Using login page instead of basic auth does not work with webroot
Posted: Saturday 02 May 2020 15:49
by CV8R
I am trying to change from Basic Auth to Login Page and I cannot login when I start Domoticz with -webroot. It works fine using Login Page only, when using the default (no weboot).
I have tried resetting the password using:
sudo ./domoticz -nowwwpwd
or
resetpwd file
I have tried clearing caches between each step of changing between Basic Auth and Login Page.
I found that running from the command line using sudo ./domoticz I can login with Login Page, with sudo ./domoticz -webroot I can not login.
If I change back to Basic Auth (password reset when i do it) then i can login either with or without a modified webroot -webroot
Any help would be really appreciated!
Version: 2020.2 on x86
Cheers
CV8R
