Exclude option in selector switch after pressing it
Posted: Monday 06 April 2020 19:09
by WietseM143
With the help of Domoticz I have automated my curtain at home. For this I used two ESP relays. I then created two switches in Domoticz for these relays called $ESP1 and $ESP2. I then created a selector switch called 'Gordijn_Wietse' with the options 'open', 'dicht' (closed), 'open met interval' (open with intervals, great for the mornings) and 'stop' (to stop if anything would go wrong). I made a script which toggles the ESP switches when performing an action on the selector switch. In this way, when pressing 'open' on the selector switch, the curtain automatically opens and after X seconds the motor stops. I included that in the script. Right now, it is however still possible to press 'open' after I have already opened the curtain, which means the motor tries to open an already open curtain and I'm afraid that at some point in the future these excessive forces will become fatal for my setup. I therefore want to include a restriction. I want to make it impossible to press 'open' or 'open met interval' on the selector switch when the switch is already on 'open'. In other words, the only options to press when the curtain is open should be 'dicht' or 'stop'. I have tried to implement this myself, but till now I'm not managing to do so. Does anyone know if this is even possible and if yes, how?
For switching to open, my straight-forward LUA code right now looks like this:
if (devicechanged['Gordijn Wietse'] == 'Open') then
commandArray['$ESP1']="On FOR 69 SECONDS"
commandArray['$ESP2']='Off'
Re: Exclude option in selector switch after pressing it
Posted: Monday 06 April 2020 21:27
by waaren
WietseM143 wrote: Monday 06 April 2020 19:09
I have automated my curtain at home. For this I used two ESP relays. I then created two switches in Domoticz for these relays called $ESP1 and $ESP2. I want to make it impossible to press 'open' or 'open met interval' on the selector switch when the switch is already on 'open'.
Don't know how to tackle this in classic Lua but in dzVents (100% Lua) it could be implemented like below.
When not yet familiar with dzVents please start with reading
Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
return
on =
devices =
'Gordijn Wietse',
logging =
level = domoticz.LOG_DEBUG,
marker = 'Gordijn manager',
data =
lastLevel =
initial = 'stop' ,
execute = function(dz, item)
local openRelay = dz.devices('$ESP1')
local closeRelay = dz.devices('$ESP2')
local blockOpen = dz.data.lastLevel == 'open' or dz.data.lastLevel =='open met interval'
local blockClose = dz.data.lastLevel == 'dicht'
if blockOpen and (item.levelName == 'open' or item.levelName =='open met interval') then
dz.log(item.name .. ' already open. Action not allowed', dz.LOG_ERROR)
return
elseif blockClose and item.levelName == 'dicht' then
dz.log(item.name .. ' already closed. Action not allowed', dz.LOG_ERROR)
return
dz.log(item.name .. ' switched to ' .. item.levelName ..' (' .. item.level ..'). LastLevel was: ' .. dz.data.lastLevel, dz.LOG_DEBUG)
dz.data.lastLevel = item.levelName
if item.levelName == 'open' then
openRelay.cancelQueuedCommands()
openRelay.switchOn()
openRelay.switchOff().afterSec(69)
closeRelay.switchOff().checkFirst()
elseif item.levelName == 'open met interval' then
for delay = 0, 3600, 360 do -- 10 steps of 6 minutes each
openRelay.switchOn().afterSec(delay)
openRelay.switchOff().afterSec(delay + 7)
elseif item.levelName == 'stop' then
elseif item.levelName == 'dicht' then
closeRelay.switchOn()
closeRelay.switchOff().afterSec(69)
Posted: Tuesday 07 April 2020 14:37
by WietseM143
waaren wrote: Monday 06 April 2020 21:27
return
on =
devices =
'Gordijn Wietse',
logging =
data =
lastLevel =
initial = 'stop' ,
return
return
Thanks a lot!! I'm definitely going to try this soon!
