MQTT - battery percentage level without themperature update?
Posted: Tuesday 21 April 2020 20:08
by tomes
There is a temperature sensor. I would like to update their temperature value and battery level with separate MQTT commands. Is it possible?
When I type: {"idx": 123, "Battery": 50} an error appears.
When I enter the temperature without battery, the battery level disappears.
How to update only one value without erase other?
Tom
Re: MQTT - battery percentage level without themperature update?
Posted: Tuesday 21 April 2020 23:32
by waaren
tomes wrote: Tuesday 21 April 2020 20:08
The only way to update a batteryLevel of a temperature sensor (besides poking directly in the database) is with the combined MQTT or JSON command.
Luckily dzVents can help here.
if you send one of these MQTT messages to domoticz/in
{"command":"customevent","event":"separateValues","data": "{'"'idx'"':29, '"'temperature'"':25 }" } # for temperature only
{"command":"customevent","event":"separateValues","data": "{'"'idx'"':29, '"'batteryLevel'"':29 }" } # for batteryLevel only
Below dzVents script will handle the update of the temperature sensor
local scriptVar = 'separateValues'
return
on =
customEvents =
scriptVar,
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG, -- set to LOG_ERROR when tested and OK
marker = scriptVar,
execute = function(dz, item)
lodash = dz.utils._
local function sendURL(idx, temperature, batteryLevel)
local url = dz.settings['Domoticz url'] ..
'/json.htm?type=command¶m=udevice&idx=' .. idx ..
'&nvalue=0&svalue=' .. temperature ..
'&battery=' .. batteryLevel
dz.openURL(
url = url,
callback = scriptVar,
if item.isCustomEvent then
local mqtt = item.data
local batteryLevel = mqtt.batteryLevel or dz.devices(mqtt.idx).batteryLevel or 255
local temperature = mqtt.temperature or dz.devices(mqtt.idx).temperature
sendURL(mqtt.idx, temperature, batteryLevel)
elseif not item.ok then
dz.log('Problem with sending the temperature / batteryLevel' .. lodash.str(item), dz.LOG_ERROR)
dz.log('All ok \n' .. lodash.str(item.data) .. '\n', dz.LOG_DEBUG)
Posted: Wednesday 22 April 2020 0:47
by tomes
Ok, thank You again. I`ll test it.
Posted: Wednesday 22 April 2020 13:29
by thomasbaetge
since you're working already with MQTT, this is how I update the battery value with node-red. The sample is from a flood sensor. the "svalue" : "0" is required, otherwise it won't work.
msg.payload = {
"idx" :290,
"svalue" : "0",
"Battery" :parseInt(msg.payload)
return msg;
Posted: Wednesday 22 April 2020 16:51
by waaren
thomasbaetge wrote: Wednesday 22 April 2020 13:29
if you send svalue 0 to a temperature sensor it will show a temperature of 0 degrees.
Posted: Wednesday 22 April 2020 17:28
by thomasbaetge
Right...but I assume NVALUE=0 will do the trick too.
The point is, that just sending the Battery value doesn't seem to work.
Posted: Wednesday 22 April 2020 17:50
by waaren
thomasbaetge wrote: Wednesday 22 April 2020 17:28
That's why I proposed the dzVents approach which will preserve the current value for temperature when updating the battery-value and preserving the battery-value when updating the temperature.
Posted: Wednesday 22 April 2020 18:54
by ben53252642
What I do is when a device only reports its battery level I store it in Node-Red and then when a temperature level is reported I also send the previously received battery reading (or latest if its available).
You can code a rule if you want to only send the battery reading with temperature if the battery reading was received within the last 2 days (so that its reasonably current, obviously depending on the power consumption of the device).
