Pairing Ikea Tradfri Driver with Zigate
Posted: Friday 01 May 2020 16:18
by mobielbas
I have a problem with the pairing of the ikea tradfri LED driver with zigate (USB). I am running domoticz v2020.2 on the raspberry 3b+. When i turn on and of the LED light for many times with different speeds it ist visible on the zigate website under device management. Nothing to see in the log files also. Is there someone who has experience with this pairing process?
Re: Pairing Ikea Tradfri Driver with Zigate
Posted: Friday 01 May 2020 17:00
by pipiche
mobielbas wrote: Friday 01 May 2020 16:18
I'm not sure I fully understand, so let me summarize
- You are trying to pair an Ikea Tradfri Led Driver with Zigate/plugin/domoticz
-I beleive you follow the standard process documented in the wiki, so
Zigate and plugin in Pairing mode
Domoticz accepting new Hardware
- After "reseting" the led driver, you see an entry in the Device Management page of the plugin website, but no widget created on Domoticz
If that is correct, could please follow what is here afgter and provide me the export.json file as an attachement here
https://github.com/pipiche38/Domoticz-Z ... -device.md
Posted: Saturday 02 May 2020 19:07
by ronaldbro
You shouldn’t turn off and on the tradfri led driver. It has a little hole with a button you can press with a paper clip.
