Prevent runtime errors.
Posted: Sunday 26 April 2020 13:04
by Hesitated
I've been working with customEvents and it is helpfull to reduce (duplicate) code in other scripts, so they will be easier to maintain.
E.g.:
local up = "Up"
local down = "Down"
customEvents = {
'BedieningRolluiken'
logging =
level = domoticz.LOG_ERROR,
marker = "Bediening rolluiken"
execute = function(dz, item)
local function rolluikOpen(rolluik)
if rolluik ~= nil then
dz.log('Rolluik omhoog: ' .. rolluik.name, dz.LOG_DEBUG)
rolluik.switchOff()
local function rolluikDicht(rolluik)
dz.log('Rolluik omlaag: ' .. rolluik.name, dz.LOG_DEBUG)
rolluik.switchOn()
local json = dz.utils.fromJSON(item.data)
local command = json[1]
if command ~= up and command ~= down then
return
local devices = json[2]
local rolluiken = dz.devices().filter(devices)
dz.log('#rolluiken: ' .. tostring(#rolluiken), dz.LOG_DEBUG)
if command == up then
dz.log('Command was "Up"', dz.LOG_DEBUG)
rolluiken.forEach(function(rolluik)
end)
elseif command == down then
dz.log('Command was "Down"', dz.LOG_DEBUG)
end)
Which will be triggered by other scripts containing:
local args = {
"Down",
idsRolluiken
dz.emitEvent('BedieningRolluiken', args)
But the main script could fail when the passed arguments are not in the expected format.
E.g.:
could fail if item.data is not (proper) json
Or:
could fail if devices are not found.
How do I prevent these runtime errors? (
pcall can't be used here)
Re: Prevent runtime errors.
Posted: Sunday 26 April 2020 13:56
by boum
Why would pcall couldn't be called there? What behavior do you expect?
You can protect against runtime error either piecemeal or on the whole custom event script.
For the two places you shown, it would be:
local ok, json = pcall(dz.utils.fromJSON, item.data)
if not ok then
-- handle error
return
and
-- use anonymous function, dz.devices() is a table
local ok, rolluiken = pcall(function() return dz.devices().filter(devices) end)
if not ok then
-- handle device not found
return
and for the custom script, you just wrap your whole execute function in a local function and pcall it:
customEvents = { 'BedieningRolluiken' }
local checkExecute = function(dz, item)
local function rolluikOpen(rolluik) [...]
-- protected call
local ok = pcall(checkExecute, dz, item)
if not ok then
dz.log(...)
Posted: Sunday 26 April 2020 14:08
by boum
I checked and you cannot use pcall on callable tables. I'll update the example above for dz.devices.
Posted: Sunday 26 April 2020 14:22
by Hesitated
boum wrote: Sunday 26 April 2020 13:56
I think my knowledge of lua is still far too limited...
Ah, I did not know that I could put json as the second variable.
This one I should have known, but didn't think of it.
Posted: Sunday 26 April 2020 17:39
by waaren
Hesitated wrote: Sunday 26 April 2020 13:04
E.g.:
If item.data is not in the right JSON format you will get an error message but the script will not fail. Item.data will be nil and that is something that can be handled in your script logic.
Posted: Sunday 26 April 2020 17:57
by Hesitated
waaren wrote: Sunday 26 April 2020 17:39
Unfortunately not always.
With this url you're right!
https://domoticz/json.htm?type=command¶m=customevent&event=BedieningRolluiken&data=ok
But if you use this url:
https://domoticz/json.htm?type=command¶m=customevent&event=BedieningRolluiken&data=[%22Up%22,{}]
you'll get:
2020-04-26 17:41:54.697 Error: dzVents: Error: (3.0.1) Bediening rolluiken: Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:808: expected string argument to JSON:decode(), got table
2020-04-26 17:41:54.697 Error: dzVents: Error: (3.0.1) Bediening rolluiken: item.data is not jsontable: 0x728f4468
Re: Prevent runtime errors. [Solved]
Posted: Sunday 26 April 2020 19:10
by waaren
Hesitated wrote: Sunday 26 April 2020 17:57
you'll get:
Yes you can get an Error message but the script will continue (at least it does on my systems (dzVents 3.0.2)
Let me have a look if I can add the isJSON attribute to item in customEvents triggers to help catching errors.
If I use
/json.htm?type=command¶m=customevent&event=faultyJSON&data=[%22Up%22,{}]
and this test script
return
on =
customEvents =
'faultyJSON', -- just an example to trigger the request
-- /json.htm?type=command¶m=customevent&event=faultyJSON&data=[%22Up%22,{}]
lodash = dz.utils._
for i=1, 10 do
dz.log('although you will see an error. The script is still executing here', dz.LOG_FORCE)
dz.log('ítem is: ' .. lodash.str(item), dz.LOG_FORCE)
dz.log('item.data: ' .. lodash.str(item.data), dz.LOG_FORCE)
The log shows:
- Spoiler: show
2020-04-26 19:03:24.612 Status: dzVents: Info: Handling Domoticz custom event for: "faultyJSON"
2020-04-26 19:03:24.613 Status: dzVents: Info: ------ Start internal script: dz JSON reader: Custom event: "faultyJSON"
2020-04-26 19:03:24.613 Status: dzVents: !Info: although you will see an error. The script is still executing here
2020-04-26 19:03:24.613 Status: dzVents: !Info: ítem is: {["type"]="customEvent", ["isSystem"]=false, ["isDevice"]=false, ["status"]="info", ["isTimer"]=false, ["data"]={"Up", {}}, ["isHardware"]=false, ["isHTTPResponse"]=false, ["isCustomEvent"]=true, ["isSecurity"]=false, ["trigger"]="faultyJSON", ["isGroup"]=false, ["isVariable"]=false, ["message"]="", ["isScene"]=false}
2020-04-26 19:03:24.613 Status: dzVents: !Info: item.data: {"Up", {}}
2020-04-26 19:03:24.613 Status: dzVents: Info: ------ Finished dz JSON reader
Posted: Sunday 26 April 2020 22:16
by Hesitated
waaren wrote: Sunday 26 April 2020 19:10
Just updated to 20202.2, to be sure...
I'll feel sighted blind, but eventually solved the mistery:
local lodash = dz.utils._
if json == nil then
dz.log('item.data is not json: ' .. lodash.str(item.data), dz.LOG_FORCE)
return
is now looging:
2020-04-26 22:04:50.204 Status: dzVents: Info: Bediening rolluiken: ------ Start internal script: BedieningRolluiken: Custom event: "BedieningRolluiken"
2020-04-26 22:04:50.204 Status: dzVents: !Info: Bediening rolluiken: item.data is not json: {"Up", {}}
2020-04-26 22:04:50.204 Status: dzVents: Info: Bediening rolluiken: ------ Finished BedieningRolluiken
2020-04-26 22:04:50.204 Error: dzVents: Error: (3.0.2) Bediening rolluiken: Error parsing json to LUA table: /home/pi/domoticz/scripts/dzVents/../lua/JSON.lua:808: expected string argument to JSON:decode(), got table
I'm probably confused by the fact that the error message is shown after the last line of the script.
The function
dz.utils._.str() is very usefull, thanxs!
