Dewpoint
Posted: Wednesday 29 April 2020 11:49
by ErikM
Is there anyone who can explain to me how to use the dewpoint device in a Blockly script? The wiki doesn't offer any explanation on it and I'm still very new to using Blockly (or any form of scripting, for that matter).
What I am trying to achieve is to use the dewpoint in a room to trigger an action that closes the valves on the underfloor cooling in that room when the temperature above the floor is at a safe level (say 2 degrees) above the dewpoint to avoid condensation on the floor. I was planning on measuring both temperature and dewpoint with an Aeotec Multisensor 6 (but if there are better sensor options, I'm open to suggestions.
Re: Dewpoint
Posted: Friday 01 May 2020 14:08
by knielen
As far as I know that's not possible with Blockly. You can compare the value of the dewpoint with the actual temperature. Or you can compare the dewpoint with a fixed number. But it's not possible to compare with the actual temperature and an offset.
Try to master dzvents, pretty steep learning curve, but eventually you need it anyway
Re: Dewpoint
Posted: Friday 01 May 2020 16:31
by ErikM
Darn... I already found Blockly to be a steep learning curve and when I look at a dzvents or lua script I break out in a sweat...
All the indentation makes it look extremely complicated and while Dewpoint is a device in Blockly, it is not in the normal device list. This is looking to be a lot more complicated than I had expected it to be...
Re: Dewpoint
Posted: Friday 01 May 2020 21:21
by jake
ErikM wrote:Darn... I already found Blockly to be a steep learning curve and when I look at a dzvents or lua script I break out in a sweat...
That was my first thought about lua (before dzvents was around) too. I didn't look forward to the learning curve. But when you want to do something more complicated than just a single if then else, it becomes a nightmare in blockly. So at some point I was fed up with it and decided to go for it. In the dzvents wiki is plenty of material to learn and 'steal' from. Over time I collected my scripts from using parts from other scripts and reuse of my own scripts. For instance I always start with a copy of an existing script, so the base is correct.
Re: Dewpoint
Posted: Saturday 02 May 2020 9:54
by rrozema
dzVents isn't hard. I've written you below example in 15 minutes. I hope the comments in the code will help you understand what this code does and opens up the opportunity to learn dzVents fast.
-- Change the names below to match your device names.
-- When changing the names take care to use the exact same
-- case as used in your device names.
-- For example: "TempHum" is not the same as "Temphum".
local TEMPERATURE_DEVICE_NAME = 'Keuken: TempHum'
local SWITCH_DEVICE_NAME = 'Keuken: Cooling'
-- I like to use variables for device names to avoid mistyping a
-- name when it is referenced multiple times in a script. I make
-- these variable names in all caps, but that is nu requirement.
-- I do this to easily identify where the variable is used.
-- Please also not the use of "local" in front of every declaration
-- of a variable. If you don't put that "local" in front of your
-- variables the script will run without problems. If however you
-- use in another script a variable with the same name, the variables
-- wil get mixed-up. So always specify the word "local" in front of
-- every variable declaration.
-- Indentation (spaces or tabs in front of lines) is not a requirement,
-- but it does help keep the code readable. So do yourself a favor,
-- always use proper indentation.
-- The "devices" section defines for which devices the execute-section
-- below will be executed. It can contain a list of device names
-- separated by a , . In this example only 1 device is listed
-- so no comma needed.
devices = {
-- This execute section is the code that will get executed when the device
-- in the devices section changes value.
-- The way to show output in your log file (if the log level is high enough).
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
-- Ask domoticz for a device object with the name of SWITCH_DEVICE_NAME.
local switch = domoticz.devices(SWITCH_DEVICE_NAME)
-- If you misspelled the name a nil-value will be returned.
-- "==" is equals, "~=" is not equals.
-- Every "if <condition>" must be followed by a "then", which must be
-- closed by an "end". Optionally an "else" can be used in between the
-- "then" and the "end".
if nil == switch then
-- This is another message i want shown in the log, here I specify
-- LOG_ERROR to make the text show up in bold and red in the log.
domoticz.log("Switch device " .. SWITCH_DEVICE_NAME .. " not found.", domoticz.LOG_ERROR)
-- what properties a device exposes depends on the type of the
-- device. Documentation is available in the wiki:
-- https://www.domoticz.com/wiki/DzVents:_next_generation_LUA_scripting
-- In this case I tried to implement what I think you asked for:
-- if the temperature is at least 2 degrees above the dewPoint
-- the switch must be switched off, if it falls below that it must
-- be switched on again.
if device.temperature >= device.dewPoint + 2 then
-- .switchOff() changes the devices' state to "Off". I don't
-- like to send to many commands, so I specify .checkFirst()
-- to make sure that no "Off" command is sent if the device
-- is already "Off".
switch.switchOff().checkFirst()
switch.switchOn().checkFirst()
end -- This is the "end" for the execute section.
