installing ubuntu error
Posted: Tuesday 05 May 2020 10:38
by deheugden
I downloaded the latest Ubuntu LTS Desktop and tried to install Domoticz.
I use the following code:
sudo apt curl -sSL install.domoticz.com | sudo bash
but i get the following error:
command line option 's' [from -sSL] is not understood in combination with the other options.
Anyone who knows what is going wrong?
regards,
Re: installing ubuntu error
Posted: Tuesday 05 May 2020 10:46
by sancla
Posted: Tuesday 05 May 2020 11:10
by erem
it's not
it is
sudo curl -sSL install.domoticz.com | sudo bash
Posted: Tuesday 05 May 2020 11:33
by deheugden
correct, thanks
Posted: Saturday 09 May 2020 22:16
by jackwan1
- domoticzinstall.jpg (239.99 KiB) Viewed 1048 times
I used the correct curl command, but I got Error 404 Not Found at the end. What could be the problem? I am using Ubuntu 18.04
Posted: Sunday 31 May 2020 19:11
by foxmulder06
What is your OS version: 32 or 64 bits ?
As far as I know, and I was obliged to do it like this, the Binary is only available for 64 bits platform, therfore if you have a 32 bits platform, the binary is
not available anymore and give you an error message...
I read on the Screen capture the text "i686" that confirms that you have a 32 bits platform...
Solution: The only way to get Domoticz running on a 32 bits platform is to "compil" it on your platform, after getting the Source code.
Please follow link:
https://www.domoticz.com/wiki/Build_Do ... om_source
Note: I did it without any problems on "
Ubuntu 18.04.4 LTS" +
INTEL ATOM 32bits + Domoticz latest release
V2020.2
I created an installation process, fully automated by Shell script that do ALL stuff automatically...
Good luck !
