problem with os.execute in dzVents, while in "normal" lua all is fine
Posted: Tuesday 14 April 2020 14:31
Hi guy's,
I'm having a bit of trouble to do the following using dzVents:
- Shutdown a remote host using os.execute over ssh from a local host (e.g. domoticz that shutsdown another raspbeery pi)
What did I do:
- installing keys to remotely ssh without a password (
works)
- verified from local cli on domoticz pi that command used is working to shutdown remote host (
works)
- verified from local cli on domoticz pi that using "normal" lua without dzvents, code is working (
works)
- Using a script on the remote host to shutdown, containing simple "sudo shutdown now" triggered over ssh from local host with (
works)
- Directly triggering from local host to remote host with (I added the pi users to the visudo list to directly use "shutdown" instead of /sbin/shutdown) (
works)
- trying both the "os.execute" and "assert(io.popen(cmd, 'r')" way using a standard lua script on local host (
works)
What is the problem:
When using dzvents do accomplish the same as above, it is not working. Even if relevant parts of lua codes that works in standard lua get copied to dzvents.
Full Script:
The relevants part that must trigger the remote host to shutdown are these:
or
I hope that somebody can help me out. Thanks already!
What did I do:
ssh [email protected] sh /home/pi/shutdown.sh- Directly triggering from local host to remote host with
ssh [email protected] sh sudo shutdown now- trying both the "os.execute" and "assert(io.popen(cmd, 'r')" way using a standard lua script on local host (
Full Script:
devices = {
'Werkkamer - Sw_L'
logging = {
level = domoticz.LOG_DEBUG,
marker = "P3STEELSWITCH.LUA"
execute = function(domoticz, switch)
local cmd = "ssh [email protected] sh /home/pi/shutdown.sh"
domoticz.log(switch.state)
if(domoticz.devices('Werkkamer - P3Steel').state == 'On') then
if(domoticz.devices('Werkkamer - P3Steel').lastUpdate.minutesAgo >= 1) then
domoticz.log("3D printer powered on > 1 minute ago, shutdown")
domoticz.log(cmd)
os.execute(cmd)
--local f = assert(io.popen(cmd, 'r'))
--s = assert(f:read('*a'))
--f:close()
--print(s)
--domoticz.log(s)
domoticz.devices('Werkkamer - P3Steel').switchOff()
domoticz.log("3Dprinter powered on < 1 minute ago, don't shutdown.")
domoticz.devices('Werkkamer - P3Steel').switchOn()
os.execute(cmd)
f:close()
--print(s)
domoticz.log(s)
