Need help :Virtual blind percentage for eg. Velux
Posted: Wednesday 22 April 2020 13:55
by sailmich
Hello, I have this simply script to open and close my roof windows.
- Spoiler: show
--[[This script is for a roof window.
J_down = EnOcean switch blind down
Velux = Dummy Blind
Vrunter = Fibaro FGS222 switch first output
J_up = EnOcean switch blind up
Vhoch = Fibaro FGS222 switch second output
The Fibaro switch is connected to VELUX KLF 050 WW INTEGRA® Schalter-Interface
One output of Fibaro switch is for close blinds and the other open blinds
Stop blind by using again same output as before]]
devices = {'J_down', 'J_up'}
execute = function(dz, device)
if dz.devices('J_down').state == 'On' and dz.devices('Velux').state == 'Open' then
dz.devices('Vrunter').switchOn().forSec(40)
dz.devices('Velux').switchOn()
elseif dz.devices('J_down').state == 'On' and dz.devices('Velux').state == 'Closed' then
domoticz.log('Jalousie is already closed')
if dz.devices('J_up').state == 'On' and dz.devices('Velux').state == 'Closed' then
dz.devices('Vhoch').switchOn().forSec(40)
dz.devices('Velux').switchOff()
elseif dz.devices('J_up').state == 'On' and dz.devices('Velux').state == 'Open' then
domoticz.log('Jalousie is already open')
This working as it should. Now I would like to use a virtual blind percentage switch to close or open the blinds. I searched the forum and found some solutions but to complicated for me to adapt to my needs. I need a variable for the percentage. I know the time for 1% up is 0.4 seconds and time for 1% down is 0.3 seconds. Compare old percentage with new percentage multiply with speed for 1% should deliver the time between the start and stop signal.
I already read the wiki about dzvents but I can't get it together. Lack of language and skill level.
Any Help appreciated
Re: Need help :Virtual blind percentage for eg. Velux
Posted: Wednesday 22 April 2020 15:38
by waaren
sailmich wrote: Wednesday 22 April 2020 13:55
I will try to come up with something but the problem with creating such a script is that the behavior of these blind percentage switches is not as expected. From percentage X to percentage Y is not very complicated but if you set the percentage to 0 the device will only show 'Off' and keeps the old percentage and the other way around if you set it to 100% it will show 'On' and keeps the old percentage.
So it might take some iterations before we will have a working script (if at all
Posted: Wednesday 22 April 2020 16:23
by sailmich
THX in advance!
Posted: Thursday 23 April 2020 12:52
by waaren
sailmich wrote: Wednesday 22 April 2020 16:23
THX in advance!
Can you have a look at this and revert with your findings?
J_down = EnOcean switch blind down // Controller for Switch blind completely down
J_up = EnOcean switch blind up // Controller Switch blind completely up
Velux = Dummy Blind // Controller to set blind percentage and follows when controlled by J_down or J_up
Vrunter = Fibaro FGS222 switch // Actuator
Vhoch = Fibaro FGS222 switch // Actuator
.The time for 1% up is 0.4 seconds and time for 1% down is 0.3 seconds.
return
on =
devices =
'J_down',
'J_up',
'Velux',
logging =
level = domoticz.LOG_DEBUG, -- Change to domoticz.LOG_ERROR when working as expected
marker = 'blindPercentages',
data =
level = { initial = 0 },
execute = function(dz, item)
local Jdown = dz.devices('J_down')
local Jup = dz.devices('J_up')
local Vrunter =dz.devices('Vrunter')
local Vhoch = dz.devices('Vhoch')
local velux = dz.devices('Velux')
local function createSomeLogging(dv)
dz.log(dv.name .. ': -->> device Type: ' .. ( dv.deviceType or "-") .. ', device switchType: ' .. ( dv.switchType or "-") ..
', state: ' .. ( dv.state or "-") .. ', nValue ' .. (dv.nValue or "-") ..
', dv.level: ' .. ( dv.level or "-") ,dz.LOG_DEBUG)
for _, device in pairs({Jdown, velux , Jup, Vrunter, Vhoch, velux}) do
createSomeLogging(device)
dz.log('level in data: ' .. dz.data.level,dz.LOG_DEBUG )
local function gotoLevel(newLevel, remote)
local upSpeed = 0.3
local downSpeed = 0.4
if dz.data.level < newLevel then
Vhoch.cancelQueuedCommands()
Vhoch.switchOn()
if remote then
local delay = upSpeed
for intLevel = dz.data.level, newLevel do
velux.setLevel(intLevel).afterSec(math.floor(delay)).silent()
delay = delay + upSpeed
Vhoch.switchOff().afterSec(( newLevel - dz.data.level) * upSpeed ).silent()
elseif newLevel < dz.data.level then
Vrunter.cancelQueuedCommands()
Vrunter.switchOn()
if remote then
local delay = downSpeed
for intLevel = dz.data.level, newLevel, -1 do
delay = delay + downSpeed
Vrunter.switchOff().afterSec(( dz.data.level - newLevel) * downSpeed ).silent()
dz.data.level = newLevel
-- Main..
if item == Jdown and Jdown.state == 'On' and velux.level > 1 then
gotoLevel(0, true)
elseif item == Jdown and Jdown.state == 'On' and velux.state == 'Open' then
dz.log('Jalousie is already closed')
elseif item == Jup and Jup.state == 'On' and velux.level < 99 then
gotoLevel(100, true)
elseif item == Jup and Jup.state == 'On' and velux.state == 'Closed' then
dz.log('Jalousie is already open')
elseif item == velux then
gotoLevel(velux.level)
Posted: Thursday 23 April 2020 13:56
by sailmich
I already tried your script. What is the best way to debug? Or can you worked with my trials?
