Fronius solar inverter Plugin
ayasystems
I have completed another plugin to integrate Fronius FV inverter into domoticz
https://github.com/ayasystems/froniusHttp
Enjoy it!
Enjoy it!
Fronius plugin
Solax plugin
https://github.com/ayasystems/SolaxHTTP
Openevse plugin
https://github.com/ayasystems/OpenEVSEPlugin
Solax plugin
Openevse plugin
zettie
Re: Fronius solar inverter Plugin
I followed your instructions to install it on my raspberry ( https://domotuto.com/fronius_domoticz_plugin/ ), but i don't see any values in the information fields. When I go to the Fronius converter on my local network I do see the values
Are there some more settings, for instance on the Fronius converter?
- sincze
- Domoticz version: 2024.4
Haha nice. This I got to try.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
ayasystems
Did you provide the relevant settings??zettie wrote: Tuesday 07 July 2020 10:11 Hi,
Host IP ....
Please send a screen shot
Fronius plugin
Solax plugin
Openevse plugin
Solax plugin
Openevse plugin
zettie
Yes, I,ve filled in the IP adress.
zettie
I get the following error messages in the Domoticz logfile:
2020-07-07 21:30:34.416 (Fronius) Good Response received from Solax, Dropping connection.
2020-07-07 21:30:34.417 Error: (Fronius) 'onMessage' failed 'NameError'.
2020-07-07 21:30:34.417 Error: (Fronius) ----> Line 229 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-07 21:30:34.417 Error: (Fronius) ----> Line 164 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-07 21:30:34.418 Error: (Fronius) ----> Line 324 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function processResponse
ayasystems
Please set max debug level and send the log
What's your fronius model??
Test to open the following urls and let me know the response
http://IP_FRONIUS/solar_api/v1/GetMeterRealtimeData.cgi?Scope=System
http://IP_FRONIUS/solar_api/v1/GetPowerFlowRealtimeData.fcgi
http://IP_FRONIUS/solar_api/v1/GetInverterRealtimeData.cgi?Scope=System
The plugin was done using a FRONIUS PRIMO 6.0-1 6KW
Fronius plugin
Solax plugin
Openevse plugin
Solax plugin
Openevse plugin
zettie
Hi, I have a Fronius Symo 5.0-3-M.
The output for http://IP_FRONIUS/solar_api/v1/GetMeterRealtimeData.cgi?Scope=System is:
"Body" : {
"Data" : {
"0" : {
"Details" : {
"Manufacturer" : "Fronius",
"Model" : "S0 Meter at inverter 1",
"Serial" : "n.a."
"Enable" : 0,
"Meter_Location_Current" : 0,
"TimeStamp" : 1594141652,
"Visible" : 1
"Head" : {
"RequestArguments" : {
"DeviceClass" : "Meter",
"Scope" : "System"
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2020-07-09T13:23:14+02:00"
the output for http://IP_FRONIUS/solar_api/v1/GetPowerFlowRealtimeData.fcgi is:
"Body" : {
"Data" : {
"Inverters" : {
"1" : {
"DT" : 122,
"E_Day" : 3228.5,
"E_Total" : 590416,
"E_Year" : 590416.9375,
"P" : 847
"Site" : {
"E_Day" : 3228.5,
"E_Total" : 590416,
"Meter_Location" : "unknown",
"Mode" : "vague-meter",
"P_Akku" : null,
"P_Grid" : null,
"P_Load" : null,
"P_PV" : 847,
"rel_Autonomy" : null,
"rel_SelfConsumption" : null
"Version" : "12"
"Head" : {
"RequestArguments" : {},
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2020-07-09T13:25:13+02:00"
the output for http://IP_FRONIUS/solar_api/v1/GetInverterRealtimeData.cgi?Scope=System is:
"Body" : {
"Data" : {
"DAY_ENERGY" : {
"Unit" : "Wh",
"Values" : {
"1" : 3248
"PAC" : {
"Unit" : "W",
"Values" : {
"1" : 694
"TOTAL_ENERGY" : {
"Unit" : "Wh",
"Values" : {
"1" : 590436
"YEAR_ENERGY" : {
"Unit" : "Wh",
"Values" : {
"1" : 590436
"Head" : {
"DeviceClass" : "Inverter",
"Scope" : "System"
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Timestamp" : "2020-07-09T13:26:48+02:00"
"Body" : {
"Data" : {
"0" : {
"Details" : {
"Serial" : "n.a."
