Page 1 of 2
Ookla Speedtest CLI integration
Posted: Saturday 28 March 2020 16:15
by joosty
Have been using the speedtest-cli integration for some years, but yesterday swapped to the "speedtest" CLI provided by Ookla. The original speedtest-cli worked well, except for the latency/ping measurements. The Ookla speedtest does measure the ping correctly, so therefore a step forward.
Please note that you can't have them both installed at same time ;-)
Maybe this info saves some other people a bit of time to get this running.
1) create dummy sensors
2) store scripts somewhere (e.g. ~/domoticz/scripts)
see below for content
3) modify IDXs in script with IDXs of your virtual sensors
4a) remove speedtest-cli (if installed)
sudo apt-get remove speedtest-cli
4b) install speedtest from Ookla,
see https://www.speedtest.net/apps/cli (see Ubuntu/Debian)
check it works
5) install jq
sudo apt-get install jq)
6) verify the script works
check the port on which domoticz runs ;-)
7) create a crontab entry to schedule it.
#speedtest
5,20,35,50 * * * * ~/domoticz/scripts/ooklaspeed.sh > /dev/null 2>&1
speedtest trend.jpg (121.03 KiB) Viewed 18018 times
------------script content----------------------
#!/bin/bash
# make sure jq is installed
# sudo apt-get install jq
# define domoticz connection
host=127.0.0.1
port=80
# define ids for domoticz sensors
idxpng=69
idxul=70
idxdl=71
idxjit=122
# define location for file
file=~/ookla.json
# execute the speedtest and store result.
speedtest -f json-pretty > $file
downraw=$(jq -r '.download.bandwidth' $file)
download=$(printf %.2f\\n "$((downraw * 8))e-6")
upraw=$(jq -r '.upload.bandwidth' $file)
upload=$(printf %.2f\\n "$((upraw * 8))e-6")
png=$(jq -r '.ping.latency' $file)
jit=$(jq -r '.ping.jitter' $file)
#output if you run it manually
echo "download = $download Mbps"
echo "upload =  $upload Mbps"
echo "ping =  $png ms"
echo "jitter = $jit ms"
# upload result to Domiticz
curl "http://$host:$port/json.htm?type=command&param=udevice&idx=$idxdl&svalue=$download" > /dev/null 2>&1
curl "http://$host:$port/json.htm?type=command&param=udevice&idx=$idxul&svalue=$upload" > /dev/null 2>&1
curl "http://$host:$port/json.htm?type=command&param=udevice&idx=$idxpng&svalue=$png" > /dev/null 2>&1
curl "http://$host:$port/json.htm?type=command&param=udevice&idx=$idxjit&svalue=$jit" > /dev/null 2>&1
Re: Ookla Speedtest CLI integration
Posted: Saturday 28 March 2020 16:43
by FireWizard
@joosty.
Good initiative, as the Ookla Speedtest uses a much more modern approach then the speedtest-cli, developed by Sivel and used in @xorfor's plugin.
Be aware that the version in the (Buster) repositories contains a bug.
See: viewtopic.php?f=6&t=31267&p=236103&hili ... st#p236103
Another issue is that from time to time we all get faster internet, because of the competition between the providers.
Be aware that the measurements are not influenced by the speed of your Ethernet port.
You can't measure a "Download" speed of 500 Mbps with e.g. a Raspberry Pi 3B+ or lower.
See: https://magpi.raspberrypi.org/articles/ ... benchmarks
As the provider recently upgraded my "Download" speed from 100 Mbps to 200 Mbps, my Raspberry Pi 2B throttled the results.
I installed The Ookla Speedtest directly on my router/gateway and pushes the results with MQTT to Domoticz.
If someone is interested in the solution and the simple Node Red flow, let me know.
Posted: Saturday 28 March 2020 17:00
by joosty
I am on VDSL, where every provider is having issues to even provide a stable 50 Mbps. I mainly use the speedtest graphs to address issues with the ISPs.
