Move cloud cover to weather
Menno
Domoticz version: 2026.1
Post by Menno »
Hi All,
For some reason the cloud cover percentage is listed under the Utilty tab.
Would it not be way more logical to have this under the tab Weather?
Cheers,
Menno
kiddigital
Re: Move cloud cover to weather
Post by kiddigital »
Menno wrote: Tuesday 28 April 2020 15:28 Hi All,
Cheers,
Menno
Which weather module are you using? Maybe provide a (cropped) print screen of your issue?
The 'Weather' tab only displays certain Weather related sensortypes. Often Weathermodules also use more generic sensortypes to present additional information like 'cloud cover percentage' (generic percentage sensor) or 'Weather description' (generic test sensor) so Domoticz can not know that these sensor actually contain data that could be considered Weather data.
Menno
Post by Menno »
Sorry for replying so late, I don' t visit the forum very often.
I use the cloud cover percentage from Openweathermap.
Temperature, humidity, barometric pressure and visibilty from Openweathermap are all placed in the Weather tab, but cloud cover percentage is placed under Utility.
Is there a way for me to tell Domoticz this property belongs under Weather instead of under Utilty?
Menno
Post by Menno »
In version 2021.1 there are new devices for Openweathermap.
For instance "weather description". It is quite ludicrous that this gets placed in Utilities instead of in Weather.
Menno
Post by Menno »
Can we get cloud cover and weather description from OpenWeather in the Weather tab, instead of in Utilities?
Should not be a big or difficult change to make...
Unfortunately it is not that easy.
You can make a floormap with all the weather devices.