"Enable" : 0,
"Visible" : 1
"Head" : {
"Scope" : "System"
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Body" : {
"Data" : {
"Inverters" : {
"1" : {
"DT" : 122,
"E_Day" : 3228.5,
"E_Total" : 590416,
"P" : 847
"Site" : {
"E_Day" : 3228.5,
"E_Total" : 590416,
"P_Akku" : null,
"P_Grid" : null,
"P_Load" : null,
"P_PV" : 847,
"Version" : "12"
"Head" : {
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
"Body" : {
"Data" : {
"DAY_ENERGY" : {
"Unit" : "Wh",
"Values" : {
"1" : 3248
"PAC" : {
"Unit" : "W",
"Values" : {
"1" : 694
"TOTAL_ENERGY" : {
"Unit" : "Wh",
"Values" : {
"1" : 590436
"YEAR_ENERGY" : {
"Unit" : "Wh",
"Values" : {
"1" : 590436
"Head" : {
"Scope" : "System"
"Status" : {
"Code" : 0,
"Reason" : "",
"UserMessage" : ""
ayasystems
You have a diferent Fronius model, seems like json are diferent. I will try to add your model to work
Fronius plugin
Solax plugin
Openevse plugin
Solax plugin
Openevse plugin
zettie
Hi, that would be terrific!
I didn't know that there is a difference in output between the Primo and the Symo because the picture you fist placed was of a Symo
ayasystems
I changed it..zettie wrote: Friday 10 July 2020 13:13 Hi, that would be terrific!
I didn't know that there is a difference in output between the Primo and the Symo because the picture you fist placed was of a Symo![]()
I have not frunius inverter. I did it with data from one friend... I will try to add Symo... I have changed the picture (now it is a Primo)
Fronius plugin
Solax plugin
Openevse plugin
Solax plugin
Openevse plugin
jansen1443
When using this plugin with a Primo 3.0-1 I get the same message.
Am I doing something wrong?
020-07-20 21:30:47.773 (Fronius) Pushing 'onMessageCallback' on to queue
2020-07-20 21:30:47.773 (Fronius) Processing 'onMessageCallback' message
2020-07-20 21:30:47.773 (Fronius) Calling message handler 'onMessage'.
2020-07-20 21:30:47.773 (Fronius) HTTP Details (3):
2020-07-20 21:30:47.773 (Fronius) a>'Status':'200'
2020-07-20 21:30:47.773 (Fronius) b>'Headers':
2020-07-20 21:30:47.773 (Fronius) ----a>'Content-Type':'application/json'
2020-07-20 21:30:47.773 (Fronius) ----a>'Cache-Control':'no-cache, no-store, must-revalidate'
2020-07-20 21:30:47.773 (Fronius) ----a>'Pragma':'no-cache'
2020-07-20 21:30:47.773 (Fronius) ----a>'Expires':'0'
2020-07-20 21:30:47.773 (Fronius) ----a>'Content-Length':'902'
2020-07-20 21:30:47.773 (Fronius) ----a>'Date':'Mon, 20 Jul 2020 19:30:45 GMT'
2020-07-20 21:30:47.774 (Fronius) ----a>'Server':'webserver'
2020-07-20 21:30:47.774 (Fronius) a>'Data':'b'{\n "Body" : {\n "Data" : {\n "Inverters" : {\n "1" : {\n "DT" : 81,\n "E_Day" : 15056,\n "E_Total" : 16248359,\n "E_Year" : 1798289.625,\n "P" : 0\n }\n },\n "Site" : {\n "E_Day" : 15056,\n "E_Total" : 16248359,\n "E_Year" : 1798289.625,\n "Meter_Location" : "unknown",\n "Mode" : "produce-only",\n "P_Akku" : null,\n "P_Grid" : null,\n "P_Load" : null,\n "P_PV" : null,\n "rel_Autonomy" : null,\n "rel_SelfConsumption" : null\n },\n "Version" : "12"\n }\n },\n "Head" : {\n "RequestArguments" : {},\n "Status" : {\n "Code" : 0,\n "Reason" : "",\n "UserMessage" : ""\n },\n "Timestamp" : "2020-07-20T21:30:45+02:00"\n }\n}\n''
2020-07-20 21:30:47.774 (Fronius) Good Response received from Solax, Dropping connection.
