[Solved:] Zigate webUI: Delete device button
Geitje
Post by Geitje »
About the device-management tab in de Zigate webUI: For some reason I do not see the garbage-bin shaped button to delete devices. It was there some time ago. I tried to make the column broader, but that is not possible (I can make it smaller). Language change also not helping.
I want to use the button to delete a device. I deleted it from Domoticz, but somehow it still is in the devicelist of Zigate (I restarted the plugin already).
Aantekening 2020-05-05 012340.png (77.54 KiB) Viewed 487 times
Zwave, Zigate, RFlink etc.
pipiche
Re: Zigate webUI: Delete device button
Post by pipiche »
The Trash icon, will only be available if the entry can be removed.
If you don't get the Trash icon after a plugin restart, this is normaly due to the fact that some Widget remains connected to this entry
Geitje
Post by Geitje »
Sorry, you were right, it was still in my Domoticz devices list (had only set it to inactive). Now working again.
