script produces error [Solved]
Posted: Friday 01 May 2020 12:13
by jkimmel
I switched from Raspi to Windows. The scripts were fine under Buster
Here is the script
-- assumptions:
-- the setpoint is set by a selector dummy device where the values are numeric temperatures
-- but you can easily change it to a setpoint device
local BOILER_DEVICE = 'FB 23 Heizkreis Buero' -- switch device
local SETPOINT_DEVICE = 'Solltemperatur Buero' -- selector dummy device
local TEMPERATURE_SENSOR = 'Buero'
local MODUS_DEVICE = 'Modus Waermepumpe' -- selector dummy device
local LOGGING = false
return
    on =
        timer =
            'every 3 minutes'
    logging =
        level = LOGGING and domoticz.LOG_DEBUG or domoticz.LOG_ERROR or domoticz.LOG_INFO,
        marker = 'HZ Buero',
    active = true,
    execute = function(domoticz)
        local boiler = domoticz.devices(BOILER_DEVICE)
        local temperature = domoticz.devices(TEMPERATURE_SENSOR).temperature
        local setpoint = domoticz.devices(SETPOINT_DEVICE).levelName
        local modusState = domoticz.devices(MODUS_DEVICE).state
        local boilerState = boiler.state
        local setpointValue = tonumber(setpoint)
        domoticz.log('Current temperature: ' .. temperature, domoticz.LOG_DEBUG)
        domoticz.log('Setpoint: ' .. setpointValue, domoticz.LOG_DEBUG)
        domoticz.log('Current boiler state: ' .. boilerState, domoticz.LOG_DEBUG)
        -- now determine what to do
       if setpoint == 'Off' or modusState ~= 'Heizen' then
             boiler.switchOff()
        elseif temperature > setpointValue and boilerState == 'On' then
            boiler.switchOff()
        elseif temperature <= setpointValue and boilerState == 'Off' and modusState == 'Heizen'  then
            boiler.switchOn()
         if temperature > setpointValue then
            domoticz.log('Target temperature reached, boiler off', domoticz.LOG_INFO)
            domoticz.log('Target temperature not reached, boiler on', domoticz.LOG_INFO)
producing the error:
2020-05-01 12:09:00.400 Error: dzVents: Error: (3.0.2) HZ Buero: An error occurred when calling event handler Klima Buero
2020-05-01 12:09:00.400 Error: dzVents: Error: (3.0.2) HZ Buero: ...oticz\scripts\dzVents\generated_scripts/Klima Buero.lua:39: attempt to concatenate a nil value (local 'setpointValue')
Re: Two similar scripts one produces error the other not
Posted: Friday 01 May 2020 12:31
by waaren
jkimmel wrote: Friday 01 May 2020 12:13 -- the setpoint is set by a selector dummy device where the values are numeric temperatures
It seems that the setpoint (string) cannot be converted to a number.
can you change line 39 to
        domoticz.log('Setpoint: ' .. tostring(setpoint), domoticz.LOG_DEBUG)
and show the result?
Re: script produces error
Posted: Friday 01 May 2020 13:04
by jkimmel
Now this:
2020-05-01 13:03:00.383 Error: dzVents: Error: (3.0.2) HZ Buero: An error occurred when calling event handler Klima Buero
2020-05-01 13:03:00.383 Error: dzVents: Error: (3.0.2) HZ Buero: ...oticz\scripts\dzVents\generated_scripts/Klima Buero.lua:51: attempt to compare nil with number
It seems to me handling of setpointvalue is different running Windows, because under Buster no problems
Posted: Friday 01 May 2020 13:19
by waaren
jkimmel wrote: Friday 01 May 2020 13:04 Now this:
You need to set the level of logging to debug to see what is happening.
So change this part
    logging =
to
    logging =
       -- level = LOGGING and domoticz.LOG_DEBUG or domoticz.LOG_ERROR or domoticz.LOG_INFO,
        level = domoticz.LOG_DEBUG,
Posted: Friday 01 May 2020 14:13
by jkimmel
Status
2020-05-01 14:06:00.222 Status: dzVents: Info: HZ Buero: ------ Start internal script: Klima Buero:, trigger: "every 3 minutes"
2020-05-01 14:06:00.232 Status: dzVents: Debug: HZ Buero: Processing device-adapter for FB 23 Heizkreis Buero: Switch device adapter
2020-05-01 14:06:00.232 Status: dzVents: Debug: HZ Buero: Processing device-adapter for Buero: Temperature+humidity device adapter
2020-05-01 14:06:00.232 Status: dzVents: Debug: HZ Buero: Processing device-adapter for Solltemperatur Buero: Switch device adapter
2020-05-01 14:06:00.232 Status: dzVents: Debug: HZ Buero: Processing device-adapter for Modus Waermepumpe: Switch device adapter
2020-05-01 14:06:00.232 Status: dzVents: Debug: HZ Buero: Current temperature: 23.39999961853
2020-05-01 14:06:00.240 Status: dzVents: Debug: HZ Buero: Setpoint: 25
2020-05-01 14:06:00.240 Status: dzVents: Debug: HZ Buero: Current boiler state: Off
2020-05-01 14:06:00.240 Status: dzVents: Debug: HZ Buero: Constructed timed-command: On
2020-05-01 14:06:00.240 Status: dzVents: Info: HZ Buero: Target temperature not reached, boiler on
2020-05-01 14:06:00.240 Status: dzVents: Info: HZ Buero: ------ Finished Klima Buero
2020-05-01 14:06:00.240 Status: dzVents: Debug: Commands sent to Domoticz:
2020-05-01 14:06:00.240 Status: dzVents: Debug: - FB 23 Heizkreis Buero = On
Error:
2020-05-01 14:03:00.211 Error: dzVents: Error: (3.0.2) HZ Buero: An error occurred when calling event handler Klima Buero
2020-05-01 14:03:00.211 Error: dzVents: Error: (3.0.2) HZ Buero: ...oticz\scripts\dzVents\generated_scripts/Klima Buero.lua:52: attempt to compare nil with number
Posted: Friday 01 May 2020 15:34
by waaren
jkimmel wrote: Friday 01 May 2020 14:13
The script uses a mix of string and number without checking these. You need to add an additional check for that.
Can you try this?
-- assumptions:
return
    on =
        timer =
            'every 3 minutes'
    logging =
    active = true,
        local setpointValue = tonumber(setpoint) or -99  -- set it to -99 when setpoint is a string that cannot be converted to a number)
             boiler.switchOff()
             return
        if setpointValue ~= -99 then
                boiler.switchOff()
                boiler.switchOn()
Posted: Friday 01 May 2020 19:24
by jkimmel
Answer as quick as ever.
Many thanks
Re: script produces error [Solved]
Posted: Saturday 02 May 2020 0:52
by HvdW
I'm following this thread with interest.
Can you explain what is:
Is it to know if the Boiler_device is on or off?
If so can you explain how to create a dummy device that shows the state?
Posted: Saturday 02 May 2020 10:25
by jkimmel
stboiler
HvdW wrote: Saturday 02 May 2020 0:52 Hi,
In my case it is a selector which can be changed from "off" to heating or cooling. Nothing to do with the boiler.
is what you're looking for
