Drayton wiser sensors
dbrb2
Post by dbrb2 »
I have a set of Draytin Wiser smart TRVs
They are seen by Domoticz using the wiser plugin for Domoticz
Each TRV appears as two devices - a thermostat with a set point, and a temperature sensor
Under "utilities" I can see each thermostat, with an "actual" and a "set" tewmperature - and these two values are identical.
Is there a way to merge the data from the TRV thermostat and the TRV temperature sensor into a single device, such that the "actual" = that measured from the sensor, and the "set" is the demand temperature?
Cheers!
