Add a dim function to a pushbutton
Posted: Friday 10 April 2020 9:44
by dutchronnie
I have a script that was working fine, but i want that the light is dimming to 100%
This was the original code
return
    on = { devices =  { 'Drukknop keuken' }}, -- Name of your pushButton
    execute = function(dz)
        dz.devices('Keuken Koof').toggleSwitch()  -- Name of your light
        dz.devices('Keuken Nis').toggleSwitch()    -- Name of your light
So i changed the script to:
return
        dz.devices('Keuken Koof').toggleSwitch().dimTo(100)   -- Name of your light
This is not working, i get the following error in the log:
6: attempt to call a nil value (field 'dimTo')
Does somebody know what i am doing wrong?
Re: Add a dim function to a pushbutton
Posted: Friday 10 April 2020 10:08
by waaren
dutchronnie wrote: Friday 10 April 2020 9:44 I have a script that was working fine, but i want that the light is dimming to 100%
You try to combine the methods toggleSwitch() and dimTo()
dzVents cannot determine where to toggle to so this combination is not valid.
Try with this implementation of a 'home made' toggle function
return
    on =
        devices =
            'Drukknop keuken'  -- Name of your pushButton
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'toggle on pushbutton',
        local koof = dz.devices('Keuken Koof')
        local nis = dz.devices('Keuken Nis')
        if koof.active then
            koof.dimTo(0)
            koof.dimTo(100)
        nis.toggleSwitch()
Re: Add a dim function to a pushbutton  [Solved]
Posted: Friday 10 April 2020 10:40
by dutchronnie
Thanks Waaren, it works :D
