Installation of domoticz takes forever
Posted: Sunday 19 April 2020 19:17
by Draakje
Is there anything I can do to speed up the initial install / compile of domoticz?
On my raspberry pi3b+ (running rasbian) it is taking hours to complete.
I might have something not done right... ??????
any ideas?
Re: Installation of domoticz takes forever
Posted: Sunday 19 April 2020 19:42
by freijn
Must be something wrong indeed.
SD card broken ?
Any hint in the text on the screen?
Posted: Sunday 19 April 2020 19:46
by Draakje
no hints, compile just takes forever (as in more than 60 minutes..
eventually it will finish with no errors..
I have a 32GB Samsung EVO microsd.
Posted: Monday 20 April 2020 0:25
by waaren
Draakje wrote: Sunday 19 April 2020 19:46
60 minutes is not bad for compiling the first time on a RPI 3B.
Did you use a swap file as per the recommendations on the
wiki ?
On a raspberry PI compilation could take a long time. Suggested is to use a swap file (see above) if you have less then 4GB of memory
Initial build:
RPI-4: 28m.40s
Posted: Monday 20 April 2020 7:51
by Draakje
aa cr**p
yes I did not do that step!
that was probably the problem!
Will not test it thou
the system is up and running now
Posted: Monday 04 May 2020 13:03
by sammyke007
I compiled myself Domoticz on an old Sony Vaio netbook (Atom CPU...) as the easy install script gives a 404 error for a 32bit CPU. It took almost all night to compile, but it's up and running now
. Only 2GB ram and without swapfile
