Hi All,
sometime it happens im Setup,
that a temperature Sensor or w Wattmeter or whatever, created a very hight or low Entry in the DB.
Then, if I look at the Graph for usage, I see this Peak and I don´t like to have it.
Is there a possibility to remove this wrong Peaks?In the Attachment, I send an Example of what i mean.
The NAS never ever used 10kW/h a Day, I like to remove this.
Best Regards
How to fix bad/wrong Data in Day/Week/Month/Year Protocol
mastadook
- Domoticz version: 2022.1
- here you see what I mean
- screendomo.PNG (64.39 KiB) Viewed 8176 times
________________________________________________________________________
global chief of permanent lightning and strike detonator
jake
Re: How to fix bad/wrong Data in Day/Week/Month/Year Protocol
With a computer, hold shift an right click on the faulty data. Domoticz will ask to remove that particular data point.
mastadook
no matter if with shift, Ctrl or Alt or whatever, I got no Menu to remove it:
See Screenshot.
What I´m doing wrong?
See Screenshot.
- domo.jpg (26.94 KiB) Viewed 8153 times
It's SHIFT + LEFT click.
It would be nice if there came an entry field for the right data itself, even an approximated data.
mastadook
no matter if shift and right or shift and left, still nothing or Standard browser Menu.
Using Google chrome actual Version
Sorry, but in my Chrome ( Version 81.0.4044.122 (Official Build) (64-bit) ) is DOES matter.
Shift+Right click gives the context menu kind of as in the picture above, as supposed to.
Shift+Left click gives the delete value popup.
mastadook
Ha Ha Ha LOL
When I try this on "Week" View it did not work, no matter what I try and how.
But on Day and Month and Year, yes, it works.
So now I would say, we both are right
Thank you for your help
rdas
- Domoticz version: 2021.1
Thanks for the info, my smart energy meter was replaced, and even though I shut down domoticz before, it had a huge spike in usage/return value that day.
Deleted the datapoint in "last 7 days" and "usage last month" by Shift+Left click in Google Chrome.
Domoticz 2021.1 on PI