Open to closed Vrunter = 40s
closed to open Vhoch = 30s
closed to 48% Vhoch on for 14s -- should be Vrunter
48% to 82% Vhoch on for 10s -- should be Vrunter
82% to 93% Vhoch on for 3s -- should be Vrunter
93% to 39% Vrunter on for 22s -- should be Vhoch
39% to open = nothing happen
12% to closed = nothing happen
I need also always 2 times the signal on. First is for start second for stop. For closed and open it doesn't matter because there is an electronic inside the blind.
Posted: Thursday 23 April 2020 15:54
by waaren
sailmich wrote: Thursday 23 April 2020 13:56
The best way to debug is to write down the sequence of your actions combined with what you see in the log and in the GUI. I reverted Vhogh and Vrunter and changed the switchOff to switchOn. See below
Please also try to understand what happens in the code and make your own modifications as you see fit.
return
on =
devices =
'J_down',
'J_up',
'Velux',
logging =
data =
local upSpeed = 0.3
Vrunter.switchOn().silent()
if remote then
Vrunter.switchOn().afterSec(( newLevel - dz.data.level) * upSpeed ).silent()
Vhoch.switchOn().silent()
if remote then
Vhoch.switchOn().afterSec(( dz.data.level - newLevel) * downSpeed ).silent()
-- Main..
gotoLevel(0, true)
Posted: Friday 24 April 2020 16:20
by sailmich
@waaren
I add some code and did some small changes. I understand the part for moving the blinds with dummy switch and it's working but needs double click for open or closed. Directions are right and fits to Vrunter and Vhoch.
The harder part is to understand and change the remote part. General problem is that J_up and J_down are toggle switches but act like on/off. I just need the on signals to switch Vrunter and Vhoch. e.g. J_up on start and push J_up on again (J_up send on to Vhoch and another on by pushing again.) whenever I want, should start the blinds moving up and stop the blinds before they reach the physical limit switch. Now J_up stays always on. Any suggestions? And thanks again for your help! It's looking amazing when the dummy blind changing the position
Posted: Friday 24 April 2020 20:27
by waaren
sailmich wrote: Friday 24 April 2020 16:20
How do J_up and J_down behave if you change them to push On buttons ? (edit the devices on the switches tab)
Posted: Friday 24 April 2020 21:27
by sailmich
On the remote server they still have 'on/off/GroupOff'. I changed them also on main domoticz and I got just 'on'.
As you can see MainJ_up.png got two times on signal, because I toggled the remote switch. But Vhoch didn't get the second from J_up.
Posted: Friday 24 April 2020 23:09
by waaren
sailmich wrote: Friday 24 April 2020 21:27
In one of the recent Beta's (build 11959) a commit was applied that prevents the log of identical states of switches. Could that be the reason?
Posted: Saturday 25 April 2020 9:57
by sailmich
waaren wrote: Friday 24 April 2020 23:09
I don't thing so. According to the domoticz log the remote process is already finish calculated before the next switch on signal is comming. But the process can't stop.
For better understanding the log for J_down with a second push.
- Spoiler: show
2020-04-25 09:35:54.180 Status: User: Admin initiated a switch command ( 196/J_down/On)
2020-04-25 09:35:54.197 (EnoceanRemote) Lighting 2 (J_down)
2020-04-25 09:35:54.206 Status: Incoming connection from: 192.168.178.54
2020-04-25 09:35:54.322 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-04-25 09:35:54.441 Status: dzVents: Debug: Processing device-adapter for J_down: Switch device adapter
2020-04-25 09:35:54.442 Status: dzVents: Debug: dzVents version: 3.0.2
2020-04-25 09:35:54.442 Status: dzVents: Debug: Event triggers:
2020-04-25 09:35:54.442 Status: dzVents: Debug: - Device: J_down
2020-04-25 09:35:54.492 Status: dzVents: Info: Handling events for: "J_down", value: "On"
2020-04-25 09:35:54.493 Status: dzVents: Info: blindPercentages: ------ Start internal script: Script #1: Device: "J_down (EnoceanRemote)", Index: 196
2020-04-25 09:35:54.499 Status: dzVents: Debug: blindPercentages: Processing device-adapter for J_up: Switch device adapter
2020-04-25 09:35:54.501 Status: dzVents: Debug: blindPercentages: Processing device-adapter for Vrunter: Switch device adapter
2020-04-25 09:35:54.503 Status: dzVents: Debug: blindPercentages: Processing device-adapter for Vhoch: Switch device adapter
2020-04-25 09:35:54.506 Status: dzVents: Debug: blindPercentages: Processing device-adapter for Velux: Switch device adapter
2020-04-25 09:35:54.506 Status: dzVents: Debug: blindPercentages: J_down: -->> device Type: Lighting 2, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:35:54.506 Status: dzVents: Debug: blindPercentages: Velux: -->> device Type: Light/Switch, device switchType: Blinds Percentage, state: Open, nValue 0, dv.level: 0
2020-04-25 09:35:54.506 Status: dzVents: Debug: blindPercentages: J_up: -->> device Type: Lighting 2, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:35:54.507 Status: dzVents: Debug: blindPercentages: Vrunter: -->> device Type: Light/Switch, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:35:54.507 Status: dzVents: Debug: blindPercentages: Vhoch: -->> device Type: Light/Switch, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:35:54.507 Status: dzVents: Debug: blindPercentages: Velux: -->> device Type: Light/Switch, device switchType: Blinds Percentage, state: Open, nValue 0, dv.level: 0
2020-04-25 09:35:54.507 Status: dzVents: Debug: blindPercentages: level in data: 0
2020-04-25 09:35:54.507 Status: dzVents: Debug: blindPercentages: Constructed timed-command: On
2020-04-25 09:35:54.507 Status: dzVents: Debug: blindPercentages: Constructed timed-command: On NOTRIGGER
2020-04-25 09:35:54.508 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 0
2020-04-25 09:35:54.508 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 0 AFTER 0 SECONDS
2020-04-25 09:35:54.508 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 0 AFTER 0 SECONDS NOTRIGGER
2020-04-25 09:35:54.508 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 1
2020-04-25 09:35:54.508 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 1 AFTER 0 SECONDS
2020-04-25 09:35:54.509 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 1 AFTER 0 SECONDS NOTRIGGER
2020-04-25 09:35:54.509 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 2
2020-04-25 09:35:54.509 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 2 AFTER 0 SECONDS
2020-04-25 09:35:54.509 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 2 AFTER 0 SECONDS NOTRIGGER
2020-04-25 09:35:54.509 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 3
2020-04-25 09:35:54.510 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 3 AFTER 1 SECONDS
2020-04-25 09:35:54.510 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 3 AFTER 1 SECONDS NOTRIGGER
2020-04-25 09:35:54.510 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 4
2020-04-25 09:35:54.510 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 4 AFTER 1 SECONDS
2020-04-25 09:35:54.510 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 4 AFTER 1 SECONDS NOTRIGGER
2020-04-25 09:35:54.511 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 5
2020-04-25 09:35:54.511 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 5 AFTER 1 SECONDS
2020-04-25 09:35:54.511 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 5 AFTER 1 SECONDS NOTRIGGER
2020-04-25 09:35:54.511 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 6
2020-04-25 09:35:54.511 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 6 AFTER 2 SECONDS
2020-04-25 09:35:54.512 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 6 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.512 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 7
