Page 1 of 3
Dashticz Security Panel
Posted: Saturday 18 April 2020 22:53
by clinkadink
I have updated the Dashticz security panel block's design in the latest beta. The block settings remain unchanged, but the 'look and feel' has been updated
Additionally, if you have set your Domoticz security panel to "Armed Away", you can now configure Dashticz to secure automatically by applying the following setting in CONFIG.js.
config['security_panel_lock'] = 1;
If the panel has been set to "Armed Away", it will display a fullscreen panel. The user will need to enter the code and either set "Disarm" or "Armed Home" to enable the blue enter button". Pressing this will then show your Dashticz main screen.
Buttons:
The countdown delay is set in Domoticz, Setup > Settings > Security Panel > Delay. If set to zero, there will be no countdown.
The above fullscreen lock feature does
not require you to also have a Security Panel
block added in CONFIG.js. But if you want one, you can add one.
blocks['secpanel'] = {
title: '',
width: 6
Or you can have a block defined and disable the fullscreen lock feature with this (which is the default if not set):
config['security_panel_lock'] = 0;
As before, its a beta, feedback is always welcome
Re: Dashticz Security Panel
Posted: Sunday 19 April 2020 7:14
by krizzz
Wow, I don’t even use this function currently but I had to reply to say that the screens look absolutely fantastic! Maybe now I will use it in the future
Posted: Sunday 19 April 2020 9:17
by clinkadink
Thanks for the great feedback, glad you like it
I am building wall mounted display by my front door, and wanted an easy and secure method to arm/disarm the house. I am guessing others may want to do the same. It is built using pure css and should be responsive and scale to any display (phone, tablet, ipad, laptop, pc, etc.).
Posted: Tuesday 21 April 2020 10:04
by nfuse
realy nice addon to the allready fantastic dashticz
i tryed different options and it is usefull but i dont get the lock screen.
When i arm my system i only get the secpanel when i f5 (the same with graph updates) is this something i can change or set with a config option?
these are my default settings
in this scenario the secpanel will show only after 60 minutes
Posted: Tuesday 21 April 2020 10:38
by Lokonli
You have to add to CONFIG.js:
(and update to latest beta with git pull)
Posted: Tuesday 21 April 2020 13:41
by nfuse
Lokonli wrote: Tuesday 21 April 2020 10:38
i know and i have but when i set the alarm on for example my phone or another device the dashticz screen will show the secpanel after refreshing the screen (f5) or when the configured refresh has been loaded (config['dashticz_refresh'] = '60';) so there is no instant refresh when i arm the system
Posted: Tuesday 21 April 2020 15:35
by Lokonli
nfuse wrote: Tuesday 21 April 2020 13:41
ok, the Dashticz window should reload.
Maybe there is an issue with the reloading mechanism: which browser versions did you try?
If the system is on arm_away, and you refresh Dashticz, the security panel will pop up. If you then disarm, can you enter Dashticz by pressing the blue button?
Posted: Tuesday 21 April 2020 17:16
by clinkadink
The security panel will only display when (a) the system is "Armed Away", (b) security_panel_lock is set to 1 in CONFIG.js and (c) Dashticz is refreshed either by its dashticz_refresh setting or manual browser refresh.
Posted: Tuesday 21 April 2020 22:17
by nfuse
clinkadink wrote: Tuesday 21 April 2020 17:16
hmm hard to explain the problem i have (or feature i'am missing
. (i'am dutch so not that good with the english language)
To be clear there is no problem with the security panel it works, i arm the system home away and i get the lock screen but it takes at least an hour (after a dashticz refresh) before the security panel is shown (i arm from an other location)
after that i can unlock and press blue to open dashticz
a workaround would be to set config['dashticz_refresh'] = '60'; to 15 or 10 minutes but not an ideal solution, an instant update pushed to dashitcz would be nicer.
Posted: Tuesday 21 April 2020 22:27
by clinkadink
nfuse wrote: Tuesday 21 April 2020 22:17
^^^ this is the plan
Posted: Thursday 23 April 2020 9:09
by lzwfkv
It is already working that way for me.