I have raspberry 3b and I know from the unifi controller it can deliver around 80 Mbps on ethernet. Being stuck on VDSL that will be more then enough for coming years :cry:
Posted: Sunday 29 March 2020 12:38
by Bigted
FireWizard wrote: Saturday 28 March 2020 16:43
Can you post how you did that, I tried running Speedtest from my PI but it is being throttled
Posted: Sunday 29 March 2020 18:22
by FireWizard
Of course I can and I will do so :D .
As said, especially older versions of the Raspberry Pi, will, because of the limitation of their Ethernet port, throttle the results of the speedtest application, if used with high speed networks.
Therefore it might not be useful to run speedtest-cli, as provided by Sivel (https://github.com/sivel/speedtest-cli) to run on older models of RPi.
Do not use the speedtest-cli, as installed from the repo, as it contains a bug.
To have the most reliable result from Speedtest, which is not influenced by other hardware, such as switches, etc, it is recommended to install the test on a device with direct connection to your internet modem/router. Of course the Ethernet port of that device should be capable of handling the download and upload speed. Perhaps you can install it on your router/gateway.
In my case I have installed it on a ClearOS (CentOS based) server, running on a HP Microserver GEN 8. This is Linux based!
You can download the OOKLA Speedtest at: https://www.speedtest.net/apps/cli and choose your platform.
Install the program for your platform and run it once installed. The first time, you have to accept the license. The key is stored on your machine and you don't have to bother about it.
As I have running this program on a Linux based machine and as I wanted to have the data published on my MQTT server, you have to install, at least, mosquitto_pub on your hardware. This is part of the mosquitto_client package, but may differ for your platform.
I wanted to have the same functionality as provided by xorfor's python script for Domoticz. So that means 3 sensors for resp. Ping, Download speed and Upload speed. In addition 1 push button to activate the test manually.
For the last function I needed another program, called mqtt-launcher, provided by J.P. Mens: https://github.com/jpmens/mqtt-launcher.
Install also the requirements for this program. See the README file.
I copied this program in the directory /usr/local/bin.
If you do not need/want the manual push-button in Domoticz, you do not need to install mqtt-launcher.
In this case you have to activate the speedtest by means off a cronjob.
In the same directory I created a script file, called speedtest2mqtt.sh.
The contents of this file (I included also the "help" file of speedtest in it) is as follows:
#!/bin/bash
# Speedtest by Ookla is the official command line client for testing the speed and performance of your internet connection.
# Version: speedtest 1.0.0.2
# Usage: speedtest [<options>]
#  -h, --help                        Print usage information
#  -V, --version                     Print version number
#  -L, --servers                     List nearest servers
#  -s, --server-id=#                 Specify a server from the server list using its id
#  -I, --interface=ARG               Attempt to bind to the specified interface when connecting to servers
#  -i, --ip=ARG                      Attempt to bind to the specified IP address when connecting to servers
#  -o, --host=ARG                    Specify a server, from the server list, using its host's fully qualified domain name
#  -p, --progress=yes|no             Enable or disable progress bar (Note: only available for 'human-readable'
#                                    or 'json' and defaults to yes when interactive)
#  -P, --precision=#                 Number of decimals to use (0-8, default=2)
#  -f, --format=ARG                  Output format (see below for valid formats)
#  -u, --unit[=ARG]                  Output unit for displaying speeds (Note: this is only applicable
#                                    for ‘human-readable’ output format and the default unit is Mbps)
#  -a                                Shortcut for [-u auto-decimal-bits]
#  -A                                Shortcut for [-u auto-decimal-bytes]
#  -b                                Shortcut for [-u auto-binary-bits]
#  -B                                Shortcut for [-u auto-binary-bytes]
#      --selection-details           Show server selection details
#      --ca-certificate=ARG          CA Certificate bundle path
#  -v                                Logging verbosity. Specify multiple times for higher verbosity
#      --output-header               Show output header for CSV and TSV formats
# Valid output formats: human-readable (default), csv, tsv, json, jsonl, json-pretty
# Machine readable formats (csv, tsv, json, jsonl, json-pretty) use bytes as the unit of measure with max precision
# Valid units for [-u] flag:
#   Decimal prefix, bits per second:  bps, kbps, Mbps, Gbps
#   Decimal prefix, bytes per second: B/s, kB/s, MB/s, GB/s
#   Binary prefix, bits per second:   kibps, Mibps, Gibps
#   Binary prefix, bytes per second:  kiB/s, MiB/s, GiB/s
#   Auto-scaled prefix: auto-binary-bits, auto-binary-bytes, auto-decimal-bits, auto-decimal-bytes
# Script to push speedtest results to mqtt server (Mosquitto)
# Uses mosquitto_pub
# In order to use crontab use full path
/usr/bin/speedtest --format=json | /usr/bin/mosquitto_pub -L mqtt://user:password@<IP_address>:1883/speedtest/status -s
Insert your own IP address of the MQTT server after @. If you have protected your MQTT server with a username and password, insert this as well.
