Service doesn't work on reboot
Posted: Sunday 19 April 2020 13:44
by xavierlp
Hello all.
I just finished to build a new script with the help of this page
https://www.domoticz.com/wiki/Presence_ ... Beacon%29
All is ok if I run the service manually but after every reboot the service is failed!
I built the file check_beacon_presence.service as is
Description=check_beacon_presence Service
After=multi-user.target
[Service]
User=root
Type=idle
ExecStart=python /usr/local/bin/check_beacon_presence.py
[Install]
WantedBy=multi-user.target
then I activated the service
sudo systemctl enable check_beacon_presence.service
Then start the service like this
sudo systemctl start check_beacon_presence.service
All is working
pi@raspberrypi4:~ $ sudo systemctl status check_beacon_presence.service -l
● check_beacon_presence.service
Loaded: loaded (/etc/systemd/system/check_beacon_presence.service; enabled; vendor preset: enabled)
Active: active (running) since Sat 2020-04-18 19:30:22 CEST; 1min 7s ago
Main PID: 7213 (python)
Tasks: 2 (limit: 3911)
Memory: 12.0M
CGroup: /system.slice/check_beacon_presence.service
└─7213 /usr/bin/python /usr/local/bin/check_beacon_presence.py
avril 18 19:30:22 raspberrypi4 systemd[1]: Started check_beacon_presence.service.
avril 18 19:30:22 raspberrypi4 sudo[7219]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/hciconfig hci1 down
avril 18 19:30:22 raspberrypi4 sudo[7219]: pam_unix(sudo:session): session opened for user root by (uid=0)
avril 18 19:30:22 raspberrypi4 sudo[7219]: pam_unix(sudo:session): session closed for user root
avril 18 19:30:22 raspberrypi4 sudo[7229]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/hciconfig hci1 up
avril 18 19:30:22 raspberrypi4 sudo[7229]: pam_unix(sudo:session): session opened for user root by (uid=0)
avril 18 19:30:22 raspberrypi4 sudo[7229]: pam_unix(sudo:session): session closed for user root
avril 18 19:30:22 raspberrypi4 sudo[7239]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/hciconfig
avril 18 19:30:22 raspberrypi4 sudo[7239]: pam_unix(sudo:session): session opened for user root by (uid=0)
avril 18 19:30:22 raspberrypi4 sudo[7239]: pam_unix(sudo:session): session closed for user root
But after a reboot I can read this
Active: failed (Result: exit-code) since Sat 2020-04-18 19:25:09 CEST; 1s ago
Process: 4777 ExecStart=/usr/bin/python /usr/local/bin/check_beacon_presence.py (code=exited, status=1/FAILURE)
Main PID: 4777 (code=exited, status=1/FAILURE)
avril 18 19:25:09 raspberrypi4 sudo[4803]: pam_unix(sudo:session): session opened for user root by (uid=0)
avril 18 19:25:09 raspberrypi4 sudo[4803]: pam_unix(sudo:session): session closed for user root
avril 18 19:25:09 raspberrypi4 python[4777]: Traceback (most recent call last):
avril 18 19:25:09 raspberrypi4 python[4777]: File "/usr/local/bin/check_beacon_presence.py", line 182, in <module>
avril 18 19:25:09 raspberrypi4 python[4777]: hci_toggle_le_scan(sock, 0x01)
avril 18 19:25:09 raspberrypi4 python[4777]: File "/usr/local/bin/check_beacon_presence.py", line 102, in hci_toggle_le_scan
avril 18 19:25:09 raspberrypi4 python[4777]: bluez.hci_send_cmd(sock, OGF_LE_CTL, OCF_LE_SET_SCAN_ENABLE, cmd_pkt)
avril 18 19:25:09 raspberrypi4 python[4777]: _bluetooth.error: (1, 'Operation not permitted')
avril 18 19:25:09 raspberrypi4 systemd[1]: check_beacon_presence.service: Main process exited, code=exited, status=1/FAILURE
avril 18 19:25:09 raspberrypi4 systemd[1]: check_beacon_presence.service: Failed with result 'exit-code'.
So my first idea it was because root user
So I ran this command
pi@raspberrypi4:~ $ sudo su
root@raspberrypi4:/home/pi# python /usr/local/bin/check_beacon_presence.py
And all is ok
So manually od ok but after rebbot no!
I am using RPI4 and buster
I can't understand where is my mistake
Any help or advice very appreciated
Have a good day
Re: Service doesn't work on reboot
Posted: Sunday 19 April 2020 14:11
by MikeF
I think your After clause is probably wrong - you want something like
Posted: Sunday 19 April 2020 15:27
by xavierlp
MikeF
Thanks a lot : it's works perfectly now
You made my day ....
Posted: Thursday 14 May 2020 19:25
by McMelloW
Dear all.