2020-07-20 21:30:47.774 Error: (Fronius) 'onMessage' failed 'NameError'.
2020-07-20 21:30:47.774 Error: (Fronius) ----> Line 229 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-20 21:30:47.774 Error: (Fronius) ----> Line 164 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-20 21:30:47.774 Error: (Fronius) ----> Line 324 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function processResponse
2020-07-20 21:30:57.548 (Fronius) Sending 222 bytes of data
2020-07-20 21:30:57.548 (Fronius) 47 45 54 20 2f 73 6f 6c 61 72 5f 61 70 69 2f 76 31 2f 47 65 GET./solar_api/v1/Ge
2020-07-20 21:30:57.548 (Fronius) 74 50 6f 77 65 72 46 6c 6f 77 52 65 61 6c 74 69 6d 65 44 61 tPowerFlowRealtimeDa
2020-07-20 21:30:57.548 (Fronius) 74 61 2e 66 63 67 69 20 48 54 54 50 2f 31 2e 31 0d 0a 43 6f ta.fcgi.HTTP/1.1..Co
2020-07-20 21:30:57.548 (Fronius) 6e 74 65 6e 74 2d 54 79 70 65 3a 20 74 65 78 74 2f 78 6d 6c ntent-Type:.text/xml
2020-07-20 21:30:57.548 (Fronius) 3b 20 63 68 61 72 73 65 74 3d 75 74 66 2d 38 0d 0a 43 6f 6e ;.charset=utf-8..Con
2020-07-20 21:30:57.548 (Fronius) 6e 65 63 74 69 6f 6e 3a 20 6b 65 65 70 2d 61 6c 69 76 65 0d nection:.keep-alive.
2020-07-20 21:30:57.548 (Fronius) 0a 41 63 63 65 70 74 3a 20 43 6f 6e 74 65 6e 74 2d 54 79 70 .Accept:.Content-Typ
2020-07-20 21:30:57.548 (Fronius) 65 3a 20 74 65 78 74 2f 68 74 6d 6c 3b 20 63 68 61 72 73 65 e:.text/html;.charse
2020-07-20 21:30:57.548 (Fronius) 74 3d 55 54 46 2d 38 0d 0a 48 6f 73 74 3a 20 31 39 32 2e 31 t=UTF-8..Host:.192.1
2020-07-20 21:30:57.548 (Fronius) 36 38 2e 32 32 2e 31 31 36 3a 38 30 0d 0a 55 73 65 72 2d 41 68.22.116:80..User-A
2020-07-20 21:30:57.548 (Fronius) 67 65 6e 74 3a 20 44 6f 6d 6f 74 69 63 7a 2f 31 2e 30 0d 0a gent:.Domoticz/1.0..
2020-07-20 21:30:57.548 (Fronius) 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
2020-07-20 21:30:57.798 (Fronius) Pushing 'ReadEvent' on to queue
2020-07-20 21:30:57.799 (Fronius) Processing 'ReadEvent' message
2020-07-20 21:30:57.799 (Fronius) Received 1112 bytes of data
2020-07-20 21:30:57.799 (Fronius) 48 54 54 50 2f 31 2e 31 20 32 30 30 20 4f 4b 0d 0a 43 6f 6e HTTP/1.1.200.OK..Con
tjabas
Hi!
i have tried your plugin and it works great but just on one of my fronius inverters,
the one that it works on has a fronius smartmeter, the other one where the plugins doesnt work doesnt have any smart meter, does this plugin require a smartmeter for it to work?
i get this error message in the log:
2020-07-22 11:31:41.176 Error: (Fronius) onStart:
2020-07-22 11:31:41.176 Error: (Fronius) onStart - try
2020-07-22 11:31:41.194 Error: (Fronius) Address: 192.168.1.182
2020-07-22 11:31:41.194 Error: (Fronius) port: 80
2020-07-22 11:31:41.346 Error: (Fronius) 'onMessage' failed 'NameError'.
