Change default Dashticz port 8082
misterleffe
Post by misterleffe »
Hi!
Is it possible (should be), when Dashticz is installed with the default port 8082, and afterwards change the port? I have 4 RPi and they use ports 8080-8083. Daschticz used port 8082 when installing per default. In what file, is the port defined??
I want to have a free port, exclusive for Dashticz, so I can reach Dashticz from outside of my LAN, through portforwarding.
Someone :?:
Lokonli
Re: Change default Dashticz port 8082
Post by Lokonli »
misterleffe wrote: Tuesday 31 March 2020 14:05 Hi!
Someone :?:
By default Dashticz will take the first free port at 8080 or higher.
To change the port, first stop the Dashticz container:
make stop
Edit (or create) the file Makefile.ini in the Dashticz root folder. Add the following content:
PORT=8090
(all case sensitive)
You have to check whether the assigned port is available yourself.
Restart the Dashticz container:
make start
easypeasy :)
misterleffe
Ok, thanks!
I'm not a pro in Raspberry/Linux, so how jump to root?
Can't go lower than /home/pi How to come further?
If I run command sudo make stop in /home/pi Raspberry says "No rule .... Stop. Sorry for my poor knowledge in Linux ....
Perhaps you can point me in the correct direction?
Lokonli
Post by Lokonli »
Start with:
cd dashticz
misterleffe
Thanks! Working with "new" port!
Learn new things every day ....