Since the update to buster,i Have the same kind of problem. I hope some can point me in the right direction to solve it.
This is my service file.
# This is an example systemd configuration file for using in an systemd environment
# its was written for the archlinux-arm os
# modify User and ExecStart for your needs
[Unit]
Description=iSpindle-genericTCP server and relay
[Service]
Type=idle
User=pi
ExecStart=/usr/bin/python3 /usr/local/bin/iSpindle.py
Restart=always
TimeoutStartSec=10
RestartSec=10
[Install]
When I enable the service and start it It does work. See the log below.
pi@mcmellow-pi:~ $ sudo systemctl status ispindle-srv.service
? ispindle-srv.service
Loaded: loaded (/etc/init.d/ispindle-srv.service; generated)
Active: failed (Result: exit-code) since Thu 2020-05-14 19:00:49 CEST; 1min 51s ago
Docs: man:systemd-sysv-generator(8)
Process: 27666 ExecStart=/etc/init.d/ispindle-srv.service start (code=exited, status=203/EXEC)
May 14 19:00:49 mcmellow-pi systemd[1]: Starting ispindle-srv.service...
May 14 19:00:49 mcmellow-pi systemd[27666]: ispindle-srv.service: Failed to execute command: Exec format error
May 14 19:00:49 mcmellow-pi systemd[27666]: ispindle-srv.service: Failed at step EXEC spawning /etc/init.d/ispindle-srv.service: Exec format error
May 14 19:00:49 mcmellow-pi systemd[1]: ispindle-srv.service: Control process exited, code=exited, status=203/EXEC
May 14 19:00:49 mcmellow-pi systemd[1]: ispindle-srv.service: Failed with result 'exit-code'.
May 14 19:00:49 mcmellow-pi systemd[1]: Failed to start ispindle-srv.service.
Posted: Thursday 14 May 2020 19:42
by FireWizard
Hello @Mcmellow.
However, if I see the file below it displays:
Active: failed
and
Does this work? Or are my observations wrong?
Posted: Thursday 14 May 2020 20:59
by McMelloW
FireWizard wrote: Thursday 14 May 2020 19:42
Hello @Mcmellow.
Active: failed
and
No it does not start. This is what happen.
pi@mcmellow-pi:~ $ sudo systemctl start ispindle-srv.service
Job for ispindle-srv.service failed because the control process exited with error code.
See "systemctl status ispindle-srv.service" and "journalctl -xe" for details.
pi@mcmellow-pi:~ $
This is the status after the failed start.
Posted: Thursday 14 May 2020 22:42
by FireWizard
Ho @McMelloW,
Can you check a few things?
The error message (code=exited, status=203/EXEC) is often seen when the script itself or its interpreter cannot be executed.
It could have these reasons:
wrong path, (/usr/local/bin/iSpindle.py)
script not executable
no shebang (first line)
wrong path in shebang (e.g. /bin/python3)
internal files in your script might be missing access permissions.
Posted: Thursday 14 May 2020 23:42
by McMelloW
@FireWizard Thanks very much for your checking.
FireWizard wrote: Thursday 14 May 2020 22:42
Ho @McMelloW,
I will check.
Script will run OK from command line
$ /usr/bin/python3 /usr/local/bin/iSpindle.py
So script is executable and does run OK. path is OK
shebang line and shebang path are correct. Otherwise it would not run correctly before.
It did run before Buster with insserv. But with Buster you have to remove insserv, because this does not OK. And it is build inin buster.
Posted: Friday 15 May 2020 0:02
by FireWizard
@McMellow,
If I try to "google" iSpindle.py I find Python2 scripts.
Are you sure that the script is Python3?
Check the shebang,
Posted: Friday 15 May 2020 12:14
by McMelloW
FireWizard wrote: Friday 15 May 2020 0:02
@McMellow,
Check the shebang,
Sure it is python3. This is the header:
#!/usr/bin/env python3
# Version 3.0
# Modified version for Python 3
# Some string handling had to be changed for python3
How can it else work on a command line like this.
Posted: Friday 15 May 2020 14:09
by FireWizard
Hi @McMelloW,
You are right, otherwise the commandline would have failed also.
Can you try the following command:
journalctl -u ispindle-srv.service
Posted: Friday 15 May 2020 15:41
by McMelloW
FireWizard wrote: Friday 15 May 2020 14:09
Thanks FireWizard.
Getting a bit frustrated about Buster.It is now asking for user-id password authentication when a service is started interactive.
Below you see what happens after I started the service; then the status and finaly the journalctl
pi@mcmellow-pi:~ $ systemctl start ispindle-srv.service
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
Authentication is required to start 'ispindle-srv.service'.