2020-07-22 11:31:41.346 Error: (Fronius) ----> Line 229 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-22 11:31:41.346 Error: (Fronius) ----> Line 164 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-22 11:31:41.346 Error: (Fronius) ----> Line 324 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function processResponse
2020-07-22 11:31:51.548 Error: (Fronius) 'onMessage' failed 'NameError'.
2020-07-22 11:31:51.548 Error: (Fronius) ----> Line 229 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-22 11:31:51.548 Error: (Fronius) ----> Line 164 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-22 11:31:51.548 Error: (Fronius) ----> Line 324 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function processResponse
2020-07-22 11:32:01.374 Error: (Fronius) 'onMessage' failed 'NameError'.
2020-07-22 11:32:01.374 Error: (Fronius) ----> Line 229 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-22 11:32:01.374 Error: (Fronius) ----> Line 164 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-07-22 11:32:01.374 Error: (Fronius) ----> Line 324 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function processResponse
ayasystems
Do you have meter connected?? I will fix measures without meter....
I have not time at now but i will back after summer, sorry
Fronius plugin
Solax plugin
Openevse plugin
Solax plugin
Openevse plugin
tjabas
hi!
yes on one of the inverters there is a meter, the other one dont have one.
the one with a fronius smartmeter works good, but not the other one.
tjabas
i have enabled debuggin on the inverter that doesnt seem to connect, and it actually seems like the plugin connects to the inverter, but i cant read the data from the inverter.
gniazdoj
- Domoticz version: 2023.1
Hi,ayasystems wrote: Wednesday 22 July 2020 14:14 Do you have meter connected?? I will fix measures without meter....
I have as well Primo 3.0-1 without any meter, would be great to have option to disable it on Hardware tab if that is the issue. I'm getting same errors like jansen1443. If you need any dump of communication please let me know. It would be great to use more advance option. Hope it support night when inverter is offline as my current script produce error each minute because of unhandled connection.
Thank you
Jakub
gniazdoj
I have Primo 3.0-1 I would see switch on Hardware configuration tab to select between Inverters. We need to use different URL to get data from with different data structure. You can look on draft code that I've changed from original great phyton script from author.gniazdoj wrote: Tuesday 20 October 2020 19:13Hi,ayasystems wrote: Wednesday 22 July 2020 14:14 Do you have meter connected?? I will fix measures without meter....
Thank you
Jakub
# Fronius http python plugin
# @2020
# Author: EA4GKQ
#https://github.com/akleber/fronius-json-tools
# 06/05/2020
# - Añadido dummy con valor medio de Grid de las últimas 30 muestras
# - Mejorada reconexión automática
<plugin key="FroniusHttp" name="Fronius http" author="EA4GKQ" version="1.0.2" wikilink="https://github.com/ayasystems/froniusHttp" externallink="https://www.fronius.com/es-es/spain/energia-solar/productos">
<description>
<h2>Fronius HTTP Pluging</h2><br/>
<h3>by @ea4gkq</h3>
<br/>
<a href="https://domotuto.com/fronius_domoticz_plugin/">https://domotuto.com/fronius_domoticz_plugin/</a>
<br/>
</description>
<params>
<param field="Address" label="Fronius IP" width="200px" required="true" default="192.168.1.xx"/>
<param field="Mode1" label="Protocol" width="75px">
<options>
<option label="HTTP" value="80" default="true" />
