Basic Wall Controller not recognized?
Posted: Tuesday 21 April 2020 15:26
by Marcjeok
Hi All,
I received a Zwave basic wall controller (ordered here: https://www.robbshop.nl/wandzender-2v-z ... obb-smarrt, the manual can be found here: https://www.robbshop.nl/amfilerating/fi ... le_id/816/) a few days ago. After adding the device to my Zwave controller, Domoticz shows the device like this (Setup > Hardware > Setup Zwave controller):
Domoticz 1.PNG (119.48 KiB) Viewed 2554 times
--> Description in image: Basic Wall Controller
No new devices are emerging (Setup> Devices). Normally it take some time to show the device properly, but in this case it's not showing the device properly after two days. Is this fixable for me or does this means that the device is not supported by Domoticz?
Thanks in advance!
Edit post:
Hereby a photo with the front and back of the device:
Text on the back:
ROBB smarrt
ROB_100-002-0
3v CR2450 10mA
200303V1
Re: Basic Wall Controller not recognized?
Posted: Tuesday 21 April 2020 15:44
by waaren
Marcjeok wrote: Tuesday 21 April 2020 15:26 No new devices are emerging (Setup> Devices). Normally it take some time to show the device properly, but in this case it's not showing the device properly after two days. Is this fixable for me or does this means that the device is not supported by Domoticz?
Did you enable "Accept new hardware devices" ?
in [Setup][Setting][System]
Posted: Tuesday 21 April 2020 15:56
by Marcjeok
waaren wrote: Tuesday 21 April 2020 15:44
Thanks for your reply! I forgot to mention this in my first post; yes I enabled to accept new hardware devices. Just to be sure, I just pressed the button again, but unfortunately nothing happens.
Hereby also some information about my Domoticz (just in case):
About Domoticz
Version: 2020.1
Build Hash: 63fa969e4
Compile Date: 2020-03-22 15:16:16
dzVents Version: 3.0.1
Python Version: 3.7.3 (default, Dec 20 2019, 18:57:59) [GCC 8.3.0]
Posted: Thursday 23 April 2020 10:54
by Marcjeok
I added an another device to my Domoticz (FIBARO System FGRM223 Roller Shutter Controller 3+) and this went well (see pictures below). Does this mean that the 'Basic Wall Controller' will not be recognized by Domoticz?
--> Fibaro has been added correctly, the Basic Wall Controller is still not added correctly
--> Fibaro devices are visible
Posted: Thursday 23 April 2020 14:50
by Marcjeok
I found some more information. My reseller sales this device under his own brand. However, I think this is the real manufacturer:
https://www.sunricher.com/z-wave-series.html
When I look in the file 'manufacturer_specific.xml' in the domoticz/config folder (see code below) the manufacturer already exists. Apparently not with the correct XML?
  <Manufacturer id="0330" name="Sunricher">
    <Product config="sunricher/srzv9001t4dimeu.xml" id="a10d" name="Touch Panel Wall Controller - ZSC-01D" type="0003"/>
    <Product config="sunricher/srzv9001k8.xml" id="a305" name="Wall Controller - SR-ZV9001" type="0300"/>
    <Product config="sunricher/zv9101.xml" id="d005" name="Dimmer ZV-9101" type="0200"/>
    <Product config="sunricher/srzv9101sachpeu.xml" id="d00c" name="Dimmer ZV9040" type="0200"/>
    <Product config="sunricher/srzv9003t4rgbweu.xml" id="a107" name="Z-Wave Wall Controller - SR-ZV9003T4-RGBW-EU" type="0300"/>
  </Manufacturer>[*]
Posted: Friday 24 April 2020 11:44
by Marcjeok
If I'm right, when I want to make this work, I have to do two things:
1. Create a XML file with the information for this Zwave device (source: https://github.com/OpenZWave/open-zwave ... ng-Devices)
2. Edit the file 'manufacturer_specific.xml' to add the device and refer to the created file
Unfortunately I'm not that technical, so I'm afraid I have to return this device back to my reseller. Can anyone confirm my findings? Are my thoughts correct or did I miss something?
Thanks in advance.
Posted: Sunday 26 April 2020 20:43
by Jef61
I have the same controller with 4 buttons. After updating to Domoticz 2020 .1 the controller is not recognized anymore so i had to reverse the update. I also found the new manufactor but still no solution for the problem. I'm going to try the new Domoticz version 2020.2. Have you already found a solution?
Posted: Monday 27 April 2020 13:44
by Jef61
Just tested with version 2020.2, it is working again :-)
Posted: Monday 27 April 2020 15:42
by Marcjeok
Jef61 wrote: Monday 27 April 2020 13:44 Just tested with version 2020.2, it is working again :-)
Thanks for your reply! Very good it's working for you again! I also update to version 2020.2, but unfortunately with the same result (not recognized). I'm going to send the device back to my reseller :cry:
Updated Domoticz configuration (just in case):
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Posted: Thursday 30 April 2020 9:31
by Marcjeok
After contact with my reseller I excluded the device and included it again. Now it works :D
It's not working perfectly if you ask me. At the hardware tab the device is shown as:
Included second time.PNG (13.84 KiB) Viewed 2435 times
--> Unknown: id=0330 Unknown: type=0300, id=a307+
There are two Devices added and both are configured as a switch. Both switches stay at 'On', regardless of the buttons I press on the devices itself. However, with Dzvents it triggers the event depending on the button I press on the device. So it works for me now.
Posted: Thursday 30 April 2020 11:43
by Snowtiger
Marcjeok wrote:After contact with my reseller I excluded the device and included it again. Now it works :D
Now you could try to :
Go to Hardware / Zwave settings / Select this node and press Refresh Node info to see if the text is now correct (vernieuw node info in Dutch), maybe the correct info is now displayed....
Posted: Friday 01 May 2020 10:27
by Marcjeok
Snowtiger wrote: Thursday 30 April 2020 11:43 Now you could try to :
I did this yesterday and nothing seems to happen. Today I noticed that the configuration part was lost and when I pressed the buttons nothing happened any more. Somehow it lost his configuration. I excluded the node and included it again and now it's working again. Hope it stays like this... :roll:
