How stop delayed swtich in scene
Posted: Tuesday 31 March 2020 22:17
I have an irrigation system with some areas and a pump.
I programed a scene to launch manually the irrigation. I used the on and off delay to chain the areas (in seconds for tests):
Switch 1 (area 1) _ ON delay:0 _ OFF delay:6
Switch 2 (area 2) _ ON dealy:5 _ OFF delay:6
Switch 3 (area 3) _ ON delay:10 _ OFF delay:6
Switch 4 (pump) _ ON delay:1 _ OFF delay:15
The permutation between 2 areas are not at the same moment to be sure that no overpressure in circuit occurs and the pump start after opening the first valve and stop befor close the last one (for the same reason).
All works perfectly. But in case of I need to stop the process, I made another scene with all switch to OFF with 1 sec delay off for the valves (always to prevent overpressure).
When I activate the "Stop scene", all output goes to off. But if cycle is not finnished, the switchs continue to be activated. If I stop for example at 7 seconds, switch 2 and pump goes OFF. But at 10 seconds, the switch 3 goes ON etc...
Is it possible to have acces to the timer of the scene (throw a scrypt for example) to reset them ?
Or do you have any other solution ?
Thanks for your help.
Regards.
Regards.