</options>
</param>
<param field="Mode2" label="Update speed" width="75px">
<options>
<option label="Normal" value="Normal"/>
<option label="High" value="High" default="true" />
</options>
</param>
<param field="Mode6" label="Debug" width="150px">
<options>
<option label="None" value="0" default="true" />
<option label="Python Only" value="2"/>
<option label="Basic Debugging" value="62"/>
<option label="Basic+Messages" value="126"/>
<option label="Connections Only" value="16"/>
<option label="Connections+Queue" value="144"/>
<option label="All" value="-1"/>
</options>
</param>
</params>
</plugin>
errmsg = ""
try:
import Domoticz
except Exception as e:
errmsg += "Domoticz core start error: "+str(e)
try:
import json
errmsg += " Json import error: "+str(e)
try:
import time
errmsg += " time import error: "+str(e)
try:
import re
errmsg += " re import error: "+str(e)
from random import seed
from random import gauss
from functools import reduce
class FroniusHttp:
httpConn = None
interval = 1
runAgain = interval
connectedCount = 0
disconnectCount = 0
sProtocol = "HTTP"
DAY_ENERGY1 = ""
PAC1 = ""
TOTAL_ENERGY1 = ""
DAY_ENERGY = ""
PAC = ""
TOTAL_ENERGY = ""
P_PV = "" #Instant production
E_Day = "" #Total of the day
E_Total = "" #Total Production
E_Year = "" #Production Year
P_Grid = "" #Negative inject Positive consume
UAC = "" #Grid + solar consumption
FAC = ""
IAC = ""
IDC = ""
UDC = ""
UAC = ""
F_PAC = ""
F_FAC = ""
F_IAC = ""
F_IDC = ""
F_UDC = ""
F_UAC = ""
GRID_W = ""
listGrid = []
maxGridList = 30
avgGrid = 0
URL2 = "/solar_api/v1/GetInverterRealtimeData.cgi?Scope=System"
#URL1 = "/solar_api/v1/GetPowerFlowRealtimeData.fcgi"
URL1 = "/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData"#jakub
#URL2 = "/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterData"#jakub
#192.168.1.51/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DataCollection=CommonInverterData&DeviceId=1
current = ""
def __init__(self):
return
def onStart(self):
Domoticz.Error("onStart: "+errmsg)
if errmsg =="":
try:
Domoticz.Debug("onStart - try")
if Parameters["Mode6"] == "": Parameters["Mode6"] = "-1"
if Parameters["Mode6"] != "0":
Domoticz.Debug("if parameters mode 6: "+Parameters["Mode6"])
Domoticz.Debugging(int(Parameters["Mode6"]))
Domoticz.Debug("DumpConfigToLog")
DumpConfigToLog()
createDevices(self,"F_PAC")
createDevices(self,"F_FAC")
createDevices(self,"F_IAC")
createDevices(self,"F_IDC")
createDevices(self,"F_UAC")
createDevices(self,"F_UDC")
if (Parameters["Mode1"].strip() == "443"): self.sProtocol = "HTTPS"
if (Parameters["Mode2"].strip() == "High"): Domoticz.Heartbeat(1)
Domoticz.Debug("Address: "+Parameters["Address"])
Domoticz.Debug("port: "+Parameters["Mode1"].strip())
Domoticz.Debug("Address: "+Parameters["Address"].strip())
self.httpConn = Domoticz.Connection(Name=self.sProtocol+" Test", Transport="TCP/IP", Protocol=self.sProtocol, Address=Parameters["Address"].strip() , Port=Parameters["Mode1"].strip() )
self.httpConn.Connect()
Domoticz.Error("Plugin onStart error: "+str(e))
else:
Domoticz.Error("Your Domoticz Python environment is not functional! "+errmsg)
def onStop(self):
Domoticz.Log("onStop - Plugin is stopping.")
def Average(self):
if(len(self.listGrid)>self.maxGridList):
self.listGrid.pop(0)
#Domoticz.Debug("List values: "+str(self.listGrid))
self.avgGrid = reduce(lambda a,b: a + b, self.listGrid) / len(self.listGrid)
self.avgGrid = round(self.avgGrid,0)
def onConnect(self, Connection, Status, Description):
if (Status == 0):
Domoticz.Debug("Fronius connected successfully.")
