strugling with screen design
henrybcn
Target OS: OS X
Post by henrybcn »
Hi All,
I have been reading a lot and experimenting, but I simply do not get it.... :(
I have a few sensors/switches in domoticz and I can see them without any issue in dashticz, but I really like to reorganize the screen like the pic below...
Can anyone tell me how to do that? I read all the documentation about blocks/columns, tried some of the config.js that some of you posted, but I can not make it work.
Can I use only the config.js to do that? Or do I also have to edit other files like custom.css?
I am not a programmer... Sorry if I am asking something stupid..... :shock:
any basic "template" that I can use to show more or less what I want?
Tks for the help!
Jimster
Re: strugling with screen design
Post by Jimster »
I'm also not a programmer, but managed to understand it. It's not very difficult. :)
A screen has width 12. Every column also has width 12.
What you want are 2 columns, I would say the left column width 5 and the right 7.
In the left column you can put your switches, remember the width of your switches in one line can be max 12.
This can be done in custom.js
henrybcn
Target OS: OS X
Post by henrybcn »
Tks Jimster! Ops.... i was trying to do that in config.js... I will try later on custom.js ;)
Lokonli
Post by Lokonli »
You can do it in config.js. custom.js is for more advanced use in case you want to customize blocks.
henrybcn
Target OS: OS X
Post by henrybcn »
Tks so much guys for pointing me out to the right direction! Now I am making progress....
Here is how it looks like:
And here the config.js:
config.js
(834 Bytes) Downloaded 84 times
How can I group my weather sensors in a new blocktitle after the Switches (in the same column 1)?
The IDX for the weather is 2
Any help/suggestion?
Alfagek
Domoticz version: 2020.1
Post by Alfagek »
something like this?
Switches (blocktitle)
switch 1 switch2 switch3
Weather (blocktitle)
weather
Check "your" new config.js i put here
config.js
(914 Bytes) Downloaded 93 times
henrybcn
Target OS: OS X
Post by henrybcn »
fantastic. what a simple solution... Tks so much Alfagek! ;)
Alfagek
Post by Alfagek »
henrybcn wrote: Saturday 28 March 2020 19:41 fantastic. what a simple solution... Tks so much Alfagek! ;)
Youre Welcome. I also send you a PM ;)
Jimster
Post by Jimster »
henrybcn wrote: Saturday 28 March 2020 17:42 Tks Jimster! Ops.... i was trying to do that in config.js... I will try later on custom.js ;)
Oops, I meant config.js
henrybcn
Target OS: OS X
Post by henrybcn »
Tks Jimster and Alfagek! Now I have the first version completed! I will fine tune over the next days.
Alfagek, I will read your pm tomorrow!
Here is how it looks like and it is really simple. I will post the code tomorrow....