This will publish the data to your MQTT server under the topic speedtest/status. You can change that, if you want it.
In case you have choosen to use the manual activation button in Domoticz you have to configure "launcher.conf", which is used by mqtt-launcher.
See also the installed example file.
The contents of this file is as follows:
logfile         = '/usr/local/bin/mqtt-launcher.log'
mqtt_broker     = 'IP_address'                 # default: 'localhost'. If using TLS, this must be set to the domain name signed by your TLS certificate.
mqtt_port       = 1883                         # default: 1883
mqtt_clientid   = 'mqtt-launcher-2'
mqtt_username   = 'user'
mqtt_password   = 'password'
mqtt_tls        = None                         # default: No TLS
topiclist = {
    # topic                     payload value           program & arguments
    "speedtest/cmd":            {
                                     'on'               :   [ '/usr/local/bin/speedtest2mqtt.sh' ],
Insert your IP adress between ' ' and if you have your MQTT server protected insert username and password between ' '.
In the directory /user/local/bin I have now the following programs:
-rw-r--r-- 1 root root    689 Feb 14 16:49 launcher.conf
-rw-r--r-- 1 root root   1732 Feb 13 19:09 launcher.conf.example
-rw-r--r-- 1 root root    286 Feb 14 16:47 mqtt-launcher
-rw-r--r-- 1 root root 133309 Mar 29 16:00 mqtt-launcher.log
-rwxr-xr-x 1 root root   5234 Feb 13 19:09 mqtt-launcher.py
-rw-r--r-- 1 root root   3925 Feb 13 19:09 README.md
-rwxr-xr-x 1 root root   2790 Feb 15 14:10 speedtest2mqtt.sh
The next step is to prepare the flow in Node Red.
The flow in Node Red consist of two parts.
1. The incoming flow from your device, that runs speedtest, to Domoticz (Upper part)
2. The outgoing flow from Domoticz and Node Red to activate the speedtest-cli command (Lower part)
If you do not want to use the push button in Domoticz, you do not need the Lower part of the flow.
However in this case, you have to setup a cronjob in the device, which has speedtest-cli installed
Screenshot_speedtest flow1.png (27.93 KiB) Viewed 17964 times
1. Incoming flow
The first node is a MQTT input node. You have to insert the topic, that you use in the mosquitto_publish command on the device, that has
speedtest-cli installed. In this case speedtest/status.
Screenshot_speedtest flow2.png (18.67 KiB) Viewed 17964 times
The JSON node has its default configuration followed by the Function node, with the following contents:
var msg1 ={};
var msg2 ={};
var msg3 ={};
msg1.payload = {"command":"udevice","idx":119,"nvalue":0,"svalue":msg.payload.ping.latency.toString()};
msg2.payload = {"command":"udevice","idx":120,"nvalue":0,"svalue":(parseFloat((msg.payload.download.bytes*8/msg.payload.download.elapsed)/1000).toFixed(3)).toString()};
msg3.payload = {"command":"udevice","idx":121,"nvalue":0,"svalue":(parseFloat((msg.payload.upload.bytes*8/msg.payload.upload.elapsed)/1000).toFixed(3)).toString()};
return [[msg1,msg2,msg3]];
The outgoing node is a MQTT output node.
