Fibaro dimmer 2 behavior
Posted: Monday 06 April 2020 15:25
by astrapowerrr
Hi can someone tell me. Why 1 of my 4 installed fibaro dimmer 2 is acting strange.
I have those dimmers for several years now. And working perfectly!
But now after updating to 2020 version the whole zwave is as wonky as can be.
Now I have 1 dimmer 2 that when you push bi stable s1 lights go on and s1 gain it switches of.
But I want it like al those years before that s2 switches off and dim downwards.
I checked the other 3 modules and they have the same parameter settings.
So I can’t fix it what is wrong.
Please help!
Re: Fibaro dimmer 2 behavior
Posted: Tuesday 07 April 2020 9:53
by astrapowerrr
Today I found my solution.
As in the parameters my switch was setup as bi stable switch... and it is a bistable one.
As I said all my switches are configed as bistable. Because I checked the parameters of all the other identical switches.
But now I changed parameter to rollershutter and it works now like I want to.
So in short:
After update to 2020 version the parameter in the dimmer 2 module changed from rollershutter to bi stable(when you check parameters in domoticz) but in real life my old switches still work like rollershutter.