2020-04-25 09:35:54.512 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 7 AFTER 2 SECONDS
2020-04-25 09:35:54.512 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 7 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.512 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 8
2020-04-25 09:35:54.512 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 8 AFTER 2 SECONDS
2020-04-25 09:35:54.513 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 8 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.513 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 9
2020-04-25 09:35:54.513 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 9 AFTER 2 SECONDS
2020-04-25 09:35:54.513 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 9 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.513 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 10
2020-04-25 09:35:54.514 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 10 AFTER 3 SECONDS
2020-04-25 09:35:54.514 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 10 AFTER 3 SECONDS NOTRIGGER
2020-04-25 09:35:54.514 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 11
2020-04-25 09:35:54.514 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 11 AFTER 3 SECONDS
2020-04-25 09:35:54.515 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 11 AFTER 3 SECONDS NOTRIGGER
2020-04-25 09:35:54.515 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 12
2020-04-25 09:35:54.515 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 12 AFTER 3 SECONDS
2020-04-25 09:35:54.515 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 12 AFTER 3 SECONDS NOTRIGGER
2020-04-25 09:35:54.515 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 13
2020-04-25 09:35:54.516 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 13 AFTER 4 SECONDS
2020-04-25 09:35:54.516 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 13 AFTER 4 SECONDS NOTRIGGER
2020-04-25 09:35:54.516 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 14
2020-04-25 09:35:54.516 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 14 AFTER 4 SECONDS
2020-04-25 09:35:54.516 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 14 AFTER 4 SECONDS NOTRIGGER
2020-04-25 09:35:54.517 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 15
2020-04-25 09:35:54.517 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 15 AFTER 4 SECONDS
2020-04-25 09:35:54.517 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 15 AFTER 4 SECONDS NOTRIGGER
2020-04-25 09:35:54.517 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 16
2020-04-25 09:35:54.517 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 16 AFTER 5 SECONDS
2020-04-25 09:35:54.518 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 16 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.518 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 17
2020-04-25 09:35:54.518 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 17 AFTER 5 SECONDS
2020-04-25 09:35:54.518 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 17 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.518 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 18
2020-04-25 09:35:54.519 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 18 AFTER 5 SECONDS
2020-04-25 09:35:54.519 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 18 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.519 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 19
2020-04-25 09:35:54.519 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 19 AFTER 5 SECONDS
2020-04-25 09:35:54.519 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 19 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.519 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 20
2020-04-25 09:35:54.520 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 20 AFTER 6 SECONDS
2020-04-25 09:35:54.520 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 20 AFTER 6 SECONDS NOTRIGGER
2020-04-25 09:35:54.520 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 21
2020-04-25 09:35:54.520 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 21 AFTER 6 SECONDS
2020-04-25 09:35:54.520 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 21 AFTER 6 SECONDS NOTRIGGER
2020-04-25 09:35:54.521 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 22
2020-04-25 09:35:54.521 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 22 AFTER 6 SECONDS
2020-04-25 09:35:54.521 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 22 AFTER 6 SECONDS NOTRIGGER
2020-04-25 09:35:54.521 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 23
2020-04-25 09:35:54.521 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 23 AFTER 7 SECONDS
2020-04-25 09:35:54.522 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 23 AFTER 7 SECONDS NOTRIGGER
2020-04-25 09:35:54.522 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 24
2020-04-25 09:35:54.522 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 24 AFTER 7 SECONDS
2020-04-25 09:35:54.522 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 24 AFTER 7 SECONDS NOTRIGGER
2020-04-25 09:35:54.522 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 25
2020-04-25 09:35:54.523 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 25 AFTER 7 SECONDS
2020-04-25 09:35:54.523 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 25 AFTER 7 SECONDS NOTRIGGER
2020-04-25 09:35:54.523 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 26
2020-04-25 09:35:54.523 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 26 AFTER 8 SECONDS
2020-04-25 09:35:54.523 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 26 AFTER 8 SECONDS NOTRIGGER
2020-04-25 09:35:54.524 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 27
2020-04-25 09:35:54.524 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 27 AFTER 8 SECONDS
2020-04-25 09:35:54.524 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 27 AFTER 8 SECONDS NOTRIGGER
2020-04-25 09:35:54.524 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 28
2020-04-25 09:35:54.525 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 28 AFTER 8 SECONDS
2020-04-25 09:35:54.525 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 28 AFTER 8 SECONDS NOTRIGGER
2020-04-25 09:35:54.525 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 29
2020-04-25 09:35:54.525 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 29 AFTER 9 SECONDS
2020-04-25 09:35:54.525 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 29 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.525 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 30
2020-04-25 09:35:54.526 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 30 AFTER 9 SECONDS
2020-04-25 09:35:54.526 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 30 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.526 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 31
2020-04-25 09:35:54.526 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 31 AFTER 9 SECONDS
2020-04-25 09:35:54.526 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 31 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.527 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 32
2020-04-25 09:35:54.527 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 32 AFTER 9 SECONDS
2020-04-25 09:35:54.527 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 32 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.527 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 33
2020-04-25 09:35:54.527 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 33 AFTER 10 SECONDS
