Multiple triggers with Qubino mini dimmer
Posted: Sunday 03 May 2020 10:39
I have installed a Qubino mini dimmer, and everytime I switch it from Domoticz, this results in three event triggers instead of one. For instance, if I switch it on, I get three device events (for instance in dzvents)
- First one with state "On" immediately when I turn the switch on
- Another one 800ms later with state "Off"
- Another one 1-2s later with final state "On".
This makes scripting complex and unreliable for advanced scenarios.
I have checked, other module such as Fibaro relays don't have this behavior. Is this something that can be fixed? Do you observe the same on Qubino mini dimmers? Do the Fibaro Dimmer 2 or Aeotec Nano Dimmer have the same issue? (These are the three zwave modules which work without neutral).
