Dashticz Graphs - customHeader with other device data Topic is solved
clinkadink
Post by clinkadink »
Update the customHeader parameter allowing use of other device data.
https://www.domoticz.com/forum/viewtopi ... 77#p244511
dorenberg
Domoticz version: 4.10982
Re: Dashticz Graphs - customHeader with other device data
Post by dorenberg »
also interested in this.
clinkadink
This feature is now available in the beta version.
renerene
Post by renerene »
clinkadink wrote: Saturday 06 June 2020 23:32 This feature is now available in the beta version.
Please explain. Is it hard programmed for power meter only?
Would be great to minimalise / modify other headers to. My temp multigraph header needs to be wide because of bad line break from header.
clinkadink
renerene wrote: Sunday 07 June 2020 10:19
Please explain. Is it hard programmed only for power meter?
Sure, customHeader now accepts a string, for example:
customHeader: '"Usage: " + devices[6].Usage + "Delivery: " + devices[6].CurrentDeliv'
https://dashticz.readthedocs.io/en/beta ... stomheader
renerene
Post by renerene »
Great!
.Usage method is not working for my gas P1 meter, resulting in "undefined". How to get a list of possible values per device?
additional idea: show daily min / max temperature in header
clinkadink
You can get the device information using this:
http://_DOM_IP_PORT_/json.htm?type=devices&rid=_IDX_
Further info, here:
https://www.domoticz.com/wiki/Domoticz_API/JSON_URL's
renerene
Post by renerene »
