Devolo home Control Smart Metering Plug MT02792+ and 2020.1
Posted: Sunday 05 April 2020 17:46
maybe I posted this in the wrong category before, it probably belongs here as it concernes a zWave device that is addressed via a OpenZWave USB dongle (Version: 1.6-1063-g04969b71):
I made a fresh install of the new 2020.1 version on Synology NAS (domoticz_apollolake-6.2_2020.1.11804-8.spk). I also have an installation where I upgraded from the previous version and now get on both installations messages like the following in the log:
2020-03-24 22:40:11.055 Error: OpenZWave: Unhandled Meter type: Electric - Pulses, class: 0x32 (METER), NodeID: 3 (0x03), Index: 3, Instance: 1
2020-03-24 22:40:12.592 Error: OpenZWave: Unhandled Meter type: Electric - Pulses, class: 0x32 (METER), NodeID: 3 (0x03), Index: 3, Instance: 1
2020-03-24 22:40:12.592 Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!. Node: 3 (0x03), CommandClass: METER, Label: Electric - Pulses, Instance: 1, Index: 3
Removing the node and adding it again did not help.
The device is a Devolo Smart Metering Plug and in Node Management shows as
"Devolo home Control Smart Metering Plug MT02792+"
The functions I use (switch On/Off) are OK, though.
edit: I checked the configuration file in the installation which is used and came with the installation file (mt02792.xml).
The content starts with:
I also checked a backup of the installation of the old version and saw that it was using the same file, but these messages did not appear then.
edit: The device configuration files are identical to what is in Github.
Is this just because of the code changes in OZW?
Any suggestions?
Thank you a lot in advance.
Best regards
Al
In products.z-wavealliance.org the product number of the power plug I am using is 2057.<?xml version="1.0" encoding="UTF-8"?>
<!-- Devolo Metering Plug MT 2646
http://products.z-wavealliance.org/products/1129
Any suggestions?
Best regards
Al