2020-04-25 09:35:54.527 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 33 AFTER 10 SECONDS NOTRIGGER
2020-04-25 09:35:54.528 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 34
2020-04-25 09:35:54.528 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 34 AFTER 10 SECONDS
2020-04-25 09:35:54.528 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 34 AFTER 10 SECONDS NOTRIGGER
2020-04-25 09:35:54.528 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 35
2020-04-25 09:35:54.529 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 35 AFTER 10 SECONDS
2020-04-25 09:35:54.529 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 35 AFTER 10 SECONDS NOTRIGGER
2020-04-25 09:35:54.529 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 36
2020-04-25 09:35:54.529 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 36 AFTER 11 SECONDS
2020-04-25 09:35:54.529 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 36 AFTER 11 SECONDS NOTRIGGER
2020-04-25 09:35:54.529 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 37
2020-04-25 09:35:54.530 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 37 AFTER 11 SECONDS
2020-04-25 09:35:54.530 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 37 AFTER 11 SECONDS NOTRIGGER
2020-04-25 09:35:54.530 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 38
2020-04-25 09:35:54.530 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 38 AFTER 11 SECONDS
2020-04-25 09:35:54.530 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 38 AFTER 11 SECONDS NOTRIGGER
2020-04-25 09:35:54.531 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 39
2020-04-25 09:35:54.531 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 39 AFTER 12 SECONDS
2020-04-25 09:35:54.531 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 39 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.531 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 40
2020-04-25 09:35:54.531 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 40 AFTER 12 SECONDS
2020-04-25 09:35:54.532 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 40 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.532 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 41
2020-04-25 09:35:54.532 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 41 AFTER 12 SECONDS
2020-04-25 09:35:54.532 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 41 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.532 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 42
2020-04-25 09:35:54.533 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 42 AFTER 12 SECONDS
2020-04-25 09:35:54.533 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 42 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.533 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 43
2020-04-25 09:35:54.533 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 43 AFTER 13 SECONDS
2020-04-25 09:35:54.533 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 43 AFTER 13 SECONDS NOTRIGGER
2020-04-25 09:35:54.534 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 44
2020-04-25 09:35:54.534 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 44 AFTER 13 SECONDS
2020-04-25 09:35:54.534 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 44 AFTER 13 SECONDS NOTRIGGER
2020-04-25 09:35:54.534 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 45
2020-04-25 09:35:54.534 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 45 AFTER 13 SECONDS
2020-04-25 09:35:54.535 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 45 AFTER 13 SECONDS NOTRIGGER
2020-04-25 09:35:54.535 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 46
2020-04-25 09:35:54.535 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 46 AFTER 14 SECONDS
2020-04-25 09:35:54.535 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 46 AFTER 14 SECONDS NOTRIGGER
2020-04-25 09:35:54.535 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 47
2020-04-25 09:35:54.536 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 47 AFTER 14 SECONDS
2020-04-25 09:35:54.536 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 47 AFTER 14 SECONDS NOTRIGGER
2020-04-25 09:35:54.536 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 48
2020-04-25 09:35:54.536 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 48 AFTER 14 SECONDS
2020-04-25 09:35:54.536 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 48 AFTER 14 SECONDS NOTRIGGER
2020-04-25 09:35:54.536 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 49
2020-04-25 09:35:54.537 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 49 AFTER 15 SECONDS
2020-04-25 09:35:54.537 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 49 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.537 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 50
2020-04-25 09:35:54.537 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 50 AFTER 15 SECONDS
2020-04-25 09:35:54.537 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 50 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.538 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 51
2020-04-25 09:35:54.538 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 51 AFTER 15 SECONDS
2020-04-25 09:35:54.538 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 51 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.538 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 52
2020-04-25 09:35:54.538 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 52 AFTER 15 SECONDS
2020-04-25 09:35:54.539 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 52 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.539 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 53
2020-04-25 09:35:54.539 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 53 AFTER 16 SECONDS
2020-04-25 09:35:54.539 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 53 AFTER 16 SECONDS NOTRIGGER
2020-04-25 09:35:54.539 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 54
2020-04-25 09:35:54.540 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 54 AFTER 16 SECONDS
2020-04-25 09:35:54.540 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 54 AFTER 16 SECONDS NOTRIGGER
2020-04-25 09:35:54.540 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 55
2020-04-25 09:35:54.540 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 55 AFTER 16 SECONDS
2020-04-25 09:35:54.540 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 55 AFTER 16 SECONDS NOTRIGGER
2020-04-25 09:35:54.541 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 56
2020-04-25 09:35:54.541 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 56 AFTER 17 SECONDS
2020-04-25 09:35:54.541 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 56 AFTER 17 SECONDS NOTRIGGER
2020-04-25 09:35:54.541 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 57
2020-04-25 09:35:54.542 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 57 AFTER 17 SECONDS
2020-04-25 09:35:54.542 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 57 AFTER 17 SECONDS NOTRIGGER
2020-04-25 09:35:54.542 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 58
2020-04-25 09:35:54.542 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 58 AFTER 17 SECONDS
2020-04-25 09:35:54.542 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 58 AFTER 17 SECONDS NOTRIGGER
2020-04-25 09:35:54.543 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 59
2020-04-25 09:35:54.543 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 59 AFTER 18 SECONDS
2020-04-25 09:35:54.543 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 59 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.543 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 60