Do not forget, if you have not done yet, to configure Domoticz with the right custom sensors and replace the idx numbers with your idx's.
The next part is in a next post.
Posted: Sunday 29 March 2020 18:38
by FireWizard
If you have decided to include the push button in Domoticz, you need the lower part of the flow as well.
The first node is the default MQTT Output node, which is subscribed to domoticz/out, followed by the default JSON node.
The next node is anon-default node, that has to be installed from the palette.
This node filters the idx of the push button in Node Red. So check that idx number.
Install this node: node-red-contrib-filter.
It is configured as follows:
Screenshot_speedtest flow3.png (16.53 KiB) Viewed 17962 times
Replace the idx number with your idx.
The next node is a function node to send the correct data to the device, that has mqtt-launcher and speedtest-cli installed.
The contents is as follows:
if (msg.payload.nvalue === 1) {
    msg.payload = "on";
return msg;
This payload is send to a MQTT Output node, which is configured as follows:
Screenshot_speedtest flow4.png (21.82 KiB) Viewed 17962 times
This flow sends the push button command to your device, that has speedtest-cli installed.
The regular timing is done by an inject node that injects the correct payload to the same MQTT Output node.
Screenshot_speedtest flow5.png (33 KiB) Viewed 17962 times
Below you will find the complete flows:
[{"id":"8395ba46.a4eb1","type":"mqtt in","z":"ab5ccf37.8faeb8","name":"Server Speedtest In","topic":"speedtest/status","qos":"0","datatype":"auto","broker":"f9f13036.e28b58","x":190,"y":100,"wires":[["2eb9c765.43fa"]]},{"id":"2eb9c765.43fa","type":"json","z":"ab5ccf37.8faeb8","name":"","property":"payload","action":"","pretty":false,"x":390,"y":100,"wires":[["813c9c3b.7fb578"]]},{"id":"813c9c3b.7fb578","type":"function","z":"ab5ccf37.8faeb8","name":"To Domoticz","func":"var msg1 ={};\nvar msg2 ={};\nvar msg3 ={};\nmsg1.payload = {\"command\":\"udevice\",\"idx\":119,\"nvalue\":0,\"svalue\":msg.payload.ping.latency.toString()};\nmsg2.payload = {\"command\":\"udevice\",\"idx\":120,\"nvalue\":0,\"svalue\":(parseFloat((msg.payload.download.bytes*8/msg.payload.download.elapsed)/1000).toFixed(3)).toString()};\nmsg3.payload = {\"command\":\"udevice\",\"idx\":121,\"nvalue\":0,\"svalue\":(parseFloat((msg.payload.upload.bytes*8/msg.payload.upload.elapsed)/1000).toFixed(3)).toString()};\nreturn [[msg1,msg2,msg3]];","outputs":1,"noerr":0,"x":570,"y":100,"wires":[["ed6c10df.d23618"]]},{"id":"ed6c10df.d23618","type":"mqtt out","z":"ab5ccf37.8faeb8","name":"Domoticz In","topic":"domoticz/in","qos":"2","retain":"false","broker":"f9f13036.e28b58","x":770,"y":100,"wires":[]},{"id":"ec89ae7.ce185d","type":"mqtt in","z":"ab5ccf37.8faeb8","name":"Domoticz Out","topic":"domoticz/out","qos":"2","datatype":"auto","broker":"f9f13036.e28b58","x":170,"y":220,"wires":[["8f15b75e.0a94e"]]},{"id":"451753bf.8d4d14","type":"filter","z":"ab5ccf37.8faeb8","name":"Filter Button","property":"payload.idx","propertyType":"msg","asArray":false,"itemProperty":"","itemPropertyType":"item","rules":[{"t":"eq","v":"122","vt":"num","output":1}],"checkall":"true","outputs":1,"x":530,"y":220,"wires":[["d6e722d6.125e5"]]},{"id":"8f15b75e.0a94e","type":"json","z":"ab5ccf37.8faeb8","name":"","property":"payload","action":"","pretty":false,"x":350,"y":220,"wires":[["451753bf.8d4d14"]]},{"id":"d6e722d6.125e5","type":"function","z":"ab5ccf37.8faeb8","name":"To