Device not visible and no variable triggering
Posted: Monday 30 March 2020 21:41
by PVuser
I searched a while, but cannot find any hint. I'm new to Domoticz so it's more difficult for me. Also to detect the reason, so perhaps if this is not the right sub board please move my entry.
The problem 1:
I didn't find my device in any of the programming languages. And I cannot use it there. I only can find the device in device list, at counters and in the list of devices I get in the progamming view. The values are correct displayed.
I put the hardware and device to Domo with the following commands:
- --http://<ip of device>/json.htm?type=command&param=addhardware&htype=15&port=1&name=Fronius&enabled=true
--http://<ip and port of domoticz>/json.htm?type=createvirtualsensor&idx=8&sensorname=FroniusConsumption&sensortype=248
As I workaround I put the value in my deviceAdapter in a user variable.
commandArray['Variable:nGrid'] = tostring(nGrid);
That I can use than in a lua script, but not in dzVent.
The problem 2: I cannot use dzVent
II followed the wiki tutorial for dzVent, but get not trigger. No trigger on the above described device, nor the user variable. I also tried to set a global variable in a lua script to trigger, but this fails also. I tried it as a numeric value and a string value:
		variables = {
			'Grid','nGrid','sGrid'
	execute = function(domoticz, variable)
		domoticz.log('>>>>>>>>>> Variable ' .. variable.name .. ' was changed'..'to: '..variable, domoticz.LOG_INFO)
		-- code
I tried Tasmota devices. They trigger as expected!
I tried timer. They trigger as expected!
Whats wrong. I hope I get any help - Thanks
Re: Device not visible and no variable triggering
Posted: Wednesday 01 April 2020 19:35
by PVuser
Does no one have an idea??
Posted: Wednesday 01 April 2020 22:40
by waaren
PVuser wrote: Wednesday 01 April 2020 19:35 Does no one have an idea??
Not really yet. It is difficult for me to understand what your issues are based on your post.
It's unclear to me what the devices are. Maybe if you post a screenshot of the devices tab with the devices you want to evaluate / update in domoticz and tell us how you update them.
Same for the variables. Please show a screenshot and also tell us how you update them.
When not yet familiar with dzVents please start with reading Get started Before implementing (~ 5 minutes). Special attention please for "In Domoticz go to Setup > Settings > Other and in the section EventSystem make sure the checkbox 'dzVents enabled' is checked. Also make sure that in the Security section in the settings you allow 127.0.0.1 to not need a password. dzVents uses that port to send certain commands to Domoticz. Finally make sure you have set your current location in Setup > Settings > System > Location, otherwise there is no way to determine nighttime/daytime state."
Posted: Thursday 02 April 2020 10:46
by PVuser
Many thanks @waaren for your answer.
1) I have to mention, that I read the "Get started" and followed the instructions. So the tipps for starting dzVents I have done :-). Thats what I meant in my first post with "II followed the wiki tutorial..." sorry for unclear statement.
Also I thought, that my last two sentences will explain, that the dzVents basically work. Or isn't it a hint for working?
2) My issues are two things:
- My adopted devices are not visible for programming tasks
- My workaround with a variable didn't work with dzVents
3) The screenshots to devices
This are my devices I added to domoticz with the commands, I wrote in my first post.
I wrote a lua script to get the values from the device and than update domoticz with this commands:
           commandArray[1] = {['UpdateDevice'] = idx_PV .. '|0|' .. PAC .. ';' .. DAY_ENERGY}  -- PV-Leistung
            commandArray[2] = {['UpdateDevice'] = idx_VERBRAUCH .. '|0|' .. EVUNetz }           -- Einspeisung/Bezug
            commandArray[3] = {['UpdateDevice'] = idx_EIGENVERBRAUCH .. '|0|' .. VERBRAUCH }    -- Akt. Verbrauch
            commandArray['Variable:nGrid'] = tostring(EVUNetz);                                                     -- for workaround
It's triggered with "Device". But I also tried triggered "All". That is not the problem. In my log I get:
2020-04-02 10:12:30.597 Status: EventSystem: Script event triggered: FroniusAdapter
FroniusAdapter is the name of the Script. I think this is the hint, that the script was done sucessfull
The values in the device tab are updated in a correct manner :-)
What not work is the dcVent - script:
		devices = {
			'Smartmeter','FroniusAdapter','POW_01'
		domoticz.log('>>>>> Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
The value I want to trigger is 'Smartmeter'. It's listed in the list of devices at the domoticz programming site:
but the scrip will not be triggered. Also it is not usable in a normal lua script with:
    local meter = otherdevices['Smartmeter']
To test the basic working of the dcVent script I added a Sonoff basic switch called POW_01. If I switch it on/off in the switches Tab I get the protocol output:
 2020-04-02 10:40:49.295 Status: User: Admin initiated a switch command (3/POW_01/Off)
2020-04-02 10:40:49.437 Status: dzVents: Info: Handling events for: "POW_01", value: "Off"
2020-04-02 10:40:49.437 Status: dzVents: Info: ------ Start internal script: evTestDevice: Device: "POW_01 (Dummy devices)", Index: 3
2020-04-02 10:40:49.437 Status: dzVents: Info: >>>>> Device POW_01 was changed
2020-04-02 10:40:49.437 Status: dzVents: Info: ------ Finished evTestDevice
2020-04-02 10:40:49.611 Status: EventSystem: Script event triggered: FroniusAdapter
So that works fine! (The counters - of course I cannot trigger manually from the visual view, but they will be triggerd by a change of the value in my lua script.)
4) So I did the workaround with a user variable:
In the source code where I get the values from the device and write them to the commandArray (see above) I add the following line:
In my lua script I can than use it with:
   meter= uservariables["nGrid"]
but not in dzVent:
		variables = {
		-- code
(I tried several ways of triggering, so there are additional variables sGrid and Grid as normal global variables which I set in the lua script.)
the userVariable is set in Settings-Option-User variable:
So I hope you now have enougth information to help me. If not, as a different way, we can make a direct connection (mail,whatsapp, teamviewer,..), if you want. And than post the result here for others.
Many thanks in foreward
Posted: Thursday 02 April 2020 12:35
by waaren
PVuser wrote: Monday 30 March 2020 21:41 Whats wrong. I hope I get any help - Thanks
Thx for clarifying I understand now what you try to do and why it does not work as you might expect.
You use classic domoticz Lua commands to update device- and variable values and expect that this will cause trigger an event.
in https://www.domoticz.com/forum/viewtop ... old post you will find an explanation why it does not work. And what is explained there is also true for updating variables with classic Lua commands.
If you want the event system to send a trigger you will have to find another way.
You could try to make a time triggered dzVents or switch to dzVents for the initial script or use the openURL way in classic Lua for updating the device / variable
BTW. Please do not use external sites to post your screenshots. Over time the link will no longer work and therewith make your post meaningless for other forum members. I converted them now to attachments.