2020-04-25 09:35:54.544 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 60 AFTER 18 SECONDS
2020-04-25 09:35:54.544 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 60 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.544 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 61
2020-04-25 09:35:54.545 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 61 AFTER 18 SECONDS
2020-04-25 09:35:54.545 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 61 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.545 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 62
2020-04-25 09:35:54.545 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 62 AFTER 18 SECONDS
2020-04-25 09:35:54.545 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 62 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.546 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 63
2020-04-25 09:35:54.546 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 63 AFTER 19 SECONDS
2020-04-25 09:35:54.546 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 63 AFTER 19 SECONDS NOTRIGGER
2020-04-25 09:35:54.546 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 64
2020-04-25 09:35:54.546 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 64 AFTER 19 SECONDS
2020-04-25 09:35:54.547 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 64 AFTER 19 SECONDS NOTRIGGER
2020-04-25 09:35:54.547 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 65
2020-04-25 09:35:54.547 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 65 AFTER 19 SECONDS
2020-04-25 09:35:54.547 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 65 AFTER 19 SECONDS NOTRIGGER
2020-04-25 09:35:54.547 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 66
2020-04-25 09:35:54.548 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 66 AFTER 20 SECONDS
2020-04-25 09:35:54.548 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 66 AFTER 20 SECONDS NOTRIGGER
2020-04-25 09:35:54.548 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 67
2020-04-25 09:35:54.548 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 67 AFTER 20 SECONDS
2020-04-25 09:35:54.549 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 67 AFTER 20 SECONDS NOTRIGGER
2020-04-25 09:35:54.549 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 68
2020-04-25 09:35:54.549 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 68 AFTER 20 SECONDS
2020-04-25 09:35:54.549 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 68 AFTER 20 SECONDS NOTRIGGER
2020-04-25 09:35:54.549 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 69
2020-04-25 09:35:54.550 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 69 AFTER 21 SECONDS
2020-04-25 09:35:54.550 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 69 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.550 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 70
2020-04-25 09:35:54.550 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 70 AFTER 21 SECONDS
2020-04-25 09:35:54.551 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 70 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.551 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 71
2020-04-25 09:35:54.551 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 71 AFTER 21 SECONDS
2020-04-25 09:35:54.551 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 71 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.551 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 72
2020-04-25 09:35:54.552 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 72 AFTER 21 SECONDS
2020-04-25 09:35:54.552 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 72 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.552 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 73
2020-04-25 09:35:54.552 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 73 AFTER 22 SECONDS
2020-04-25 09:35:54.552 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 73 AFTER 22 SECONDS NOTRIGGER
2020-04-25 09:35:54.553 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 74
2020-04-25 09:35:54.553 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 74 AFTER 22 SECONDS
2020-04-25 09:35:54.553 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 74 AFTER 22 SECONDS NOTRIGGER
2020-04-25 09:35:54.553 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 75
2020-04-25 09:35:54.553 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 75 AFTER 22 SECONDS
2020-04-25 09:35:54.554 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 75 AFTER 22 SECONDS NOTRIGGER
2020-04-25 09:35:54.554 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 76
2020-04-25 09:35:54.554 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 76 AFTER 23 SECONDS
2020-04-25 09:35:54.554 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 76 AFTER 23 SECONDS NOTRIGGER
2020-04-25 09:35:54.555 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 77
2020-04-25 09:35:54.555 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 77 AFTER 23 SECONDS
2020-04-25 09:35:54.555 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 77 AFTER 23 SECONDS NOTRIGGER
2020-04-25 09:35:54.555 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 78
2020-04-25 09:35:54.555 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 78 AFTER 23 SECONDS
2020-04-25 09:35:54.556 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 78 AFTER 23 SECONDS NOTRIGGER
2020-04-25 09:35:54.556 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 79
2020-04-25 09:35:54.556 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 79 AFTER 24 SECONDS
2020-04-25 09:35:54.556 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 79 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.556 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 80
2020-04-25 09:35:54.557 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 80 AFTER 24 SECONDS
2020-04-25 09:35:54.557 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 80 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.557 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 81
2020-04-25 09:35:54.557 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 81 AFTER 24 SECONDS
2020-04-25 09:35:54.558 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 81 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.558 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 82
2020-04-25 09:35:54.558 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 82 AFTER 24 SECONDS
2020-04-25 09:35:54.558 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 82 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.558 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 83
2020-04-25 09:35:54.559 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 83 AFTER 25 SECONDS
2020-04-25 09:35:54.559 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 83 AFTER 25 SECONDS NOTRIGGER
2020-04-25 09:35:54.559 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 84
2020-04-25 09:35:54.559 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 84 AFTER 25 SECONDS
2020-04-25 09:35:54.559 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 84 AFTER 25 SECONDS NOTRIGGER
2020-04-25 09:35:54.560 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 85
2020-04-25 09:35:54.560 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 85 AFTER 25 SECONDS
2020-04-25 09:35:54.560 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 85 AFTER 25 SECONDS NOTRIGGER
2020-04-25 09:35:54.560 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 86
2020-04-25 09:35:54.561 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 86 AFTER 26 SECONDS
