Blockly Qubino shutter sunscreen/Blinds
AllesVanZelf
Domoticz version: 12467
Post by AllesVanZelf »
Domoticz 2020.1 - 11953
I have a problem with my Qubino shutter in a Blockly. See below Blockly image.
Now the shutter/sunscreen opens at the right time, sun power > 500. But the screen does not close at the specified time. I assume that:
[Zonwering Keuken Shutter] = Open is not the right value. But [Zonwering Keuken Shutter] (is Not) Level 100% Or (Is Not) Closed, doesn't work either.
Anyone with a Qubino shutter nows how to handle this?
Edit: with more specific information about what is working and what not.
AllesVanZelf
Re: Blockly Qubino shutter sunscreen/Blinds
No one uses the Qubino shutter in a script?
Jan Jansen
Domoticz version: Stable
Post by Jan Jansen »
try time>09:30 or time <16:00 and zonwering=closed and BR mogelijk regen=off and BR regent het? (not in one and block)
AllesVanZelf
Thank you Jan, for replying.
That Open part is working well.
It is the closing part that give me trouble.
[Else If] - [Zonwering shutter] = [Open] AND
( [Time => 16:00] OR BR [Wind > 5] OR [Regen = ON] OR [Regen > 0] )
I think it is the [Zonwering shutter] = [Open] part that is never triggered.
If I enter: [Zonwering shutter] < [Level % 100] I get:
Error: EventSystem: Lua script error (Blockly), Name: Zonnescherm_2 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: attempt to compare string with number
AllesVanZelf
I think this is a bug in the way that Qubino shutter is handled.
If the sunscreen is closed it is reported 100% on the switch in domoticz and has a status: closed. That is oke with me.
If I open the sunscreen to percentage 83% (by hand on the real switch or in Domoticz). It is not reported "open", but in the log there is a line: "Set Level: 83 %".
But I can also not use a statement like > or < then [level % 100]. Because then I get the error message: "attempt to compare string with number".
That is a bug or not?
AllesVanZelf
I did experiment a little and somehow I managed to get a step further.
If I set the closing part - else if part to [=not] [closed] and then: set Zonwering = level % 100, the sunscreen closes!! But 1% a time. So If the sunscreen was set to 30%, it will close as 31%, 32%, 33% etc. That makes it very slow.
Why is this?
AllesVanZelf
Since no-one could help me with this issue that this Qubino shutter does not report a [open] status and Level % is not accepted as a status,
I bypass this by installing a dummy switch that will open or close by blockly.
And for the case that the switch is pushed by hand, I created a dummy blockly to switch the dummy switch. Hope this will work.
But in my opinion: a statement like: " If Qubino shutter is [open] " should also work, but it isn't.
ps. Same problem with a Qubino dimmer, that is never ON, but is Off or set to level. But never [On].
A fix would be very helpfull.
AllesVanZelf
The Blockly in last post was working, but also 1% by 1% closing. Too complicated.
I now do it this way, but without dummy switch:
Same result. The sunscreen closes 1% by 1% till closed at 100%.
How do I close this screen in one run?
I did some testing. Disabled this above script and created a simple script with a dummy. Like this:
If I set the dummy switch on, the sunscreen opens to 96%. If I set the dummy switch to off, the sunscreen closes to 100%, but still 1% by 1% till 100% = closed.
Again, how do I close it in one run?