Speedtest","func":"if (msg.payload.nvalue === 1) {\n    msg.payload = \"on\";\n}\nreturn msg;","outputs":1,"noerr":0,"x":740,"y":220,"wires":[["64d59364.f1eb74"]]},{"id":"64d59364.f1eb74","type":"mqtt out","z":"ab5ccf37.8faeb8","name":"Server Speedtest Out","topic":"speedtest/cmd","qos":"0","retain":"false","broker":"f9f13036.e28b58","x":980,"y":220,"wires":[]},{"id":"681cf784.d0b4d8","type":"inject","z":"ab5ccf37.8faeb8","name":"Hourly Speedtest ","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"0 0-23 * * *","once":false,"onceDelay":0.1,"x":730,"y":160,"wires":[["64d59364.f1eb74"]]},{"id":"f9f13036.e28b58","type":"mqtt-broker","z":null,"name":"RPI1_ MQTT_Broker","broker":"192.168.10.51","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthRetain":"false","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
In case of questions, do not hesitate to ask.
Posted: Thursday 28 May 2020 18:48
by Z0eff
This looks interesting! Is there a way to only measure ping and jitter? (Video streams will buffer whenever a download test is being performed)
Posted: Thursday 28 May 2020 19:52
by FireWizard
HI,
@Z0eff
No, unfortunately not. The OOKLA speed test command line tool has no option to exclude the download and/or the upload test.
However, the python script from Sivel has that option.
See: https://github.com/sivel/speedtest-cli
Do not install this tool from the repos, as there is a bug. See above.
Posted: Friday 29 May 2020 0:09
by Z0eff
FireWizard wrote: Thursday 28 May 2020 19:52 HI,
@Z0eff
It doesn't look like that tool measures jitter though :(
Posted: Tuesday 15 December 2020 23:02
by grutter
thanks for post! two remarks
joosty wrote: Saturday 28 March 2020 16:15
had installed speedtest via:
https://pimylifeup.com/raspberry-pi-int ... d-monitor/
uninstall speedtest:
sudo pip3 uninstall speedtest-cli
changed script for running once:
speedtest --accept-license --accept-gdpr -f json-pretty > $file
Posted: Monday 06 December 2021 15:11
by SavioThecnic
Guys but something happened
I notice that it hasn't worked for a few months
If I try from the terminal and I start the script from this error
pi@raspberrypi:/home/domoticz/domoticz/scripts $ sudo ./ooklaspeed.sh
./ooklaspeed.sh: riga 19: speedtest: comando non trovato
download = 0,00 Mbps
upload = 0,00 Mbps
ping = ms
jitter = ms
Posted: Monday 06 December 2021 18:38
by FireWizard
Hello @SavioThecnic
From time to time Ookla Speedtest requires that you accept their license.
You will not see this, until you open a terminal and activate the speedtest-cli manually..
However it is indicated in Domoticz with a red bar above your widget, that it has exceed the maximum time for that sensor.
In the first version of the script, the first part of the command was as follows:
Currently I use:
/usr/bin/speedtest --accept-gdpr --format=json
This works fine for me, so far.
But you may want to add --accept-licence as well. See the @grutter post.
You can test from the command line in a terminal.
Posted: Monday 06 December 2021 19:17
by SavioThecnic
Thank you dear friend of the quick reply
I tried to send your commands but they give an error
it is not clear to me how I install the license if you give me some commands I can try again I am attaching photos of how my config is and of the result I have.
