Shell script not effective from switch. Why?
Posted: Friday 24 April 2020 18:00
by bxlouis
Hi y'all!
I am trying to make a switch wake-up and sleep my Mac.
In order to make it sleep, I have done the following:
1. Install "expect" package on my RPi.
2. Created a script test.sh in domoticz/scripts/ (cf. below)
3. Ran chmod +x test.sh
4. Created a virtual switch and mentioned "script://test.sh" in the "Off action" field.
When turning the switch off, I see in the log that the script was triggered.
Status: Executing script: /home/pi/domoticz/scripts/test.sh
But nothing happens and my mac does not go to sleep.
However, if I ssh to my RPi and manually execute the script, my Mac goes to sleep instantly.
I can't figure out why the script does not work when called from the Domoticz switch.
Can someone help me understand and maybe fix my issue ?
test.sh:
#!/usr/bin/expect -f
spawn ssh MAC_USER@MAC_IP "pmset sleepnow"
expect "assword:"
send "MAC_USER_PASSWORD\r"
interact
Re: Shell script not effective from switch. Why?
Posted: Friday 24 April 2020 22:00
by FireWizard
@bxlouis
First of all, I think there is a typo in your script:
expect "assword:"
Shouldn't that be password?
Very recently there was another issue on this forum, discussing a similar problem.
I suggest you read that first and if possible make some tests.
See: https://www.domoticz.com/forum/viewtopi ... 6&start=20
This was a "brain breaker", but finally also a solution.
Posted: Saturday 25 April 2020 0:43
by bxlouis
Hi @FireWizard,
Thank you for your reply. I will take the time to read the thread carefully as after my first reading, I don't quite understand how they solved the issue!
No typo in the script, it works fine like that. I guess the author of the script removed the "p" that to avoid any mistake related to the shell displaying "password:" or "Password:".
Posted: Saturday 25 April 2020 2:13
by bxlouis
After searching for a while I decided to go for another solution which works well.
The issue is not solved but I got what I wanted to achieve.
If anyone is interested, this allows to setup a switch which will wake up and put your Mac to sleep.
It is rather quick and dirty and I am sure there are better ways to script this, but I was not able to find an efficient way to do this on the Domoticz forum.
Hope it helps anyone who has been trying to wake and put his mac to sleep out there.
1. ssh to your Raspberry pi
2. Run "sudo apt-get install sshpass"
3. In Domoticz, create a dummy switch called "iMac" (or whatever you want)
4. Create a Lua script with Trigger set to "Device"
5. Paste the script below and edit the values to match your config
if (devicechanged['iMac'] == "On") then
    print("Waking up iMac...")
    os.execute('/usr/sbin/etherwake YOURMACMACADDRESS')
    os.execute("sshpass -p 'YOURMACUSERPASSWORD' ssh -o StrictHostKeyChecking=no YOURMACUSER@YOURMACIP caffeinate -u -t 2")
elseif (devicechanged['iMac'] == "Off") then
    print("Putting iMac to sleep...")
    os.execute("sshpass -p 'YOURMACUSERPASSWORD' ssh -o StrictHostKeyChecking=no YOURMACUSER@YOURMACIP pmset sleepnow")
Posted: Saturday 25 April 2020 8:32
by gizmocuz
To wake-up a computer you could also use the build in WOL (Wakeup on Lan) hardware type
This does not let it sleep... But as i think you are going to work on your mac after waking it up, you could issue a sleep command,
or just configure it to sleep after 30 minutes on no activity ?
Posted: Saturday 25 April 2020 9:30
by FireWizard
@bxlouis
If you are satisfied with your solution, I leave it from my side.
Posted: Saturday 25 April 2020 9:42
by bxlouis
Hi @Gizmocuz,
I have been using the WOL hardware for the last few years. However I have never found a right solution to put a Mac to sleep immediately from a switch on the forum.
At the beginning (cf. first message) I tried to simply add the sleep command to the OFF action but I ran into the issue I described.
I thought it was because I was using the switch provided by the WOL hardware so I tried with a virtual switch but got the same issue so I opened this thread.
I still don’t understand why my ssh script is not working with the ON/OFF actions from the switch while it works perfectly when executed from the terminal. I tried several things, change ownership to root and back to pi, moving the script to /home/pi/ instead of ~/domoticz/scripts/, use relative and absolute path, set different rights to the script but without any success unfortunately.
