how to differentiate a manual action from the dashboard and an action controlled by a script?
Posted: Tuesday 31 March 2020 13:43
hello
is there a command to differentiate a manual action from the dashboard and an action commanded by a script?
I want to update the state of a shutter which can be ordered by dz via the dashboard and another independent system. the action via dz acts on the third-party system and reverses the dz command (impulse command)
I just want to use the silent () command in the exclusive case of an order initiated by the third system without sending a new command to the third system.
the third-party system updates to a push on button called '$impulsion volet douche'
the dasboard blind command is named 'volet douche'
i test lastupdate 'volet douche' but don't work correctly in this case
-if the shutter is activated directly by the third-party system, update of the corresponding device, without the command via the return of the third-party system $ impulse ...
- if the shutter is controlled by dz, no action the device has already changed position via the dashboard