Posted: Monday 06 December 2021 22:32
by FireWizard
Hello @SavioThecnic
From your screenshot I see that you use the bash script provided by @joosty in his first post.
You might have seen that I use another method as I do not run the script on the same device as Domoticz.
I run the script on my Linux server/gateway/firewall and push the results with MQTT to the MQTT server.
From there with Node RED I prepare the data for Domoticz and send it to my Domoticz server.
However this should not be a problem. A quick scan of the bash script shows that this script might work well.
But I see something else in the small window.
A check with Google translate tells me that that means 'command not found"
That can mean two things, either you installed the speedtest-cli program at the wrong place or it has not been installed at all.
To install it on your Raspberry PI, you may want to use the following guide line:
Do not use the Python script.
Posted: Saturday 19 March 2022 17:15
by manjh
I ran speedtest-cli but it proved to be unreliable: sometimes it runs OK, but many times it fails somehow.
I then tried the Ookla test, but it will not install on my R-Pi 4 with current OS. This is the error:
curl -s https://install.speedtest.net/app/cli/install.deb.sh | sudo bash
This distribution version is not currently supported via package management, please use the direct download builds per architecture found at https://www.speedtest.net/apps/cli
What can I do? The Ookla site gives some options for Linux downloads, should I try one of those?
Posted: Saturday 19 March 2022 19:33
by zicht
for anyone using ookla,
Ookla has implemented a mechanisme to detect to many test in x time by automatic scripts like above
So if you see errors or a low value , please check if you are redirected to one of their "abuse" servers giving shit values.
I have discovered this by accident when i did ookla test on my browser and saw a obvious server name and values.
The name will tell you instantly that you have been redirected, can't remember is now, but is was really clear.
Now (with local python to txt file) only once in 15 minutes during the times that counts for me most.
Since then is works fine.
Posted: Saturday 19 March 2022 19:42
by FireWizard
Hello Hans,
I used the install method as indicated on the Ookla site.
However I did not install it on an Debian server but on a server running CentOS
So you can choose the one, that correspondents with you distribution.
See: Speedtest CLI and then Install Options
Perhaps it will work for you, but I did never see that error message.
I assume curl has been installed?
sudo apt-get install curl
Posted: Saturday 19 March 2022 19:50
by zicht
for anyone using ookla Cli,
Ookla has implemented a mechanisme to detect to many test in x time by automatic scripts like above.
It works by IP and includes also manual tests in your browser.
So if you see errors or a low value , please check if you are redirected to one of their "abuse" servers giving low values.
The name will tell you instantly that you have been redirected, can't remember the name, but is was really clear.
Now (with local python to txt file) max once in 15 minutes during the day times that counts for me most.
Posted: Monday 28 March 2022 22:14
by manjh
After a lot of trial/error, I finally found a setup that works without a glitch.
First removed everything from the R-Pi: all remnants of speedtest installations that I have tried before.
Then re-installed speedtest-cli using apt-get .
That's all for the Pi.
In Domoticz, I use a virtual switch to trigger the speedtest. Also have two custom sensors for download and upload speeds.
For now, I ignore the ping.
Next, created a flow in Node-Red. The flow is triggered by the domoticz trigger switch, and starts the speedtest-cli module in an exec node. The output is pushed through a json node, and output from that is processed in a normal function node to update the two sensor nodes, and also switch off the trigger.
Back in Domoticz, I have an event script that reacts to a change of the download sensor, and accumulates the values in a file.
Sounds complicated, but it really isn't...
This setup has now been running for a while, no problems at all.
Building on the growing data file, I have created another Node-Red flow to read the file, compress it into a single (average) value per date, and display it in a bar chart on Node-Red dashboard.
Posted: Friday 15 July 2022 8:57
by SavioThecnic
FireWizard wrote: Saturday 28 March 2020 16:43If someone is interested in the solution and the simple Node Red flow, let me know.
I had installed the script but it hasn't worked for months
Since I also installed the red node
I would be happy if you can share your flow
so i try to import it into my red node and see if it works Thanks
