Ok, I'm really trying hard to get this to work...but pfffew, nothing seems to go as planned...
So for my open-Zwave status I have this:
OpenZWave USB
Version: 1.6-1033-g3661f170
With a RED setup button, I tried various USB ports, but this is the least troublesome...
Log says: Error: OpenZWave: Type_Notification, NodeID not found internally!. HomeID: 0, NodeID: 255 (0xff)
Please help! (or do I just need another USB 2.0 hub?)
Aeotec USB Z-Stick - Z-Wave Plus - Raspberry 4 - states version but still red setup button (yes, I'm using a usb hub)
ronaldbro
- Domoticz version: 2020.2
Re: Aeotec USB Z-Stick - Z-Wave Plus - Raspberry 4 - states version but still red setup button (yes, I'm using a usb hub
I have encountered the same problem. Also after it worked I could loose the USB again after a few hours.
This solved my problems: https://www.domoticz.com/wiki/PersistentUSBDevices
TonyK
Could you verify if it did work for you before? *mine never worked / the button has always been red
TonyK
I got the new usb 2.0 hub (which a user verified as working with the Aeotec stick) but still no go. I also did the 'PersistentUSBDevices', still red setup and no devices...
Status: OpenZWave: User Alert - Manufacturer_specific.xml out of Date
Status: OpenZWave: ManufacturerSpecificDB Ready
Did some further testing:
above was with ACM0
with AMA0 I get:
Status: OpenZWave: using config in: /home/pi/domoticz/Config/
Status: OpenZWave: Starting...
Status: OpenZWave: Version: 1.6-1033-g3661f170
Error: OpenZWave: Driver Failed!!
Btw do I need to also fill in the USB Hub in PersistentUSBDevices?
Btw 2, this is my list:
sudo lsusb -v | grep 'idVendor\|idProduct\|iProduct\|iSerial'
can't get debug descriptor: Resource temporarily unavailable
idVendor 0x1d6b Linux Foundation
idProduct 0x0003 3.0 root hub
iProduct 2 xHCI Host Controller
iSerial 1 0000:01:00.0
idVendor 0x0403 Future Technology Devices International, Ltd
idProduct 0x6015 Bridge(I2C/SPI/UART/FIFO)
iProduct 2 RFXtrx433XL
iSerial 3 DO4YPIYW
can't get device qualifier: Resource temporarily unavailable
idVendor 0x0658 Sigma Designs, Inc.
idProduct 0x0200 Aeotec Z-Stick Gen5 (ZW090) - UZB
iProduct 0
iSerial 0
idVendor 0x14cd Super Top
idProduct 0x8601 4-Port hub
iProduct 3 USB 2.0 Hub
iSerial 0
idVendor 0x1cf1 Dresden Elektronik
idProduct 0x0030
iProduct 2 ConBee II
iSerial 3 DE2193653
idVendor 0x2109 VIA Labs, Inc.
idProduct 0x3431 Hub
iProduct 1 USB2.0 Hub
iSerial 0
idProduct 0x0002 2.0 root hub
above was with ACM0
with AMA0 I get:
iSerial 3 DO4YPIYW
iProduct 0
iSerial 0
iSerial 0
idProduct 0x0030
iSerial 3 DE2193653
iSerial 0
ronaldbro
Did your stick ever worked on a different Pi? Maybe your stick is just broken...
Your Pi does see it.
TonyK
Ok, I finally got it working...here's what I did:
-add external power to the USB 2.0 hub
-reset Aeotec Z-Stick Gen5 stick
-removed hardware (from hardware list)
-redid the PersistentUSBDevices (I did this before, but before a restart of the system I did empty out the rules, and added them again after the reboot)
-restart
-goto Hardware section of Domoticz
-add Open Z-wave, with the port assigned with the PersistentUSBDevices method! *apparently I missed that step...the port was now called: /dev/ttyUSB-ZStick-5G
-then click on red setup button
-finally see the entry there...hit back button
-Yeah...the setup button is now blue!!
Thnx Ronaldbro for pointing me in the right direction! *not sure if the external power also added to the solution...
-restart
ronaldbro
Ah, you got a powered hub. Didn’t know that. A powered hub always needs external power, it doesn’t get power from the host usb.
Good that it works. Enjoy your zwave