Multiple identities can be used for authentication:
1. ,,, (pi)
2. root
Choose identity to authenticate as (1-2): 1
Password:
==== AUTHENTICATION COMPLETE ===
pi@mcmellow-pi:~ $ systemctl status ispindle-srv.service
Active: failed (Result: exit-code) since Fri 2020-05-15 15:04:45 CEST; 1min 4s ago
Process: 4845 ExecStart=/etc/init.d/ispindle-srv.service start (code=exited, status=203/EXEC)
May 15 15:04:45 mcmellow-pi systemd[1]: Starting ispindle-srv.service...
May 15 15:04:45 mcmellow-pi systemd[4845]: ispindle-srv.service: Failed to execute command: Exec format error
May 15 15:04:45 mcmellow-pi systemd[4845]: ispindle-srv.service: Failed at step EXEC spawning /etc/init.d/ispindle-srv.service: Exec format error
May 15 15:04:45 mcmellow-pi systemd[1]: ispindle-srv.service: Control process exited, code=exited, status=203/EXEC
May 15 15:04:45 mcmellow-pi systemd[1]: ispindle-srv.service: Failed with result 'exit-code'.
May 15 15:04:45 mcmellow-pi systemd[1]: Failed to start ispindle-srv.service.
pi@mcmellow-pi:~ $ sudo journalctl -u ispindle-srv.service
Posted: Friday 15 May 2020 16:01
by FireWizard
Hello @McMellow,
This has nothing to do with Buster, but with the fact that you tried to start the service WITHOUT sudo. Previously you started that service with sudo.
Did you also try sudo journalctl -xe, as suggested?
Try to do some research now.
Posted: Friday 15 May 2020 16:06
by McMelloW
FireWizard wrote: Friday 15 May 2020 16:01
Hello @McMellow,
Yes you are right, had to use sudo. That is one thing solved
Posted: Friday 15 May 2020 17:15
by FireWizard
Hello @McMellow,
I have a question.
Is the software iSpindle retrieved from:
If so, I see that indeed the file iSpindle.py is a Python 3 file:
# Version 3.0
# Modified version fpor Python 3
But, I see also that the file ispindle-srv is not a python file:
#!/bin/sh
### BEGIN INIT INFO
# Provides: ispindle-srv
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: iSpindle-genericTCP server and relay
# Description: genericTCP backend for iSpindle providing data forwarding to ubidots csv and mysql
The file ispindle-srv.service contains:
[Unit]
[Service]
Type=idle
User=alarm
ExecStart=/usr/bin/python2 /home/alarm/iSpindle.py
Restart=always
TimeoutStartSec=10
RestartSec=10
[Install]
### END INIT INFO
# Change the next 3 lines to suit where you install your script and what you want to call it
DIR=/usr/local/bin
DAEMON=$DIR/iSpindle.py
DAEMON_NAME=ispindle-srv
Isn't that strange, that it indicates python2 or is it just a left-over of the previous version?
Once again, do the environment variables match (see above DIR).
Posted: Friday 15 May 2020 18:56
by McMelloW
FireWizard wrote: Friday 15 May 2020 17:15
Hello @McMellow,
I have a question.
You did a lot of homework, thanks.
Yes, it from the github link you mentioned. This is a fork from another and in development. The iSpindle.py is changed to python3
Therefore ispindle-srv.service has to be adjusted to python3
This the current /etc/init.d/ispindle-srv.service
[Unit]
After=network.target
[Service]
Type=simple
User=pi
Restart=always
TimeoutStartSec=10
RestartSec=10
[Install]
I hope it make things clear
Posted: Friday 15 May 2020 19:53
by FireWizard
Hello @McMelloW,
I don't see anything wrong, except that you make a change in the "ispindle-srv.service" file where you changed:
into
Does/Did it really need that the network is up. If not, reverse the change.
In my case I have all the .service files, I use to start, installed in /etc/systemd/system AND they have all set the eXecutable bit.
Can you check/try that.
1. Copy your ispindle-srv.service to /etc/systemd/system
2 sudo chmod +x etc/systemd/system/ispindle-srv.service
3 sudo systemctl start ispindle-srv.service
And for reading:
https://www.digitalocean.com/community/ ... -and-units and
https://www.digitalocean.com/community/ ... unit-files.
Posted: Friday 15 May 2020 22:36
by McMelloW
Hello FireWizard.
Thank you so much. This is exactly what I had to change. It works OK now. Well done.
I will look at the links as well and do some study.
FireWizard wrote: Friday 15 May 2020 19:53
Hello @McMelloW,
into
In my case I have all the . service files, I use to start, installed in /etc/systemd/system AND they have all set the eXecutable bit.
And for reading:
Posted: Friday 15 May 2020 22:39
by FireWizard
@McMelloW,
Take an extra beer first
Posted: Friday 15 May 2020 22:54
by McMelloW
FireWizard wrote: Friday 15 May 2020 22:39
@McMelloW,
Sure, I will
