Accuweather configuration
Posted: Friday 17 April 2020 11:18
by jensc
Beta 2020.3
Raspberry 3B+
After adding the Accuweather service "hardware", no device appears. The only thing relevant in the logs is: "AccuWeather: Worker stopped..." and no evidence that it tried to start. Where to from here?
EDIT: After some time, this appears in the error log: "Error: AccuWeather: Error getting http data!"
Re: Accuweather configuration
Posted: Wednesday 15 July 2020 15:30
by mojojojo490
Hi, you have to make a API key on de developers site from Accuweather.
Also the longitude, latitude must be reversed from the description next to it.
Than you will see directly on devices the new devices.
Posted: Tuesday 19 January 2021 9:24
by NRJMons
Well, same problem here.
The API key is correct, I tested it on accuweather website
The location is 962177 and is also correct, as tested on accuweather website.
The location in setup screen has been set as follows:
962177
50.475,3.907 (doesn't work), although it's the Long LAt given by accuweather itself in the response to the queries
3.907,50.475 (doesn't work), reversed as indicated
There must be something wrong elsewhere because nothing works
Is there a way to check the code that is run by Domoticz somewhere in the logs?
NRJ
Posted: Tuesday 19 January 2021 9:46
by NRJMons
Some additionnal info:
the link:
https://dataservice.accuweather.com/cur ... tails=true
(I changed some characters in the API key => the link above will not work as such)
But the link does work with the right key and proves that the APi and location are correct. These are the only parameters you can enter in the Hardware definition.
I also checked the code in
https://github.com/domoticz/domoticz/bl ... eather.cpp
The code looks ok although there are multiple places that can return "Error: Error parsing http request" that I get repeatedly in my log.
What's wrong then? I don't know. Hard to say without debug.
There is a debug mode foreseen in the code that refers to loading the data from a local file "E:\\AccuWeather_LocationSearch.json", but it seems to be for Windows users, which I'm not. Strange indeed that it's hardcoded like that.
So, I'm stuck, the only other option I have is OpenWeather or develop the lua scripts myself and provide the json-decoded data to virtual sensors. But that's really a pity.
NRJ
Posted: Monday 03 April 2023 15:26
by HM31
I'm digging up this old topic because I get exactly the same behavior. I'm using locationkey instead of lat/long because accuwetaher API only refer to this and when using an http request taken from code (after replacing variable parts) it works flowlessly ...
Posted: Wednesday 12 July 2023 16:40
by desertdog
Same here, I have tried with locationkey and lat,long, but when adding the hardware, no devices appear. Nor do I get an error in the log. Anyone got this working?
Posted: Sunday 03 November 2024 17:44
by epierre
same here, seems an issue from domoiticz since api is correct and valid
