Solved ? : Crash after updating parameters
Remicade
Domoticz version: 4.10717
Post by Remicade »
Today I did a parameter change on my Domoticz Smart Virtual Thermostat. Nothing special
After this the system went offline.
When I start via putty with ,/domoticz i get this:
pi@raspberrypi:~/domoticz $ sudo ./domoticz
2020-04-18 15:37:57.982  Status: Domoticz V4.11803 (c)2012-2020 GizMoCuz
2020-04-18 15:37:57.983  Status: Build Hash: f0aac95ee, Date: 2020-03-21 16:52:51
2020-04-18 15:37:57.983  Status: Startup Path: /home/pi/domoticz/
2020-04-18 15:37:58.052  Sunrise: 06:37:00 SunSet: 20:46:00
2020-04-18 15:37:58.052  Day length: 14:09:00 Sun at south: 13:42:00
2020-04-18 15:37:58.052  Civil twilight start: 06:01:00 Civil twilight end: 21:23:00
2020-04-18 15:37:58.052  Nautical twilight start: 05:15:00 Nautical twilight end: 22:09:00
2020-04-18 15:37:58.052  Astronomical twilight start: 04:21:00 Astronomical twilight end: 23:02:00
2020-04-18 15:37:58.245  Status: PluginSystem: Started, Python version '3.7.3'.
2020-04-18 15:37:58.262  Active notification Subsystems: (0/13)
2020-04-18 15:37:58.265  Status: WebServer(HTTP) started on address: :: with port 8080
2020-04-18 15:37:58.274  Status: WebServer(SSL) started on address: :: with port 443
2020-04-18 15:37:58.279  Status: Camera: settings (re)loaded
2020-04-18 15:37:58.337  Starting shared server on: :::6144
2020-04-18 15:37:58.337  Status: TCPServer: shared server started...
2020-04-18 15:37:58.339  Status: RxQueue: queue worker started...
2020-04-18 15:37:58.515  Status: Incoming connection from: 192.168.2.32
2020-04-18 15:37:58.870  Status: Incoming connection from: 192.168.2.33
2020-04-18 15:37:59.468  Status: Incoming connection from: 192.168.2.30
2020-04-18 15:37:59.847  Status: Incoming connection from: 192.168.2.34
2020-04-18 15:38:00.339  Status: (Bart) Started.
2020-04-18 15:38:00.340  Status: (Lars) Started.
2020-04-18 15:38:00.342  Status: P1 Smart Meter: Using serial port: /dev/ttyAMA0
2020-04-18 15:38:00.344  Status: P1 Smart Meter: Worker started...
2020-04-18 15:38:00.345  Status: (Omnik) Started.
2020-04-18 15:38:00.347  Status: (Vloerverwarming) Started.
2020-04-18 15:38:00.348  Status: (Shelly) Started.
2020-04-18 15:38:00.350  Status: (Rookkast) Started.
2020-04-18 15:38:00.352  Status: NotificationSystem: thread started...
2020-04-18 15:38:00.353  Status: EventSystem: reset all events...
2020-04-18 15:38:00.356  Status: EventSystem: reset all device statuses...
2020-04-18 15:38:00.364  Status: BuienRadar: Worker started...
2020-04-18 15:38:00.543  Status: RFLink: Using serial port: /dev/serial/by-id/usb-Arduino__www.arduino.cc__0042_55739323131351600201-if00
2020-04-18 15:38:00.555  Status: PluginSystem: Entering work loop.
2020-04-18 15:38:00.765  Status: Incoming connection from: 192.168.2.88
2020-04-18 15:38:01.248  Status: (Bart) Entering work loop.
2020-04-18 15:38:01.250  Status: (Bart) Initialized version 0.4.8, author 'logread'
2020-04-18 15:38:01.351  Status: MQTT: Connecting to 192.168.2.12:1883
2020-04-18 15:38:01.465  Status: RFLink: Controller Initialized!...
