Combine multiple sensors (Temp/Hum) | RSS news feed not working
schwuppdiwupp
Post by schwuppdiwupp »
Hi!
I just started my Dashticz project and wanted to know if there is a possibility to combine sensor values to one item.
Domoticz is reporting my Aqara Sensors with 3 different idx i.e. 45 temp, 46 hum, 47 pressure
I found sensor_block: 1 as a parameter, but no explanation how it is supposed to be setup. Looking at the code, it is expecting some kind of idx_1, idx_2, idx_3
Any easy solution to this?
My 2nd problem: I want to show some news on the board.
I copied the example and tried some different things but I always end up with this error:
RSS feed SyntaxError: Failed to execute 'open' on 'XMLHttpRequest': Invalid URL. Check rss url.
System is running on a Pi4 with raspbian
Dashticz 3.4.2 beta
Domoticz version 2020.1
dzVents version 3.0.1
Python version 3.7.3
PHP 7.4.4
schwuppdiwupp
Re: Combine multiple sensors (Temp/Hum) | RSS news feed not working
Any suggestions?
clinkadink
Post by clinkadink »
For devices with multiple data, i.e. subdevices, I think you can add them like this:
blocks[123_1] = {
	title: 'My Sub Device Title',
	flash: 500,
	width: 4
More here on blocks and subdevices ...
https://dashticz.readthedocs.io/en/beta ... parameters
For the RSS feed, what url are you trying to access? What happens when you paste the RSS url into a browser??
Lokonli
Post by Lokonli »
Don't forget the quotes around '123_1', like this:
blocks['123_1'] = {
If you use '123_1' as label, then only subdevice 1 will be shown on the dashboard.
With label '123' all subdevices of device 123 will be shown.
For some devices it's possible to combine the values of the subdevices into one block, by adding the 'single_block' parameter, like this:
blocks['123'] = {
   single_block: true
schwuppdiwupp
My problem is, I don't have subdevices. I got three different idx numbers(45,46,47) for the readings from one aqara sensor. (Deconz zigbee plugin)
Lokonli
Post by Lokonli »
Combining three devices in Dashticz is not possible at the moment. Maybe something for the future :)
You can create a dummy device in Domoticz, and combine the data with some scripting.
schwuppdiwupp
ok, will try that tomorrow.
Any suggestions for my news problem?
clinkadink
schwuppdiwupp wrote: Tuesday 07 April 2020 21:36 ok, will try that tomorrow.
Did you check the url in a browser, as mentioned in my reply?
schwuppdiwupp
Sorry, seems like I didn't read that.
I tried the URL from the example and 3-4 other ones. None worked. All had the same error. The one I want to have is: www.n-tv.de/rss
clinkadink
Works fine for me, both the url in a browser, and in Dashticz news. I see the news and photos.
Make sure these are set in your in config.js.
config['default_news_url'] = 'https://www.n-tv.de/rss';
config['news_scroll_after'] = '10';
config['default_cors_url'] = 'https://cors-anywhere.herokuapp.com/';
schwuppdiwupp
you're my hero!
It's the default_cors_url parameter that was set to 0 in my config. This should be updated in the wiki (https://dashticz.readthedocs.io/en/mast ... /news.html)
Lokonli
Post by Lokonli »
schwuppdiwupp wrote: Tuesday 07 April 2020 22:06 you're my hero!
The news block requires a CORS proxy to work.
With the default_cors_url parameter you can define which CORS proxy to use.
If you don't set this parameter the internal Dashticz CORS proxy will be used.
If you configured Dashticz by following the installation instructions the internal Dashticz CORS proxy will work. It will then be more reliable than the CORS proxy from herokuapp, because that one is offline quite often.
If you set the default_cors_url parameter to 0, then you've disabled the CORS proxy.
So my advice is:
Don't set the default_cors_url parameter, unless you really have to.
schwuppdiwupp
Ahh, I see! I just copied the generated file from my settings to the config file as a start. Thx for clarification on this.
Thorgal789
Post by Thorgal789 »
Lokonli wrote: Tuesday 07 April 2020 21:34 Combining three devices in Dashticz is not possible at the moment. Maybe something for the future :)
You have some scripts here for that https://github.com/Smanar/Domoticz-deCO ... ame-sensor
