itsbvka wrote: Friday 08 May 2020 14:17
Thank you very much for your work.
I'm trying to set it up with a Solax X3, Since you tested with an X1 I was hoping this would work too, all devices register when the hardware is added but all values stay on 0
it seems to start with an error and then connect using the V1 method but then aborts.
2020-05-08 14:07:28.420 Error: (Solax) onStart:
2020-05-08 14:07:28.420 Error: (Solax) if parameters mode 6: 16
2020-05-08 14:07:28.420 Error: (Solax) DumpConfigToLog
2020-05-08 14:07:29.178 (Solax) Queued asynchronous read aborted (192.168.2.25:80), [2] End of file.
2020-05-08 14:07:29.225 (Solax) Disconnect event received for '192.168.2.25:80'.
2020-05-08 14:07:29.226 (Solax) onDisconnect called for connection to: 192.168.2.25:80
2020-05-08 14:07:39.449 (Solax) Transport set to: 'TCP/IP', 192.168.2.25:80.
2020-05-08 14:07:39.452 (Solax) Connect directive received, action initiated successfully.
2020-05-08 14:07:39.508 (Solax) Sending 204 bytes of data
2020-05-08 14:07:40.211 (Solax) Queued asynchronous read aborted (192.168.2.25:80), [2] End of file.
2020-05-08 14:07:40.218 (Solax) Disconnect event received for '192.168.2.25:80'.
2020-05-08 14:07:40.219 (Solax) onDisconnect called for connection to: 192.168.2.25:80
2020-05-08 14:07:41.423 (Solax) Transport set to: 'TCP/IP', 192.168.2.25:80.
2020-05-08 14:07:41.424 (Solax) Connect directive received, action initiated successfully.
2020-05-08 14:07:41.475 (Solax) Sending 204 bytes of data
2020-05-08 14:07:42.181 (Solax) Queued asynchronous read aborted (192.168.2.25:80), [2] End of file.
2020-05-08 14:07:42.227 (Solax) Disconnect event received for '192.168.2.25:80'.
2020-05-08 14:07:42.228 (Solax) onDisconnect called for connection to: 192.168.2.25:80
2020-05-08 14:07:43.431 (Solax) Transport set to: 'TCP/IP', 192.168.2.25:80.
2020-05-08 14:07:43.432 (Solax) Connect directive received, action initiated successfully.
2020-05-08 14:07:43.483 (Solax) Sending 204 bytes of data
2020-05-08 14:07:44.186 (Solax) Queued asynchronous read aborted (192.168.2.25:80), [2] End of file.
2020-05-08 14:07:44.236 (Solax) Disconnect event received for '192.168.2.25:80'.
2020-05-08 14:07:44.236 (Solax) onDisconnect called for connection to: 192.168.2.25:80
2020-05-08 14:07:45.440 (Solax) Transport set to: 'TCP/IP', 192.168.2.25:80.
2020-05-08 14:07:45.446 (Solax) Connect directive received, action initiated successfully.
2020-05-08 14:07:45.498 (Solax) Sending 204 bytes of data
2020-05-08 14:07:46.201 (Solax) Queued asynchronous read aborted (192.168.2.25:80), [2] End of file.
2020-05-08 14:07:46.250 (Solax) Disconnect event received for '192.168.2.25:80'.
2020-05-08 14:07:46.251 (Solax) onDisconnect called for connection to: 192.168.2.25:80
2020-05-08 14:07:47.455 (Solax) Transport set to: 'TCP/IP', 192.168.2.25:80.
2020-05-08 14:07:47.456 (Solax) Connect directive received, action initiated successfully.
2020-05-08 14:07:47.506 (Solax) Sending 204 bytes of data
2020-05-08 14:07:48.218 (Solax) Queued asynchronous read aborted (192.168.2.25:80), [2] End of file.
2020-05-08 14:07:48.259 (Solax) Disconnect event received for '192.168.2.25:80'.
2020-05-08 14:07:48.260 (Solax) onDisconnect called for connection to: 192.168.2.25:80