2020-04-18 15:38:01.541  Status: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2020-04-18 15:38:01.553  Status: MQTT: connected to: 192.168.2.12:1883
2020-04-18 15:38:01.754  Status: MQTT: Subscribed
2020-04-18 15:38:01.840  Status: (Lars) Entering work loop.
2020-04-18 15:38:01.841  Status: (Lars) Initialized version 0.4.8, author 'logread'
2020-04-18 15:38:02.044  Status: (Omnik) Entering work loop.
2020-04-18 15:38:02.045  Status: (Omnik) Initialized version 1.0.1, author 'sincze'
2020-04-18 15:38:02.629  Status: (Vloerverwarming) Entering work loop.
2020-04-18 15:38:02.630  Status: (Vloerverwarming) Initialized version 0.4.8, author 'logread'
2020-04-18 15:38:02.861  Status: (Shelly) Entering work loop.
2020-04-18 15:38:02.862  Status: (Shelly) Initialized version 0.4.2
2020-04-18 15:38:03.528  Status: (Rookkast) Entering work loop.
2020-04-18 15:38:03.529  Status: (Rookkast) Initialized version 0.4.8, author 'logread'
Fatal Python error: Segmentation fault
Current thread 0x74b22220 (most recent call first):
2020-04-18 15:38:03.530  Error: Domoticz(pid:1206, tid:1209('PluginMgr')) received fatal signal 11 (Segmentation fault)
2020-04-18 15:38:03.530  Error: siginfo address=0x4b6, address=(nil)
2020-04-18 15:38:09.884  Status: P1 Smart Meter: Found gas meter on M-Bus channel 1
2020-04-18 15:38:09.884  Status: P1 Smart Meter: Meter is pre DSMR 4.0 and does not send a CRC checksum - using DSMR 2.2 compatibility
2020-04-18 15:38:09.900  (Slimme meter) P1 Smart Meter (Power)
2020-04-18 15:38:09.925  (Slimme meter) P1 Smart Meter (Gas)
2020-04-18 15:38:09.983  Error: Thread 4 (Thread 0x74b22220 (LWP 1209)):
2020-04-18 15:38:09.984  Error: #0  __waitpid (options=0, stat_loc=0x74b20d60, pid=1234) at ../sysdeps/unix/sysv/linux/waitpid.c:30
2020-04-18 15:38:09.984  Error: #1  __waitpid (pid=1234, stat_loc=0x74b20d60, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:25
2020-04-18 15:38:09.984  Error: #2  0x001099bc in dumpstack_gdb(bool) ()
2020-04-18 15:38:09.984  Error: #3  0x00109f88 in signal_handler(int, siginfo_t*, void*) ()
2020-04-18 15:38:09.984  Error: #4  <signal handler called>
2020-04-18 15:38:09.984  Error: #5  raise (sig=11) at ../sysdeps/unix/sysv/linux/raise.c:50
2020-04-18 15:38:09.984  Error: #6  <signal handler called>
2020-04-18 15:38:09.984  Error: #7  0x75dcf9dc in PyDict_GetItem () from /usr/lib/arm-linux-gnueabihf/libpython3.7m.so
2020-04-18 15:38:09.984  Error: #8  0x004525e8 in Plugins::onDeviceModifiedCallback::ProcessLocked() ()
2020-04-18 15:38:09.984  Error: #9  0x00091f98 in Plugins::CPluginMessageBase::Process() ()
2020-04-18 15:38:09.984  Error: #10 0x00455200 in Plugins::CPluginSystem::Do_Work() ()
2020-04-18 15:38:09.985  Error: #11 0x0077e854 in execute_native_thread_routine ()
2020-04-18 15:38:09.985  Error: #12 0x76ba1494 in start_thread (arg=0x74b22220) at pthread_create.c:486
2020-04-18 15:38:09.985  Error: #13 0x76a54578 in ?? () at ../sysdeps/unix/sysv/linux/arm/clone.S:73 from /lib/arm-linux-gnueabihf/libc.so.6
Segmentation fault
Can anyone please help?
Thanks again,
Paul
Remicade
Re: Crash after updating parameters
Post by Remicade »
After : ./updatebeta
things are running again.
I am lost but happy.
Paul
