device in it
so in my situation it turned on device veranda at 22:05:57 and turned on device tuinsproeier at 22:05:59
-- Script wat er voor zorgt dat de veranda verlichting automatisch aan gaat bij beweging
-- PIR sensor staat zelf ingesteld dat deze alleen werkt bij minder dan 5 lux
    active = true,
        devices = {
            ['PIR sensor'] = {'between sunset and 00:00'}
    execute = function(domoticz, beweging)
            if beweging.state == 'On'  then
            domoticz.devices('Veranda').switchOn().checkFirst().forMin(5)
this is the script which turns of the Tuinsproeier after 50 minutes
they both have dependency in it regarding timeframe.
-- Script zorgt er voor dat de tuinsproeier na inschakeling altijd weer uit gaat na 50 minuten
    active = true,
       devices = { ['Tuinsproeier'] = {'on 01/04-30/09'} }
    execute = function(domoticz, switch)
        local timestamp=domoticz.time.rawTime
        if (switch.state == 'On') then
            local results = domoticz.helpers.addRollingTextLine(domoticz, 'Status', 'Tuinsproeier ingeschakeld', '4')
           domoticz.devices('Tuinsproeier').switchOff().afterMin(50)
           --domoticz.notify("Domoticz", timestamp.."\r\n".."Tuinsproeier ingeschakeld", "telegram")
            domoticz.globalData.tuinsproeierlaststatus = 'On'
        if (switch.state == 'Off') then
            --tuinsproeierlaststatus wordt gebruikt om geen onnodige off meldingen via telegram te krijgen
            if domoticz.globalData.tuinsproeierlaststatus == 'On' then
            local results = domoticz.helpers.addRollingTextLine(domoticz, 'Status', 'Tuinsproeier uitgeschakeld', '4')
            --domoticz.notify("Domoticz", timestamp.."\r\n".."Tuinsproeier uitgeschakeld", "telegram")
            domoticz.globalData.tuinsproeierlaststatus = 'Off'
Re: is it possible tio see which dzvents script activated device
Posted: Tuesday 05 May 2020 15:48
by waaren
Gravityz wrote: Tuesday 05 May 2020 14:17 looking at the log it seems it was activated by a dzvents script.
This (relatively new) user field in the log cannot be trusted yet.
see this forum post and this github issue
Posted: Tuesday 05 May 2020 17:28
by Gravityz
ok, we can not trust the log but any idea how this could have happened.
the pump switched on 2 seconds after my outside veranda lights so that is not a coincindence i think