if(self.current==self.URL2):
self.current=self.URL1
else:
self.current=self.URL2
sendData = { 'Verb' : 'GET',
'URL' : self.current,
'Headers' : { 'Content-Type': 'text/xml; charset=utf-8', \
'Connection': 'keep-alive', \
'Accept': 'Content-Type: text/html; charset=UTF-8', \
'Host': Parameters["Address"]+":"+Parameters["Mode1"], \
'User-Agent':'Domoticz/1.0' }
Connection.Send(sendData)
else:
Domoticz.Log("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Mode1"]+" with error: "+Description)
def onMessage(self, Connection, Data):
DumpHTTPResponseToLog(Data)
strData = Data["Data"].decode("utf-8", "ignore")
Status = int(Data["Status"])
#LogMessage(strData)
#Domoticz.Debug("Data.onMessage: " + str(Data))
Domoticz.Debug("Status.onMessage: " + str(Status))
#Domoticz.Debug("self.disconnectCount & 1: " + str((self.disconnectCount & 1)) )
if (Status == 200):
if ((self.disconnectCount & 1) == 1):
Domoticz.Log("Good Response received from Solax, Disconnecting.")
self.httpConn.Disconnect()
else:
Domoticz.Log("Good Response received from Solax, Dropping connection.")
self.httpConn = None
self.disconnectCount = self.disconnectCount + 1
processResponse(self,Data)
elif (Status == 302):
Domoticz.Log("Fronius returned a Page Moved Error.")
'URL' : Data["Headers"]["Location"],
'User-Agent':'Domoticz/1.0' },
elif (Status == 400):
Domoticz.Error("Solax returned a Bad Request Error.")
elif (Status == 500):
Domoticz.Error("Solax returned a Server Error.")
else:
Domoticz.Debug("Solax returned a status: "+str(Status))
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
def onDisconnect(self, Connection):
Domoticz.Debug("onDisconnect called for connection to: "+Connection.Address+":"+Connection.Port)
def onHeartbeat(self):
if(self.connectedCount>10):
self.connectedCount = 0
#Domoticz.Trace(True)
if (self.httpConn != None and (self.httpConn.Connecting() or self.httpConn.Connected())):
Domoticz.Debug("onHeartbeat called, Connection is alive.")
else:
self.runAgain = self.runAgain - 1
if self.runAgain <= 0:
if (self.httpConn == None):
self.httpConn = Domoticz.Connection(Name=self.sProtocol+" Test", Transport="TCP/IP", Protocol=self.sProtocol, Address=Parameters["Address"], Port=Parameters["Mode1"])
self.runAgain = self.interval
else:
Domoticz.Debug("onHeartbeat called, run again in "+str(self.runAgain)+" heartbeats.")
#Domoticz.Trace(False)
global _plugin
_plugin = FroniusHttp()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
def onDisconnect(Connection):
global _plugin
_plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def LogMessage(Message):
if Parameters["Mode6"] == "File":
f = open(Parameters["HomeFolder"]+"http.html","w")
f.write(Message)
f.close()
Domoticz.Log("File written")
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
def processResponse(self,httpResp):
DAY_ENERGY1 = ""#jakub
PAC1 = ""
TOTAL_ENERGY1 = ""
stringData = httpResp["Data"].decode("utf-8", "ignore")
jsonData = json.loads(stringData)
Domoticz.Debug("##self.current: "+self.current)
Domoticz.Debug("##self.URL2: "+self.URL2)
Domoticz.Debug("##self.URL1: "+self.URL1)
#Domoticz.Debug("httpResp.processResponse: " + str(httpResp))
try:
self.DAY_ENERGY1 = str(jsonData['Body']['Data']['DAY_ENERGY']['Values']['1'])
self.PAC1 = str(jsonData['Body']['Data']['PAC']['Values']['1'])