As soon as I set security panel to "Arm Away" dashticz page is refreshed and a security panel page is displayed in full screen.
As soon as I diarm or arm home while on the locking security panel, dashticz page refreshes again and "normal" dashticz page is displayed.
Of course, when disarming/arming away from Domoticz (i.e. from remote), you must wait for config['domoticz_refresh'] seconds for dashticz to synch with the changed value in Domoticz.
I can arm away and disarm, independently, from dashticz security panel as well as from domoticz security panel.
I am using latest dashticz beta v.3.4.4 and Firefox browser.
Posted: Thursday 23 April 2020 9:26
by Lokonli
lzwfkv wrote: Thursday 23 April 2020 9:09
Yes, it was fixed last Tuesday.
Before that you had to wait for ['dashticz_refresh'] minutes (!) before Dashticz would detect you had switched on/off the alarm remotely.
Posted: Thursday 23 April 2020 11:51
by lzwfkv
Great, fixed in the same day..
However, i like both the functionality and the graphics of this security panel.
Just some layout issues with re-sizing the "block" when it starts to be a bit bigger than "designed": e.g. it goes beyond the screen vertically when i set the block width between 10 and 12 (i was trying to have a dashticz screen dedicated to the security panel block). I had to struggle with the css (custom.css) to make its height fit within the browser window using block width=11.
Posted: Thursday 23 April 2020 21:03
by toro
Very nice design!
I have the same problem, Have the panel in it's own screen. Made 3 columns, width 3, 6, 3. Then the panel does not fit on the screen.
I made the width 4, 4, 4 and now it fits, but it's a bit short.
Another question. If you enter the wrong code by mistake, the countdown starts before the error is displayed. At that moment, you are already outside the house. Is it possible to show the message 'wrong code' without the countdown?
And a small other thing a noticed, the armed message is not displayed in Edge. Once armed, the # symbols are not displayed when entering the code. Not a big problem for me as I use Edge only for testing, but maybe for others. I cleared the history and cache, that didn't help by the way.
Posted: Saturday 25 April 2020 12:47
by clinkadink
lzwfkv wrote: Thursday 23 April 2020 11:51
Ok, I will take a look. Thanks for letting me know.
Posted: Saturday 25 April 2020 12:56
by clinkadink
toro wrote: Thursday 23 April 2020 21:03
Understood. Thanks for reporting this. I will try and replicate with your example above and let you know what I find.
This would take some re-design and deviates from the Domoticz method. The code is validated when the status is being set. If you have the countdown enabled, it will countdown to zero, and then send the code and status update at the same time. I will see if anything can be done, but for the time being, if you want it to display "Wrong Code" instantly, set you delay to 0 in Domoticz (as shown in the first post).
I must admit I don't use Edge, and have not tested in Edge. It has been tested on Chrome, Firefox and Safari. I will download Edge, test, if I can replicate, I will try and fix this. I will then uninstall Edge and purge all recollection of having it on my PC (sorry, don't like Edge)
Posted: Saturday 25 April 2020 21:30
by toro
Thank you very much for looking into this.
clinkadink wrote: Saturday 25 April 2020 12:56
Well, actualy, when I use the Domoticz secpanel, the errorcode is diplayed the moment I press home or away (if entered a wrong code).
Also, setting the delay to zero doesn't give you time to leave or enter the house. Hope you are able to fix this.
I hear you
Not a big problem, just was wondering why it's different in Edge.
Posted: Tuesday 28 April 2020 14:17
by sammyke007
If I enter my PIN to disarm using the secpanel, it works fine.
If I try to arm home or arm away after entering PIN, it beeps 4 times and nothing happens?
Posted: Tuesday 28 April 2020 14:42
by HansieNL
When armed via Domoticz and try to disarm I get a message NO CONNECT. For some reason there’s no connection between Dashticz and Domoticz. Switches are working. If I restore a backup of 7 days ago theré's no problem.
@clinkadink : Any idea what’s going wrong?
Posted: Tuesday 28 April 2020 17:15
by Lokonli
sammyke007 wrote: Tuesday 28 April 2020 14:17
What is the Security Panel Delay value in Domoticz?
If it's 0 can you retest with a non 0 value?