2020-04-25 09:35:54.561 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 86 AFTER 26 SECONDS NOTRIGGER
2020-04-25 09:35:54.561 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 87
2020-04-25 09:35:54.561 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 87 AFTER 26 SECONDS
2020-04-25 09:35:54.561 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 87 AFTER 26 SECONDS NOTRIGGER
2020-04-25 09:35:54.561 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 88
2020-04-25 09:35:54.562 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 88 AFTER 26 SECONDS
2020-04-25 09:35:54.562 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 88 AFTER 26 SECONDS NOTRIGGER
2020-04-25 09:35:54.562 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 89
2020-04-25 09:35:54.562 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 89 AFTER 27 SECONDS
2020-04-25 09:35:54.562 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 89 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.563 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 90
2020-04-25 09:35:54.563 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 90 AFTER 27 SECONDS
2020-04-25 09:35:54.563 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 90 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.563 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 91
2020-04-25 09:35:54.563 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 91 AFTER 27 SECONDS
2020-04-25 09:35:54.564 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 91 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.564 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 92
2020-04-25 09:35:54.564 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 92 AFTER 27 SECONDS
2020-04-25 09:35:54.564 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 92 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.565 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 93
2020-04-25 09:35:54.565 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 93 AFTER 28 SECONDS
2020-04-25 09:35:54.565 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 93 AFTER 28 SECONDS NOTRIGGER
2020-04-25 09:35:54.565 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 94
2020-04-25 09:35:54.566 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 94 AFTER 28 SECONDS
2020-04-25 09:35:54.566 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 94 AFTER 28 SECONDS NOTRIGGER
2020-04-25 09:35:54.566 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 95
2020-04-25 09:35:54.566 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 95 AFTER 28 SECONDS
2020-04-25 09:35:54.566 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 95 AFTER 28 SECONDS NOTRIGGER
2020-04-25 09:35:54.566 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 96
2020-04-25 09:35:54.567 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 96 AFTER 29 SECONDS
2020-04-25 09:35:54.567 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 96 AFTER 29 SECONDS NOTRIGGER
2020-04-25 09:35:54.567 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 97
2020-04-25 09:35:54.567 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 97 AFTER 29 SECONDS
2020-04-25 09:35:54.567 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 97 AFTER 29 SECONDS NOTRIGGER
2020-04-25 09:35:54.568 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 98
2020-04-25 09:35:54.568 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 98 AFTER 29 SECONDS
2020-04-25 09:35:54.568 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 98 AFTER 29 SECONDS NOTRIGGER
2020-04-25 09:35:54.568 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 99
2020-04-25 09:35:54.568 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 99 AFTER 30 SECONDS
2020-04-25 09:35:54.569 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 99 AFTER 30 SECONDS NOTRIGGER
2020-04-25 09:35:54.569 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 100
2020-04-25 09:35:54.569 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 100 AFTER 30 SECONDS
2020-04-25 09:35:54.569 Status: dzVents: Debug: blindPercentages: Constructed timed-command: Set Level 100 AFTER 30 SECONDS NOTRIGGER
2020-04-25 09:35:54.569 Status: dzVents: Debug: blindPercentages: Constructed timed-command: On
2020-04-25 09:35:54.570 Status: dzVents: Debug: blindPercentages: Constructed timed-command: On AFTER 30.0 SECONDS
2020-04-25 09:35:54.570 Status: dzVents: Debug: blindPercentages: Constructed timed-command: On AFTER 30.0 SECONDS NOTRIGGER
2020-04-25 09:35:54.571 Status: dzVents: Info: blindPercentages: ------ Finished Script #1
2020-04-25 09:35:54.572 Status: dzVents: Debug: Commands sent to Domoticz:
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Cancel = {["type"]="device", ["idx"]=274}
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Vrunter = On NOTRIGGER
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Velux = Set Level 0 AFTER 0 SECONDS NOTRIGGER
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Velux = Set Level 1 AFTER 0 SECONDS NOTRIGGER
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Velux = Set Level 2 AFTER 0 SECONDS NOTRIGGER
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Velux = Set Level 3 AFTER 1 SECONDS NOTRIGGER
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Velux = Set Level 4 AFTER 1 SECONDS NOTRIGGER
2020-04-25 09:35:54.572 Status: dzVents: Debug: - Velux = Set Level 5 AFTER 1 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 6 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 7 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 8 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 9 AFTER 2 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 10 AFTER 3 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 11 AFTER 3 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 12 AFTER 3 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 13 AFTER 4 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 14 AFTER 4 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 15 AFTER 4 SECONDS NOTRIGGER
2020-04-25 09:35:54.573 Status: dzVents: Debug: - Velux = Set Level 16 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 17 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 18 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 19 AFTER 5 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 20 AFTER 6 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 21 AFTER 6 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 22 AFTER 6 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 23 AFTER 7 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 24 AFTER 7 SECONDS NOTRIGGER
2020-04-25 09:35:54.574 Status: dzVents: Debug: - Velux = Set Level 25 AFTER 7 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 26 AFTER 8 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 27 AFTER 8 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 28 AFTER 8 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 29 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 30 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 31 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 32 AFTER 9 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 33 AFTER 10 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 34 AFTER 10 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 35 AFTER 10 SECONDS NOTRIGGER