self.TOTAL_ENERGY1 = str(jsonData['Body']['Data']['TOTAL_ENERGY']['Values']['1'])
if Parameters["Mode6"] == "-1":
Domoticz.Debug("DAY_ENERGY1: "+self.DAY_ENERGY1)
Domoticz.Debug("PAC1: "+self.PAC1)
Domoticz.Debug("TOTAL_ENERGY1: "+self.TOTAL_ENERGY1)
except:
Domoticz.Debug(str(e))
if(self.current==self.URL1):#jakub
try:
self.PAC = str(jsonData['Body']['Data']['PAC']['Value'])
self.E_Day = str(jsonData['Body']['Data']['DAY_ENERGY']['Value'])
self.E_Total = str(jsonData['Body']['Data']['TOTAL_ENERGY']['Value'])
self.E_Year = str(jsonData['Body']['Data']['YEAR_ENERGY']['Value'])
self.UAC = str(jsonData['Body']['Data']['UAC']['Value'])
self.UDC = str(jsonData['Body']['Data']['UDC']['Value'])
self.IAC = str(jsonData['Body']['Data']['IAC']['Value'])
self.IDC = str(jsonData['Body']['Data']['IDC']['Value'])
self.FAC = str(jsonData['Body']['Data']['FAC']['Value'])
#self.P_PV = str(jsonData['Body']['Data']['Site']['P_PV'])
#self.listGrid.append(F_IDC)
#self.Average()
Domoticz.Error("F_PAC: "+self.PAC)
Domoticz.Error("E_Day: "+self.E_Day)
Domoticz.Error("E_Total: "+self.E_Total)
Domoticz.Error("E_Year: "+self.E_Year)
Domoticz.Error("F_UAC: "+self.UAC)
Domoticz.Error("F_UDC: "+self.UDC)
Domoticz.Error("F_IAC: "+self.IAC)
Domoticz.Error("F_IDC: "+self.IDC)
Domoticz.Error("F_FAC: "+self.FAC)
#Domoticz.Error("List: "+str(self.listGrid))
#Domoticz.Error("AVG Grid: "+str(round(self.avgGrid,0)))
instantaneoFV = self.PAC
acumuladoKwhFV = self.E_Day#daily accumulated
#if(F_IDC>=0):
# UpdateDevice("F_FAC", 0, "0;0")
# UpdateDevice("F_IDC", 0, str(F_IDC)+";0")
#Domoticz.Debug("##self.UAC : " + self.UAC )
#if(F_FAC>0):
#UpdateDevice("F_FAC", 0, self.P_Grid+";0")
# UpdateDevice("F_IDC", 0, "0;0")
UpdateDevice("F_PAC", 0, instantaneoFV+";"+acumuladoKwhFV)
UpdateDevice("F_UAC", 0, self.UAC+";0")
UpdateDevice("F_UDC", 0, self.UDC+";0")
UpdateDevice("F_FAC", 0, self.FAC+";0")
UpdateDevice("F_IAC", 0, self.IAC+";0")
UpdateDevice("F_IDC", 0, self.IDC+";0")
#UpdAteDevice("AVGGRID", 0, self.avgGrid)
except:
def DumpHTTPResponseToLog(httpResp, level=0):
if (level==0): Domoticz.Debug("HTTP Details ("+str(len(httpResp))+"):")
indentStr = ""
for x in range(level):
indentStr += "----"
if isinstance(httpResp, dict):
for x in httpResp:
if not isinstance(httpResp[x], dict) and not isinstance(httpResp[x], list):
Domoticz.Debug(indentStr + "a>'" + x + "':'" + str(httpResp[x]) + "'")
else:
Domoticz.Debug(indentStr + "b>'" + x + "':")
DumpHTTPResponseToLog(httpResp[x], level+1)
elif isinstance(httpResp, list):
for x in httpResp:
Domoticz.Debug(indentStr + "['" + x + "']")
else:
Domoticz.Debug(indentStr + "c>'" + x + "':'" + str(httpResp[x]) + "'")
def createDevices(self,unitname):
OptionsSensor = {"Custom": "1;Hz"}
OptionsSensorAVG = {"Custom": "1;w"}
iUnit = -1
for Device in Devices:
try:
if (Devices[Device].DeviceID.strip() == unitname):
iUnit = Device
break
except:
pass
if iUnit<0: # if device does not exists in Domoticz, than create it
try:
iUnit = 0
for x in range(1,256):
if x not in Devices:
iUnit=x
break
Domoticz.Debug("Creating: "+unitname);
if iUnit==0:
iUnit=len(Devices)+1
if(unitname=="F_IDC"): #amper
Domoticz.Device(Name=unitname, Unit=iUnit,Type=243,Subtype=23,Switchtype=0,Used=1,DeviceID=unitname).Create()
if(unitname=="F_IAC"): #amper
if(unitname=="F_FAC"): #custom
