Hello everyone,
I pull my hair out, I can't solve this problem....
I open and close my Venetian blinds with some states ...like If the sun power is high enough etc..
But every time that statement is true it try to close the blinds, they allready closed before.
So I want to read out the status off the blinds...
I already tried to use the status closed and open, but that does not seems to work.
For now I use a variable that is set when the statement is true,etc, but that variable is not set when you open /close the blinds physically.
How to read out the status of the Venetian Blinds
- closed.gif (17.33 KiB) Viewed 1031 times
- open.gif (17.79 KiB) Viewed 1031 times
wouterlet
Re: How to read out the status of the Venetian Blinds
Please post your script, then it's easier to see what's going wrong
That is true ….
A basic script, that not function:
- 2.GIF (34.41 KiB) Viewed 982 times
- 1.GIF (12.37 KiB) Viewed 982 times
hoeby
- Domoticz version: V2022.1
Try "On" instead of "Open".
I also have a venetian blind. In de device tab it says "Open" and "Close". But in the log of that device it says "On" and "Off"
