Lights switch -> lastUpdate not working
Posted: Monday 20 April 2020 16:34
I'm using the following script to control my lights. When I got to bed I push a button and the mode is changed to "Alles uit".
Currently my lights turn off and immediatly two of my lights turn on for 2.5 minutes. I can't figure out why this happens. The code has a line; Modus.lastUpdate.minutesAgo > 3 but i seems that this one isn't pickedup.
Anyone have an idea?
--Creator: Rob
--Date: 01-04-2020
--Last update: 10-04-2020
--Changelog:
--10-04-2020: Added option so lights will not switch off when event lights at night are on.
--Source: -
--Description: Used to switch the lights in the living room, based on someone home and lux
devices = {
311, --PIR Livingroom | Lux
312, --PIR Livingroom | Movement
313 --Mode
--Add logging for this script
logging = {
level = domoticz.LOG_INFO, --Set the loglevel. Seclect from:LOG_INFO, LOG_DEBUG, LOG_ERROR or LOG_FORCE to override system log level
marker = "-=#Livingroom Lights | Lux#=-"
--Declarations
local Modus = domoticz.devices(313) --Mode
local LuxDevice = domoticz.devices(311) --PIR Livingroom | Lux
local Lux = LuxDevice.lux
local Movement = domoticz.devices(312) --PIR Livingroom | Movement
--Function
--Light above dresser
if (Modus.state == 'Iemand thuis/Oppas' and Lux < 75) then --Someone home and lux below set value then,
domoticz.devices(179).switchOn().checkFirst() --turn on light above dresser at 100% after 5 minutes
else --If not,
domoticz.devices(179).switchOff().checkFirst() --Turn off light above dresser
--Other lights in the livingroom
if (Modus.state == 'Iemand thuis/Oppas' and Lux < 14) then
domoticz.devices(188).dimTo(70) --Turn on lights above the dinnertable at 70%
domoticz.devices(185).dimTo(35) --Turn on lights above the couch at 35%
domoticz.devices(51).switchOn().checkFirst() --Turn on light next to the television
domoticz.devices(290).switchOn().checkFirst() --Turn on ledstrip in the kitchen at 75%
elseif (Modus.state == 'Iemand thuis/Oppas' and Lux > 15) then
domoticz.devices(185).switchOff().checkFirst() --Turn off lights above the couch
domoticz.devices(51).switchOff().checkFirst() --Turn off light next to the television
--update 12-04-2020
if Modus.lastUpdate.minutesAgo > 3 and Modus.state == 'Alles uit' --If mode is set to 'Alles uit' and mode hasn't changed the last 3 minutes and
and Movement.active and Lux < 10 then --there is movement and lux is below set level then,
domoticz.devices(188).dimTo(15) --Turn on lights above the dinnertable at 15%
domoticz.devices(185).dimTo(15) --Turn on lights above the couch at 15%
domoticz.devices(188).switchOff().afterSec(150) --Turn off lights above the dinnertable after 2.5 minutes
domoticz.devices(185).switchOff().afterSec(150) --Turn off lights above the couch after 2.5 minutes
--end update 12-04-2020
elseif Modus.state == 'Uit' then
domoticz.devices(188).switchOff().checkFirst() --Turn off lights above the dinnertable
domoticz.devices(179).switchOff().checkFirst() --Turn off light above the dresser
domoticz.devices(51).switchOff().checkFirst() --Turn off lights next to the television
domoticz.devices(290).switchOff().checkFirst() --Turn off ledstrip in the kitchen