Domoticz.Device(Name=unitname, Unit=iUnit,Type=243,Subtype=31,Switchtype=0,Used=1,DeviceID=unitname).Create()
if(unitname=="F_UAC"): #voltage
Domoticz.Device(Name=unitname, Unit=iUnit,Type=243,Subtype=8,Switchtype=0,Used=1,DeviceID=unitname).Create()
if(unitname=="F_UDC"): #voltage
if(unitname=="F_PAC"):
Domoticz.Device(Name=unitname, Unit=iUnit,Type=243,Subtype=29,Switchtype=0,Used=1,DeviceID=unitname).Create()
return False
return
def UpdateDevice(unitname, nValue, sValue):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it
# if (Devices[Device].DeviceID.strip() == unitname):
iUnit = -1
try:
iUnit = Device
break
except:
pass
if iUnit>=0: # existe, actualizamos
if (Devices[iUnit].nValue != nValue) or (Devices[iUnit].sValue != sValue):
Devices[iUnit].Update(nValue=nValue, sValue=str(sValue))
Domoticz.Debug("Update "+str(nValue)+":'"+str(sValue)+"' ("+Devices[iUnit].Name+")")
2020-10-30 15:42:54.894 (FroniusInverter) Good Response received from Solax, Dropping connection.
2020-10-30 15:42:54.895 Error: (FroniusInverter) 'onMessage' failed 'NameError'.
2020-10-30 15:42:54.895 Error: (FroniusInverter) ----> Line 249 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-10-30 15:42:54.895 Error: (FroniusInverter) ----> Line 184 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function onMessage
2020-10-30 15:42:54.895 Error: (FroniusInverter) ----> Line 359 in '/home/pi/domoticz/plugins/froniusHttp/plugin.py', function processResponse
Thanks for great code
Jakub
- Freakandel
Hi, I was wonderring if you get it working. I have the same error in Domoticz log, using the plugin with a Fronius Symo 5.0-3 invertor:
I hove someone has fixed this, I would like to get info into Domoticz.
Restults with direct links to the Fronius:2020-11-15 13:53:17.978 Error: (Fronius Solar Inverter) 'onMessage' failed 'NameError'.
2020-11-15 13:53:17.978 Error: (Fronius Solar Inverter) ----> Line 229 in '/home/maarten/domoticz/plugins/froniusHttp/plugin.py'
2020-11-15 13:53:17.978 Error: (Fronius Solar Inverter) ----> Line 164 in '/home/maarten/domoticz/plugins/froniusHttp/plugin.py'
2020-11-15 13:53:17.978 Error: (Fronius Solar Inverter) ----> Line 324 in '/home/maarten/domoticz/plugins/froniusHttp/plugin.py'
- Spoiler: show
gniazdoj
Please use last code published. I've made some changes. Still working to support more devices and some cosmetics.I use the 06/05/2020 version of the python plugin.
In general you need to find out your best URL depends of your device specification. You need to know if you have APIv0 or APIv1 and phase 1 or phase 3 installation. This determine URL you should use. The error you presented says we can't find name you requested. Because of wrong URL or missing data.
please update in script URL1 and URL4 to same value and select on Domoticz Hardware Tab-Inverter:"Fronius"
you can see our conversation where APIv0 was needed.
https://github.com/ayasystems/froniusHttp/issues/1
please try URL this is for 1phase devices:
APIv0
http://IP/solar_api/GetInverterRealtimeData.cgi?Scope=Device&DeviceIndex=1&DataCollection=CommonInverterDataCode: Select all
http://IP/solar_api/v1/GetInverterRealtimeData.cgi?Scope=Device&DeviceID=1&DataCollection=CommonInverterDatahttps://www.fronius.com/en/photovoltaic ... 4216b1f709
Good luck
