Aeotec Multisensor 6 Hum not working right
Posted: Sunday 26 April 2020 22:14
I have a Aeotec Multisensor 6 that worked fine for about a year. I could really see the humidity go up when I take a shower(to maybe 90%). But for a while now the humidity doesn't respond as I was used to (all other values are fine). I think after a powerfailure or maybe the 2020.1 update (they were right after each other).
Now my graph goes up and down, but it seems it's slower. The graph has a new value every 5 minutes but even when the shower is on for 10 minutes the value didn't go up. Also the trigger in my script doesn't work anymore to switch on the fan at >70% humidity.
I checked the parameters:
42. Humidity Reporting Threshold: set to 3% so it should send a report regugarly when starting the shower.
51. Set the upper limit value of humidity sensor: is its default 60, I don't think this will change anything?
101. Group 1 Reports: set to 241, so all values should trigger a report including humidity
I allready exchanged it with a new one, but this gives the same problem. So it seems to by domoticz or openzwave.
Any ideas?
Best regards,
Wouter Lettinga
Any ideas?
Best regards,
Wouter Lettinga
