Time calculating to check temp sensor active
Posted: Saturday 25 April 2020 23:36
by Tukker
I have a thermostat script which uses a temp sensor.
2 days ago the battery of the temp sensor was empty and coming home the thermostat script had fired up the boiler and the temperature had risen far above normal.
Now I want to switch the heating off when no valid temperature is received, in other words, when there is too much a time difference between actual time and LastUpdate
Output for LastUpdate:
LastUpdate	"2020-04-25 22:52:40"
On the other hand I have
(now.strftime("%Y-%m-%d %H:%M:%S")
I want to activate some kind of system-alive-check either in python or in dzVents.
I'm not able to find the proper calculating trick in python nor am I able to create such a thing in dzVents.
Can someone help me with the code.
Re: Time calculating to check temp sensor active
Posted: Sunday 26 April 2020 7:39
by waaren
HvdW wrote: Saturday 25 April 2020 23:36 Now I want to switch the heating off when no valid temperature is received, in other words, when there is too much a time difference between actual time and LastUpdate
.. nor am I able to create such a thing in dzVents.
in dzVents the code snippet to do this could look like.
local mySensor = domoticz.devices('temperature sensor')
local lastUpdated = mySensor.lastUpdate.minutesAgo
if lastUpdated > 15 then
   domoticz.log('Last update for '  .. mySensor.name .. 'was ' .. lastUpdated .. ' minutes ago. Switching off heating system', domoticz.LOG_ERROR )
   -- more code to switch off heating
Posted: Sunday 26 April 2020 12:59
by Tukker
Thanks @waaren
So in fact it's a System_Alive_Check where only
device.state == 'Off' and
is omitted
-- this script can be used in conjunction with the System-alive checker plug-in.
-- the plugin pings a list of devices and creates switches for these devices
-- the reason for this script is to not treat devices as dead immediately after they
-- do not respond. More often than not, the second ping atempt does work. So only
-- if the device has been not responding for a while AFTER it is been presumed dead
-- then this script will notify you
-- put the names of these switches in the devicesToCheck list
-- you may have to tweak the THRESHOLD depending on the check interval
local THRESHOLD = 120 -- minutes
local devicesToCheck =
            'TFA1',
            'TFA2',
            'Oregon',
return
    on =
        devices = devicesToCheck,
        timer =
            'every other hour',
    data =
        notified = { initial = {} },
    logging =
        level = domoticz.LOG_ERROR, -- change from LOG_DEBUG to LOG_ERROR when script executes without problems
        marker = 'notify',
    execute = function(dz, item)
        if item.isTimer then
            for index, deviceName in ipairs(devicesToCheck) do
                local device = dz.devices(deviceName)
                --dz.notify('notifyer achter de eerste if.',dz.PRIORITY_HIGH)
                dz.log('device name  ' .. device.name, dz.LOG_DEBUG)
                dz.log('device state ' .. device.state, dz.LOG_DEBUG)
                dz.log('device lastUpdate ' .. device.lastUpdate.minutesAgo, dz.LOG_DEBUG)
                dz.log('device notified ' .. tostring(dz.data.notified[deviceName]), dz.LOG_DEBUG)
                if device.lastUpdate.minutesAgo >= THRESHOLD and dz.data.notified[deviceName] ~= true  then
                    --dz.notify('notifyer achter de tweede if.',dz.PRIORITY_HIGH)
                    dz.log('Idle device ' .. deviceName, dz.LOG_DEBUG)
                    dz.notify('notifyer', deviceName .. ' is not responding anymore.',dz.PRIORITY_HIGH)
                    dz.data.notified[deviceName] = true
            dz.data.notified[item.name] = false
Can you explain me how come it displays temp-sensors every 30 seconds while it does not in the original System_Alive_Checker.
2020-04-26 12:52:41.579 Status: dzVents: Info: Handling events for: "TFA1", value: "20.4;49;1"
2020-04-26 12:52:42.031 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:52:46.306 (RFXCOM) Temp + Humidity (TFA2)
2020-04-26 12:52:46.451 Status: dzVents: Info: Handling events for: "TFA2", value: "20.4;47;1"
2020-04-26 12:52:52.023 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:53:02.029 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:53:12.036 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:53:22.026 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:53:24.437 (RFXCOM) Temp + Humidity (TFA1)
2020-04-26 12:53:24.586 Status: dzVents: Info: Handling events for: "TFA1", value: "20.4;49;1"
2020-04-26 12:53:31.310 (RFXCOM) Temp + Humidity (TFA2)
2020-04-26 12:53:31.433 Status: dzVents: Info: Handling events for: "TFA2", value: "20.4;47;1"
2020-04-26 12:53:32.028 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:53:40.991 (Ranninkstraat 52) Temp + Humidity + Baro (Ranninkstraat)
2020-04-26 12:53:40.994 (Ranninkstraat 52) Wind (Unknown)
2020-04-26 12:53:40.998 (Ranninkstraat 52) Rain (Unknown)
2020-04-26 12:53:42.038 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:53:52.044 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:53:56.687 (RFXCOM) Temp (Oregon)
2020-04-26 12:53:56.839 Status: dzVents: Info: Handling events for: "Oregon", value: "20.2"
2020-04-26 12:54:02.035 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:54:07.443 (RFXCOM) Temp + Humidity (TFA1)
2020-04-26 12:54:07.562 Status: dzVents: Info: Handling events for: "TFA1", value: "20.4;49;1"
2020-04-26 12:54:12.041 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:54:16.313 (RFXCOM) Temp + Humidity (TFA2)
2020-04-26 12:54:16.467 Status: dzVents: Info: Handling events for: "TFA2", value: "20.4;47;1"
2020-04-26 12:54:22.050 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:54:27.930 (RFXCOM) Temp (Oregon)
2020-04-26 12:54:28.066 Status: dzVents: Info: Handling events for: "Oregon", value: "20.2"
2020-04-26 12:54:32.039 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:54:42.045 (Slimme meter) P1 Smart Meter (Stroom)
2020-04-26 12:54:50.435 (RFXCOM) Temp + Humidity (TFA1)
2020-04-26 12:54:50.586 Status: dzVents: Info: Handling events for: "TFA1", value: "20.4;49;1"
2020-04-26 12:54:52.052 (Slimme meter) P1 Smart Meter (Stroom)
Is that because this
is omitted?
I have found this one as well:
local devicesToCheck = {
	['TFA1'] = 80, -- threshold in seconds
	['TFA2'] = 90,
	['Oregon'] = 90
	active = true,
	on = { timer = { 'every 3 minutes' } },
	data = { notified = { initial = {} } },
	execute = function(dz)
		local notified = dz.data.notified -- short reference
		local toCheck = devicesToCheck
		for deviceName, threshold in pairs(toCheck) do
			local lastUpdate = dz.devices(deviceName).lastUpdate.secondsAgo
			if (lastUpdate > threshold and notified[deviceName] == nil) then
				dz.log(deviceName .. 'is inactive for ' .. lastUpdate .. 's. Threshold=' .. threshold, dz.LOG_ERROR)
				notified[deviceName] = lastUpdate -- mark as notified
				notified[deviceName] = nil -- remove from notified list
Which one is more elegant in the way that it asks less resources from domoticz/rasperrypi.
Extra question: Can the system_alive_check be adapted in a way that it checks all domoticz connected devices (WiFi and 433/866 MHz) in one loop for being up and running?