2020-04-25 09:35:54.575 Status: dzVents: Debug: - Velux = Set Level 36 AFTER 11 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 37 AFTER 11 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 38 AFTER 11 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 39 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 40 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 41 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 42 AFTER 12 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 43 AFTER 13 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 44 AFTER 13 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 45 AFTER 13 SECONDS NOTRIGGER
2020-04-25 09:35:54.576 Status: dzVents: Debug: - Velux = Set Level 46 AFTER 14 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 47 AFTER 14 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 48 AFTER 14 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 49 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 50 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 51 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 52 AFTER 15 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 53 AFTER 16 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 54 AFTER 16 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 55 AFTER 16 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 56 AFTER 17 SECONDS NOTRIGGER
2020-04-25 09:35:54.577 Status: dzVents: Debug: - Velux = Set Level 57 AFTER 17 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 58 AFTER 17 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 59 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 60 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 61 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 62 AFTER 18 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 63 AFTER 19 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 64 AFTER 19 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 65 AFTER 19 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 66 AFTER 20 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 67 AFTER 20 SECONDS NOTRIGGER
2020-04-25 09:35:54.578 Status: dzVents: Debug: - Velux = Set Level 68 AFTER 20 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 69 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 70 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 71 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 72 AFTER 21 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 73 AFTER 22 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 74 AFTER 22 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 75 AFTER 22 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 76 AFTER 23 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 77 AFTER 23 SECONDS NOTRIGGER
2020-04-25 09:35:54.579 Status: dzVents: Debug: - Velux = Set Level 78 AFTER 23 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 79 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 80 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 81 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 82 AFTER 24 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 83 AFTER 25 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 84 AFTER 25 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 85 AFTER 25 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 86 AFTER 26 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 87 AFTER 26 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 88 AFTER 26 SECONDS NOTRIGGER
2020-04-25 09:35:54.580 Status: dzVents: Debug: - Velux = Set Level 89 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 90 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 91 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 92 AFTER 27 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 93 AFTER 28 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 94 AFTER 28 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 95 AFTER 28 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 96 AFTER 29 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 97 AFTER 29 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 98 AFTER 29 SECONDS NOTRIGGER
2020-04-25 09:35:54.581 Status: dzVents: Debug: - Velux = Set Level 99 AFTER 30 SECONDS NOTRIGGER
2020-04-25 09:35:54.582 Status: dzVents: Debug: - Velux = Set Level 100 AFTER 30 SECONDS NOTRIGGER
2020-04-25 09:35:54.582 Status: dzVents: Debug: - Vrunter = On AFTER 30.0 SECONDS NOTRIGGER
2020-04-25 09:35:54.582 Status: dzVents: Debug: =====================================================
2020-04-25 09:35:54.637 (Dummys) Light/Switch (Vrunter)
2020-04-25 09:35:54.653 (Dummys) Light/Switch (Velux)
2020-04-25 09:35:55.634 (Dummys) Light/Switch (Velux)
2020-04-25 09:35:56.615 (Dummys) Light/Switch (Velux)
2020-04-25 09:35:57.635 (Dummys) Light/Switch (Velux)
2020-04-25 09:35:58.615 (Dummys) Light/Switch (Velux)
2020-04-25 09:35:59.647 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:00.318 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-04-25 09:36:00.395 Status: dzVents: Debug: Event triggers:
2020-04-25 09:36:00.395 Status: dzVents: Debug: - Timer
2020-04-25 09:36:00.633 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:01.653 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:02.633 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:03.654 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:04.635 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:05.656 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:06.636 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:07.630 Status: User: Admin initiated a switch command (196/J_down/On)
2020-04-25 09:36:07.642 (EnoceanRemote) Lighting 2 (J_down)
2020-04-25 09:36:07.665 (Dummys) Light/Switch (Velux)
2020-04-25 09:36:07.756 Status: dzVents: Debug: Dumping domoticz data to /home/pi/domoticz/scripts/dzVents/domoticzData.lua
2020-04-25 09:36:07.861 Status: dzVents: Debug: Processing device-adapter for J_down: Switch device adapter
2020-04-25 09:36:07.862 Status: dzVents: Debug: dzVents version: 3.0.2
2020-04-25 09:36:07.862 Status: dzVents: Debug: Event triggers:
2020-04-25 09:36:07.862 Status: dzVents: Debug: - Device: J_down
2020-04-25 09:36:07.912 Status: dzVents: Info: Handling events for: "J_down", value: "On"
2020-04-25 09:36:07.912 Status: dzVents: Info: blindPercentages: ------ Start internal script: Script #1: Device: "J_down (EnoceanRemote)", Index: 196
2020-04-25 09:36:07.916 Status: dzVents: Debug: blindPercentages: Processing device-adapter for J_up: Switch device adapter
2020-04-25 09:36:07.918 Status: dzVents: Debug: blindPercentages: Processing device-adapter for Vrunter: Switch device adapter
2020-04-25 09:36:07.920 Status: dzVents: Debug: blindPercentages: Processing device-adapter for Vhoch: Switch device adapter
2020-04-25 09:36:07.922 Status: dzVents: Debug: blindPercentages: Processing device-adapter for Velux: Switch device adapter
2020-04-25 09:36:07.922 Status: dzVents: Debug: blindPercentages: J_down: -->> device Type: Lighting 2, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:36:07.922 Status: dzVents: Debug: blindPercentages: Velux: -->> device Type: Light/Switch, device switchType: Blinds Percentage, state: On, nValue 2, dv.level: 42
2020-04-25 09:36:07.922 Status: dzVents: Debug: blindPercentages: J_up: -->> device Type: Lighting 2, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:36:07.922 Status: dzVents: Debug: blindPercentages: Vrunter: -->> device Type: Light/Switch, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:36:07.922 Status: dzVents: Debug: blindPercentages: Vhoch: -->> device Type: Light/Switch, device switchType: Push On Button, state: On, nValue 1, dv.level: 0
2020-04-25 09:36:07.923 Status: dzVents: Debug: blindPercentages: level in data: 100
2020-04-25 09:36:07.924 Status: dzVents: Info: blindPercentages: ------ Finished Script #1
And the script
- Spoiler: show
This script is for a roof window.
