Json parse - how to get value?
Posted: Sunday 05 April 2020 23:32
by tomes
I have a JSON string:
{"folder":{"testA":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testB":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testC":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1}}}
How can I get 2nd lever names using DzVents? I want to print testA testB testC
In my case these names may be different, so i must know all path to get for example item.json.folder.testA.tg
Or maybe there is a simpler way to extract these values?
I will be grateful for any hint.
Tom
Re: Json parse - how to get value?
Posted: Monday 06 April 2020 0:24
by waaren
tomes wrote: Sunday 05 April 2020 23:32
Not sure I completely understand the question but this should get you going.
return
on =
devices =
'jsonTrigger' -- virtual switch to start the script.
logging =
level = domoticz.LOG_DEBUG,
marker = 'json converter',
execute = function(dz)
local lodash = dz.utils._ -- set of very useful tools
myJSON = '{"folder":{"testA":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testB":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testC":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1}}}'
myTable = dz.utils.fromJSON(myJSON)
dz.utils.dumpTable(myTable) -- dumps the complete json (converted to a table)
for key, subTable in pairs(myTable.folder) do
dz.log(key ..': ' .. lodash.str(subTable), dz.LOG_DEBUG) -- key are the tableNames below 'folder'
Posted: Monday 06 April 2020 15:48
by tomes
Works perfectly! Thanks a lot.
So, i have another question. How to get KEY which have set isTalker:true?
Tom
Posted: Monday 06 April 2020 16:42
by waaren
tomes wrote: Monday 06 April 2020 15:48
Tom
return
on =
devices =
logging =
myJSON = '{"folder":{"testA":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testB":{"isTalker":true,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1},"testC":{"isTalker":false,"monitoredTGs":[],"protoVer":{"majorVer":1,"minorVer":0},"tg":1}}}'
if subTable.isTalker then -- if true
dz.log(lodash.str(key),dz.LOG_DEBUG)
Posted: Monday 06 April 2020 16:49
by tomes
Great! Thanks again. Everything works perfectly!