The Fibaro switch is connected to VELUX KLF 050 WW INTEGRA® Schalter-Interface
One output of Fibaro switch is for close blinds and the other open blinds
Stop blind by using again same output as before
return
on =
devices =
'J_down',
'J_up',
'Velux',
logging =
data =
local upSpeed = 0.3
if remote then
Vhoch.switchOn()--.silent()
if remote then
-- Main..
elseif item == Jdown and Jdown.state == 'On' and velux.state == 'Closed' then
gotoLevel(0, true)
gotoLevel(0, true)
elseif item == Jup and Jup.state == 'On' and velux.state == 'Open' then
Re: Need help :Virtual blind percentage for eg. Velux [Solved]
Posted: Thursday 28 May 2020 12:54
by sailmich
Here is my script with some changes to the original from waaren. For the remote EnOcean switch I decided to use own scripts with just open/close the roof windows by trigger the dummy blind. The blind dummy script for my roof windows are working except that I have to double tap open or close. When change the level with the slider the signal comes instantly.
In case someone would like to use the script here it is. Thanks again @waaren.
dummy blind percentage
- Spoiler: show
This script is for a Velux roof window.
Velux = Dummy Blind // Controller to set blind percentage
DFrunter = Fibaro FGS222 switch // Actuator
DFhoch = Fibaro FGS222 switch // Actuator
local upSpeed for 1% can be change accorrding to the time for a complete opening cycle.
local downSpeed for 1% can be change accorrding to the time for a complete closing cycle.
return
on =
devices =
'Velux',
logging =
level = domoticz.LOG_ERROR,
marker = 'blindPercentages',
data =
level = { initial = 0 },
execute = function(dz, item)
local DFrunter =dz.devices('DFrunter') --roof window down
local DFhoch = dz.devices('DFhoch') --roof window up
local velux = dz.devices('Velux')
local delay = 1 -- time delay from actuator to relais
local function createSomeLogging(dv)
dz.log(dv.name .. ': -->> device Type: ' .. ( dv.deviceType or "-") .. ', device switchType: ' .. ( dv.switchType or "-") ..
', state: ' .. ( dv.state or "-") .. ', nValue ' .. (dv.nValue or "-") ..
', dv.level: ' .. ( dv.level or "-") ,dz.LOG_DEBUG)
for _, device in pairs({velux , DFrunter, DFhoch}) do
createSomeLogging(device)
local function gotoLevel(newLevel)
local upSpeed = 0.5
local downSpeed = 0.5
if dz.data.level < newLevel and DFrunter.state == 'Off' and DFhoch.state == 'Off' then
DFrunter.switchOn().forSec(( newLevel - dz.data.level) * downSpeed +delay ).silent()
elseif newLevel < dz.data.level and DFrunter.state == 'Off' and DFhoch.state == 'Off' then
DFhoch.switchOn().forSec(( dz.data.level - newLevel) * upSpeed + delay ).silent()
elseif dz.data.level < newLevel and DFrunter.state == 'On' or DFhoch.state == 'On' then
velux.setLevel(dz.data.level).silent()
elseif newLevel < dz.data.level and DFrunter.state == 'On' or DFhoch.state == 'On' then
if dz.data.level == 'Open' then
dz.data.level.setLevel(100)
elseif dz.data.level == 'Closed' then
dz.data.level.setLevel(0)
-- Main..
dz.log('level in data: ' .. dz.data.level,dz.LOG_ERROR )
Posted: Saturday 30 May 2020 0:16
by Doomic
Not sure if i should start a new thread. But the script in this thread looks pretty the same as the one i have build.
Well not as the last post, but the one above.
It is looping over the difference between current value and prefered value and doing some setLevel statements after x seconds.
But i can't get it to work (not sure if that was the issue here as well).
Only my last setLevel statement is executed.
found something in de doc about scheduled commands within the range of the new scheduled command is automaticly canceled.
Therefore i changed the order by schedule first that command with the highest time. But this isn't working either; at the end, only the last command is executed.
Simple example:
devices = {
"SwitchTest"
local varTest = domoticz.variables("VarTest")
varTest.set(2).afterSec(2)
varTest.set(1).afterSec(1)
you should expect that varTest=2 after 2(or more) seconds. But it looks like .set(1) command is also canceling the set(2) command. So i end up with varTest=1 after 2 seconds.
is this a bug? Or can't you schedule multiple commands for 1 device/var? (but in that case the sugested script above would never have worked).
Posted: Wednesday 03 June 2020 21:18
by Doomic
in case someone read my post:
i started a new topic with the same question here:
viewtopic.php?f=59&t=32930
conclusion is that it should be scheduled from low to high. (high to low is not working, because the higher ones are canceld by the lower ones)
the issue with my script (i did not post here) was something else... silent() was not respected because of a bug. And therefore it triggered his own script. And because of that a new afterSec was scheduled.. and that one canceled all scheduled commands.
